Old 02-04-2007, 12:17 PM   #1
imprezaBlue
Member#: 40463
Talking gauge cluster color change question
is it the same process with Automatic also/?
i can't find any infor about it.
thanks.
imprezaBlue is offline   Reply With Quote
Old 02-04-2007, 03:40 PM   #2
silver-RS
Member#: 94447
2005 2.5RS
of coz it is...hah
silver-RS is offline   Reply With Quote
Old 02-04-2007, 03:43 PM   #3
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
yes, except you kinda have to leave the automatic selection window alone. it uses a different system of lighting, similar to the check engine and oil pressure warning lights- there are little compartments that light up individually. you can't change these colors without some serious electrical miniature soldering work.
but other than the gear selection indicator, it's the same.
i did it on my manual and i'd suggest you just not bother. it's not worth all the hassle and if you break something you're screwed.
Handsdown is offline   Reply With Quote
Old 02-04-2007, 04:00 PM   #4
silver-RS
Member#: 94447
2005 2.5RS
^^^ yea i agree with him...
if its as easy as changing a few bulbs then Yeah..
but the whole process is pretty complicated and time consuming
just buy the STI cluster if you like how it looks @ night
Old 02-05-2007, 03:58 PM   #5
Mechie3
Member#: 120152
2006 06 WRX, 86 FMOD
Blue, White/Red
I did mine (manual) and love the color. Then again, I spent 30 hours on it. After the first time I have managed to reduce that time significantly, but the method I used (search for my led/gel write up) is time consuming.
Mechie3 is offline   Reply With Quote
Old 02-05-2007, 05:57 PM   #6
imprezaBlue
Member#: 40463
wow. 30 hours... .. i thought it is 30 min job..
thank You for letting me know guys.
08+ Gauge Cluster Color Change wawawrx Interior & Exterior Modification 19 12-10-2009 04:05 PM
DIY gauge cluster color change. Who's happy with the results? bcWRX-02 Interior & Exterior Modification 37 04-15-2009 04:01 AM
gauge cluster color change?????? wrxtuner7 Electrical & Lighting 3 09-15-2008 03:12 PM
Lightwerkz Gauge Cluster Color Change Wind25RS Interior & Exterior Modification 0 11-26-2007 01:12 PM
05 STI gauge cluster color change Kuj_05STI Electrical & Lighting 2 11-13-2006 10:48 PM
Message Board Statistics All times are GMT -4. The time now is 08:23 PM.
