Old 02-03-2007, 12:24 AM   #1
shemoves
Member#: 80663
2005 STi
Default Are catalytic converters directional?
I need to switch the Legacy's around so that the O2 bung is on the pre-cat side, rather than on the post-cat side. Wondering if the direction exhaust gas flows through the cat matters...
shemoves is offline   Reply With Quote
Old 02-03-2007, 05:18 AM   #2
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
I believe the o2 bung should be before the cat, but I do not think if you had a cat that was universal it would matter what direction it should be installed.... Please correct me if I'm wrong......
06grayrex is offline   Reply With Quote
Old 02-03-2007, 12:26 PM   #3
shemoves
Member#: 80663
2005 STi
yah, o2 needs to be pre-cat (unless it is the one that OBD-II cars have that is specifically for measuring post-cat air quality.
All it is as far as I know are mesh screens (retains/builds heat, cooks the junk out)...someone has written 'top/flow' with an arrow on it though so it made me wonder.
Old 02-04-2007, 11:05 AM   #4
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I know the 1st o2 is before the 1st cat. and I'm pretty sure the 2nd one is as well....
as far as universal cats...I'm pretty sure it doesn't matter. I just replaced my front O2 and rear cat.
IllNastyImpreza is offline   Reply With Quote
Old 02-04-2007, 08:55 PM   #5
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
as to the o2 sensor question, the upstream sensor is for fuel mixture, the post cat sensor is there to measure catalyst efficency only and must be located after the cat.
I am not sure about directional cats. I dont see why it matters, you have a honeycomb that gets hot and why it would matter which way the air went is beyond me. There may be some engineer who would disagree, but if you want to hook one up backwards I cant see any problem that would result as long as the sensors remained on the same side of the cat that they were on before the flip
NWstiLTD is offline   Reply With Quote
Old 02-04-2007, 11:03 PM   #6
shemoves
Member#: 80663
2005 STi
That is the same conclusion I came to.
Attn thieves: How to make money stealing catalytic converters.toyota trucks are easy plunk10 Off-Topic 17 01-25-2008 03:08 PM
Yet another catalytic converter thread...are all 2 (or 3) neccesary? kaisersouse New England Impreza Club Forum -- NESIC 5 05-05-2006 10:07 AM
catalytic converter? TerribleOne Newbies & FAQs 4 05-28-2001 11:55 PM
STS and catalytic converters Overtime Motorsports 3 05-19-2001 09:42 AM
Motor diagram and catalytic converters DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-21-2001 08:26 AM
