Old 02-04-2007, 04:08 PM   #1
drth_sti
Member#: 105616
05 STi
Exclamation My 05 STi keeps dying when I turn off the car
I have an 2005 STi with the following mods:
Yellow Top Optima battery
HKS Downpipe
K&N intake
Custom ground kit
V1 Cobb Accessport Stage 2
HID's
Audiovox in dash Dvd flipout
I have installed all these parts at least over 6 months ago and car has been absolutely fine and ran well. Now whenever I shut the car off I can't start it again without boosting the battery. And when I boost the battery it takes a good few seconds for it to turn over like it's struggling. It has been getting very cold here in michigan but it started this habbit before it got really cold. Last month when I started it it would turn on and would only seldom not start but now it doesn't start at all until I kickstart the battery with a emergency charger I bought. I'm definately sure however that there is NO power getting to the rest of the car as I kept the engine off and ran my fan and my fan slowly died out as if it was being drained of power.
Also, I don't drive very much since I moved to michigan from ontario maybe drive only 3-6 miles a day, but that should be enough for the alternator to generate enough energy to store in the battery right?
There is absolutely nothing draining the energy and I suspect it could be the alternator or the yellowtop battery which is practically new as I just got it last year winter and it was working fine then. Further, i'm just 3k over my recommended oil change but that shouldn't affect the battery right?
Please let me know what you think! Anything would be helpful.
drth_sti is offline   Reply With Quote
Old 02-04-2007, 04:19 PM   #2
dibblejr
Member#: 94070
05 LGT
Short distance drives kill batteries, you need to take your car out every now and then for a much longer drive. Compiled with the cold temps, not good.
Check you battery volts.
The oil change would have nothing to do with cranking unless your car has no oil in it.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-04-2007, 08:48 PM   #3
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
Although short drives are tough on a car, it is plenty of time torecharge the battery. If it doesnt recharge the battery enough to start the car after a 15 minute drive (aprox) then there is something wrong with your charging starting system. you either have a battery which wont take a charge, an alternator which wont give a charge (or maybe has a bad diode...in which case your alternator will charge with AC voltage, causing your battery to bubble over and slowly killing it) or a voltage draw on your system.
Given the info you wrote, I would first look at the batt/charge light on the dash. If it is off when the engine is running your alt is probably fine. The fact that you can jumpstart the car makes me suspicious of a bad battery or a draw. Use a voltmeter to check for draws(if you are in the ballpark of 50mA you are fine. Charge the batt for an extended period to see if it will take a charge.
Does the car start immediatly after shutting off? if if does, but wont start after a couple/few hours then you may have a draw...hard to diag without the correct tools. you may want to take it to a shop and ask for a complete starting charging and draw check. Should cost about a half hours labor or so.
Good luck,
Dominic
NWstiLTD is offline   Reply With Quote
Old 02-04-2007, 08:53 PM   #4
dibblejr
Member#: 94070
05 LGT
^^ I concurr, however if those short drives are at night you are loosing more power than you think. The OP said 6 miles one way, it doesnt take 15 minutes to drive 6 miles unless you are in a large city.
You are correct though in that it is very hard to diagnose electrical problems over the net. There are too many things that could be wrong without having wires and a tester in hand to check.
Autozone will diagnose your system for free (if I recall correctly).
JAy-R
Old 02-04-2007, 10:56 PM   #5
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Autozone is definitely the way to go for $0 diagnosis + point in the right direction. It does sound like the alternator, but a free check will let you know for sure.
surowrxa is offline   Reply With Quote
Old 02-05-2007, 04:36 AM   #6
caterpill
Member#: 27136
Check for a "Parasitic Drain".
Possibly an incorrect install of the DVD headunit that is causing the drain, but you'll need to double check. Maybe a relay used during the HID install was installed on the wrong circuit? Probably not, but probe around.
Lastly I would point the finger at faulty alternator diode(s), but they usually do not go bad so soon.
Connect an ammeter between your battery positive terminal and your car side positive terminal and start pulling fuses if the current draw is higher then ~30-50mA. When you pull a fuse and the current drops, the drain is within that circuit.
caterpill is offline   Reply With Quote
Lights flashing when I turn off the illumination ryanncully Interior & Exterior Modification 6 10-30-2009 04:23 PM
Whirring noise when turning off the car... mourron Newbies & FAQs 6 02-20-2009 06:25 AM
When I turn off the car, the radio and the clock stays on, whats wrong? WRXakaBooSTi Car Audio, Video & Security 2 09-18-2008 11:35 AM
CRAZY squeaking noiseover speed bumps and a little bit even when turning off the car! 04subyrex Brakes, Steering & Suspension 2 12-07-2007 09:26 PM
Gas b4 turn off the car ? Poo Vancouver Impreza Club Forum -- VIC 8 01-23-2004 12:38 AM
