Old 02-03-2007, 01:11 AM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default Am i retarded? Can't get airbox cover back on
So some of you might have seen my other post about my poor gas mileage...
I went to take a look at the air filter to see if it was dirty.. .and now for the life of me.. i can't get the air box cover back on!
I don't know if its because it is a cheap filter, its definately not factory, and if i had to guess it is a FRAM air filter. But i can't seem to compress the rubber on the bottom part enough to get little tabs to go into the cutouts on the cover...
Is there some secret to this??
Maybe i just need to go pick up a factory air filter tomorrow from Subaru...
mc2 is offline   Reply With Quote
Old 02-03-2007, 01:32 AM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Hook the tabs first, slide the filter down and in to the "lid" and then close it up. My K&N doesn't fit perfect, but when it is clamped down the seal is good.
good luck
Jared
gtwagon941 is offline   Reply With Quote
Old 02-03-2007, 02:53 AM   #3
rougeben83
Member#: 115154
2005 Outback XT
White on grey
tilt the back part so that the bottom lip touches first then compress the thing to seal.
There are small latches on the bottom of the box that may be getting in the way.
rougeben83 is offline   Reply With Quote
Old 02-03-2007, 03:59 AM   #4
mc2
Member#: 59992
1997 Legacy L EJ22
So that's what i've been trying to do, but it seems impossible with the rubber piping that runs from the MAF to the resonator or whatever the big plastic box is.. I unbolted the MAF from the airbox cover just to make sure that was the reason, and i was able to hook the latches first and then use that to act like a hinge... but then of course you cant bolt the MAF back on then.. so i just did that to verify.
Now i'm trying to remove the rubber piping after the MAF but that thing is like melted on there or something...
Old 02-03-2007, 04:10 AM   #5
mc2
Member#: 59992
1997 Legacy L EJ22
okay nevermind... just took a screw driver and a bit of prying between there to finally get the piping off.. thanks for the help guys.
i think i should be okay now
Old 02-03-2007, 03:45 PM   #6
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Next time just unbolt the intake tube from the MAF tube so that the cover is seperate. Then you can finangle it more and then just reattach the intake tube again.
Plays_With_toys is offline   Reply With Quote
can't get door cards back on fl4tsc Car Audio, Video & Security 23 12-17-2008 01:42 PM
Corpus Christi: Help, I can't get my IC back on my 07 STI Spectre186 Texas Impreza Club Forum -- TXIC 8 09-21-2008 01:07 AM
I can't get my strut back on my car, help? Gso2k Brakes, Steering & Suspension 10 07-10-2008 01:43 AM
Tough to get intake cover back on? drees Newbies & FAQs 4 10-30-2002 02:51 PM
