Old 02-03-2007, 06:24 PM   #1
GAMO
Member#: 139657
Default Sourcing an oil leak in 97 Outback
I have a 1997 Legacy Outback with an oil leak that drips about once every couple minutes. I know where it's dripping from, but it's off of a hose that connects to the coolant; I would hope that blue coolant doesn't turn into oil magically due to gravity.
Could it be coming from the oil pan even though the leak isn't dripping from that area? Or is it possibly something bigger within the engine, maybe the oil pump?
GAMO is offline   Reply With Quote
Old 02-03-2007, 06:56 PM   #2
ivwarrior
Member#: 100610
MBP
Could be. Without a little better info, it's anyone's guess.
ivwarrior is offline   Reply With Quote
Old 02-04-2007, 11:14 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
the classic ej22 oil leak. My 97 impreza L had it. it was the front main seal though. They say that while your in there, just change out all the cam seals and the front main....basicly every seal inside the timing cover.
then you can rest asured knowing there isn't much left to leak
IllNastyImpreza is offline   Reply With Quote
oil leak in 97 1.8L bondkiller Normally Aspirated Powertrain 7 08-03-2006 11:31 AM
Help, got an oil leak, think i know how to fix it Depeche Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-10-2003 11:45 AM
WRX turbo in 97 Outback sport? Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-05-2003 01:29 PM
How do I locate the source of an oil leak? Rusty the Scoob Service & Maintenance 3 08-20-2002 09:06 AM
