Old 02-03-2007, 08:26 PM   #1
andrzejl
Member#: 139643
Default are models with 2.5 turbo engine affected by head gasket problem?
I do research before potential WRX purchase.
There is a lot of talk about head gasket leaks for naturaly aspirated 2.5 engines, but I have not heard turbo engines mentioned yet. Is there any evidence that models with 2.5 turbo (Legacy GT, Impreza, STI, Baja, etc.) engine are affected by this problem too?
Thx in advance ...
andrzejl is offline   Reply With Quote
Old 02-03-2007, 08:30 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No, and just because there is a problem with one model or line does not mean you need to freak out or ask about every Subaru evAr. There are no Subaru wide problems. The 02 models have weaker transmissions due to narrower gears, the 06+ models have weaker transmissions due to suckier final drive, and the 02 models have a fuel line problem in cold weather.
Old 02-03-2007, 08:52 PM   #3
andrzejl
Member#: 139643
well, I am asing with a reason - my both Outback and Impreza 2.5 TS 2002 with 94K and 103K miles respectively developed a external colant leak. I consider replacing one of them with WRX 06 and 07 model and want to be ensured Subaru fixed the gasket issue ...
Old 02-03-2007, 09:10 PM   #4
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
So many fellow trackwhores have had head gasket problems with STi's that they're buying old Honda track cars because they're so sick of trading them in every 2 years again.
Maybe Subaru thinks they've fixed the problem, but I'm not seeing that.
jack
Old 02-04-2007, 01:59 AM   #5
inchigeela
Member#: 62786
2007 WRX Sport Wagon
...and the 02 models have a fuel line problem in cold weather.
Of which I am reminded every day since the temp went to 1 deg. F this week and I never got around to having that fixed!
inchigeela is offline   Reply With Quote
Old 02-04-2007, 06:55 AM   #6
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
I've seen or heard nothing of this. How many is so many? 1? 2?
D fresh is offline   Reply With Quote
Old 02-04-2007, 07:15 AM   #7
krees23
Member#: 95154
2005 Subaru WRX STi
I've seen 2.5 Turbo engine gaskets start to have problems when the boost goes up to 22 or so PSI when the engine is stock.
krees23 is offline   Reply With Quote
Old 02-04-2007, 07:36 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
jack
some race cars, yes . but that's not your normally, daily driver now is it?
I'm not seeing it on the newer cars at all.
Old 02-04-2007, 09:52 AM   #9
Maccgyver
Member#: 137158
2004 WRX wagon
blobeyes for the win. Mine is in perfect working order thank you very much. But I maintain it to the T and never launch ever!!! No need to launch an awd drive car you can just let it go and then once you are rolling just floor it and take the hell off and the person next to you is left way in the dust.
Maccgyver is offline   Reply With Quote
2.5 non turbo compatible with 2.5 turbo Bradd06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-27-2009 04:42 PM
Sparkplugs for 2.5 turbo engines dntouch Service & Maintenance 1 03-11-2008 10:32 PM
FS: 2005 Legacy 2.5 Turbo engine complete! gt_drifter Engine/Power/Exhaust 68 11-30-2006 08:58 AM
Oil psi gauge install location on 2005 2.5 Turbo engine? BIGDLM Interior & Exterior Modification 2 10-16-2005 11:04 PM
Oil psi sending unit install location on 2.5 Turbo engine? BIGDLM Baja Forum 2 10-16-2005 04:14 PM
