Old 02-03-2007, 04:25 PM   #1
keaniegenie
Member#: 94494
2005 Element 92x
Default 2.0l to 2.5l swap, and what AVCS means to you
It seems every time somebody does a swap from a 2.0l to a 2.5l, they are looking for some improvement in their power band. I found myself writing long posts over and over again telling the story of my swap, so I thought I'd start my own post, even though people will rarely search for it anyways
It's obvious that people who swap to a 2.5l EJ257 wants an improvement in power/torque in some fashion. How you go about your build should be relative to your total goals. I think one thing most people planning a motor swap think of is what kind of power they ultimately want and what kind of power band they're looking for.
This is the combination of engine/turbo setups I've had in the order I had them.
EJ205 w/ stock turbo
EJ205 w/ stock turbo + TBE, TMIC, EWG, and EL header
EJ257 w/ stock turbo +TBE, TMIC, EWG, EL header and no AVCS
EJ257 w/ stock turbo + TBE, TMIC, EWG, EL header + AVCS
EJ257 w/ Element GT52 turbo + TBE, TMIC, EWG, EL header and AVCS
The main purpose of this post to explain the differences I've noticed during my build, since it was done in stages. Let me start with my goals, and why I chose to go this route.
The biggest thing I found lacking of the EJ205 motor was the bottom end. Having driven several STI's, I desired the bottom-end torque and responsiveness the STI's had. This said, I also wanted to improve my top-end power as well. So in a sense, I wanted to improve my entire power band from bottom-end to top-end power with a final goal of 375+whp on pump gas and 450whp with water injection.
My original assumption regarding the bottom-end torque of the STI was that the increased displacement provided all of the low-end grunt I was shooting for. Having had a 2.5l EJ257 (longblock) with no AVCS wired, I soon learned the responsiveness of the EJ257 relied heavily also on the AVCS. There was no doubt there was an increase in torque and responsiveness with the 2.5l, but it was no where near the level of the STI's I've driven. Keep in mind that I had a TD04 turbo (stock WRX turbo) which spools faster than the factory STI VF39.
Later, I wired in AVCS control, which requires either a STI ECU, or a Hydra. Voila! Now it felt like an STI. The power was not only much better in the lower end, but the power range was also much more linear. Lag is not only reduced, but the power is smoother. WRX guys are very familiar with the boost on/off feel(this is the sudden torque you feel when the turbo is spooling up). This feel is dramatically reduced making the car feel more like a big NA motor.
Not long after, I installed the larger turbo. We modded the stock injectors , installed a fuel pump and new inlet pipe and got a new base map for my GT52 turbo from Phil. I was amazed how well such a large turbo mated to my 2.5l AVCS motor in terms of linear response and fast turbo spool up.
After my build, I had the luxury riding in a 2.5l hybrid with an FP Green turbo. For people who don't know, the FP Green uses the same housing as my GT52 turbo but utilizes a smaller turbine and compressor wheel.
This hybrid utilized the proper gaskets so the compression ratio would be safe and was using complete stock WRX heads including WRX cams. Even though the displacement of our cars was the same, it was very obvious that my setup was still much more responsive on the bottom-end power range. The hybrid had better bottom end power than an EJ205, but the boost on/off feel was still there and the Green felt laggy compared to my GT52 even though the Green is a smaller turbocharger. The only real explanation for this was the AVCS. Even though my STI heads uses more aggressive cam profiles, the bottom-end was still much better.
I find many 2.5l hybrid owners planning on non-AVCS setups with upgraded cams. When I speak to these users, often they're telling me they want more bottom-end torque and more overall power too including top-end. What many of them don't realize is they're taking 2 steps forward, one step back. Yes, the 2.5l will improve torque/power, and yes, the cams will improve top-end, but what they don't realize is how much higher lift/duration cams effect bottom-end power. The end result is a car with marginally improved bottom-end and much better top-end power. This combo doesn't even make sense to me unless your power goals exceed 500whp since you don't have to sacrifice the bottom end to get any power level less than this. On the other hand, a EJ257 longblock w/ AVCS is capable of hitting 500whp while having much improved bottom-end. The slightly more aggressive cams still provide great daily driving response, and the AVCS more than makes up for the profile.
Now, if a person said they wanted a top-end monster and they wanted the 2.5l just to help spool up their giant rotated turbo, a hybrid w/ aggressive non-avcs cams makes a ton of sense. The upgraded cams on a 2.5l hybrid will yield more top-end power than a stock STI longblock w/ AVCS. If you're shooting for 600whp on race gas, then you should be prepared to lose some bottom-end power for the ultimate top-end goal. The aggressive cam profile is then not an option, it's absolutely necessary.
So if you want the best improvement of bottom-end with an ultimate HP goal less than 500whp, AVCS makes the most sense. Not only that, but you also have the piece of mind that you're reaching your ultimate goal with an OEM motor. This, of course, is not taking into consideration any motor building you may want to do on the shortblock, IE pistons, rods, etc.
Many people think the cost of wiring an AVCS setup is super expensive. However, many people don't consider the ENTIRE cost of the build. If you follow a couple, small tricks to your build, you will save hundreds of dollars and get your ultimate goal at a reasonable cost. This post is long enough, so I won't go into details here. PM me if you want details.
keaniegenie is offline   Reply With Quote
Old 02-03-2007, 05:38 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Dear lord....go grab yourself a beer for that
JMK508 is offline   Reply With Quote
Old 02-03-2007, 06:09 PM   #3
Imprezav
Member#: 82034
Informative....To say the least.
I am a newb aquiring information but what if you built your block (pistons,rods blah blah blah) and decided to increase flow on existing wrx heads?
To flow more than those avcs heads with better cams than the stock WRX has?
Is AVCS all hype or can WRX heads ported/polished + better cams beat them?
I too am looking for something with power across the entire band but really dont mind a little lag down low as I am used to it with my rex.
This would be on some sort of stoker motor of course.
Imprezav is offline   Reply With Quote
Old 02-03-2007, 07:50 PM   #4
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Have beer, now reading...
dexterous is offline   Reply With Quote
Old 02-03-2007, 08:45 PM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
golf clap... excellent writeup
jigga is offline   Reply With Quote
Old 02-03-2007, 09:31 PM   #6
keaniegenie
Member#: 94494
2005 Element 92x
my own experience has shown me avcs is no hype. Ask any sti owner with a hydra. With a hydra, you can simply turn the avcs on and off by a couple of clicks on the laptop.
set your goal of what power you want, and the answer to your questions can be easily determined.
Old 02-04-2007, 01:45 AM   #7
wrx360
Member#: 37473
Platimun Silver
Thanks for the very nice writeup. I am definitely going to do a 2.5l short block eventually and this is very informative.
So what's needed in order to utilize AVCS when using the 2.5l short block? STi head, Sti ecu, engine wiring harness? Am I missing anything?
Can you PM your "tricks to a build" knowing as much as possible is going to help tremendously. Thanks
wrx360 is offline   Reply With Quote
Old 02-04-2007, 02:27 AM   #8
wrxzzz
Member#: 137105
can someone explaine what AVCS is exactly?
wrxzzz is offline   Reply With Quote
Old 02-04-2007, 03:31 AM   #9
keaniegenie
Member#: 94494
2005 Element 92x
AVCS is subaru's adjustable cam timing name. Basically, their version of vtec.
One thing I don't want to do is make it sound like AVCS is going to make your car pull like a semi truck. The difference is definitely notable, as is the 2.5 block. The combination of the two together is what makes the sti motor so much better than the ej205 wrx motor.
Old 02-04-2007, 03:48 AM   #10
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Man I totally know the painfully feeling of no bottom end and no AVCS...but not for long.
domestic_abuser is offline   Reply With Quote
Old 02-04-2007, 10:35 AM   #11
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
very...slow....deliberate...clapping.
JonR is offline   Reply With Quote
Old 02-05-2007, 06:03 PM   #12
keaniegenie
Member#: 94494
2005 Element 92x
Thanks everybody...
Here's a good description of AVCS
http://www.drive.subaru.com/Win05_WhatsInside.htm
Old 02-06-2007, 10:53 AM   #13
keaniegenie
Member#: 94494
2005 Element 92x
Here's a link on AVCS in the 2.5l forum too.
http://forums.nasioc.com/forums/showthread.php?t=699107
Old 02-06-2007, 01:29 PM   #14
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Thanks KG, knowing how much better you seem to have it with AVCS I am convinced I should go that route eventually. I have an EJ255 with no AVCS and an EWG VF39. Is it really going to make a ton of difference on my setup? I know you had a TD04 and not the VF39 but I'm hoping you can still shed some light. My "build" is complete and just awaiting a retune so it would cost a great deal of money to get AVCS going and get a tune.
wrxfactor is offline   Reply With Quote
Old 02-06-2007, 02:19 PM   #15
keaniegenie
Member#: 94494
2005 Element 92x
The EJ255 is an AVCS motor, right?
Are you eventually going with a larger turbo? It's obvious that AVCS does something even with small turbos, but the difference isn't as dramatic as a large turbo setup.
Old 02-06-2007, 11:43 PM   #16
thejean
Member#: 17763
I would like to go AVCS but I have been told to avoid the STI LB by someone very knowledgeable. I didn't get all the details but suffice it to say that the EMS I wanted to go with (autronic) can't do it. I have heard that the Hydra can but not sure what/if there are any issues. Everyone I ask doesn't seem to have a whole lot of input on the issue.
thejean is offline   Reply With Quote
Old 02-07-2007, 12:22 AM   #17
keaniegenie
Member#: 94494
2005 Element 92x
You're not asking the right people.
There is a buffet of stand alone's that can control variable cam timing. The Hydra is one of them. The main reason the Hydra is so popular with the Subie community is Phil Grabow of Element Tuning. His help and knowledge is priceless.
That said, if you have a question, ask him.
Old 02-07-2007, 02:21 AM   #18
thejean
Member#: 17763
Yeah, he told me that hydra can do it but all of the good tuners local to me use Autronic.
Old 02-07-2007, 02:40 AM   #19
just_a_wrx
Member#: 133116
04 WRX
Thanks for the informative writeup KG.
Can you please cc me on this PM
just_a_wrx is offline   Reply With Quote
Old 02-07-2007, 02:54 AM   #20
thejean
Member#: 17763
To follow up, I spoke to Ray Hall (Autronic developer) and here is his direct quote:
JC,
The 2.5L STI engine has different cam triggers. The current plug-in ECU does not support these. Others have fitted the 2L STi cam trigger wheels when doing this conversion.
Ray Hall.
Old 02-07-2007, 10:31 AM   #21
-auSTIn-
Member#: 91815
Kind of a n00b question here but...
If I already have an STi, but plan on switching to a stand alone EMS, will I loose AVCS if I choose something other than Hydra? Say like, AEM EMS?
Or is this something strictly for non-avcs motors to begin with?
-auSTIn- is offline   Reply With Quote
Old 02-07-2007, 10:34 AM   #22
keaniegenie
Member#: 94494
2005 Element 92x
AEM will not control avcs or your drive-by-wire system, so it's out of the question for you.
Old 02-07-2007, 11:00 AM   #23
-auSTIn-
Member#: 91815
Oh o.k. thanks for clarifying, I was not aware of that...
So Hydra is pretty much the best way to go in terms of stand alones for suby owners?
Old 02-07-2007, 01:11 PM   #24
SplatZ400
Member#: 84377
2011 335d
*subscribed* this will be good info in a month!
SplatZ400 is offline   Reply With Quote
Old 02-07-2007, 02:59 PM   #25
thejean
Member#: 17763
Either that, the Link, or one of the uber expensive units like Motec are the only options you have. Hydra you have good US support. Link is more for the easterners/southerners but can still be made to work just fine in the hands of someone who knows what they are doing.
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
Standard USDM WRX 2.0L or 2.5L swapped into RS coupe timman_24 Subaru Conversions 6 09-01-2008 09:59 AM
Load and Timing on 2.0L stage 2 WRXs... what you seeing? benw Open Source Reflashes 16 01-17-2008 12:59 AM
2.0L or 2.5L block, and also need '02 wagon rear spoiler cegpcola Private 'Wanted' Classifieds 4 12-26-2005 10:14 AM
1.6L to 2.0L Legacy GT Engine Swap The_Bang Normally Aspirated Powertrain 4 10-06-2005 10:55 PM
