Old 02-04-2007, 05:41 PM   #1
Brepic06
Member#: 138780
2007 FSXT
GRAY GRAY
Unhappy Power Steering grind
about a month after i got my car i noticed a grinding sound only happening when the wheel was at the full rotation....i brang it to subaru and it didn't happen but its still happens every so often......its a 06 2.5i and just wondering if anyone knows the solution or if they have the same problem
Brepic06 is offline   Reply With Quote
Old 02-04-2007, 08:46 PM   #2
Squeakywaffle
Member#: 101849
2006 Impreza 2.5i
I have a similar issue with my steering... I never hold it at full lock (i hear that's bad, lol) but every so often it seems to have something inside that starts to resonate and the wheel starts vibrating at high speed and the steering makes a sort of high pitched screaming noise. I have no idea what it is. I assume it's no big deal, because it's only happened like twice while not moving and once while moving. And it hasn't happened in a while.
Squeakywaffle is offline   Reply With Quote
Old 02-04-2007, 09:28 PM   #3
Brepic06
Member#: 138780
2007 FSXT
GRAY GRAY
mine isn't so much as a screaming noise but like....grinding like i don't have fluid but my fluid is fine...
AVO Turbo Inlet power steering issue mrfatride Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-18-2010 08:55 PM
steering grinding especially when turning at idle Sir Punk Brakes, Steering & Suspension 10 04-13-2010 11:24 AM
Power steering noise but maybe not the power steering pump.....? deathskrye Brakes, Steering & Suspension 5 08-29-2008 10:56 PM
Belts broke, now Power steering is grinding OhFourWhore Service & Maintenance 7 09-02-2006 07:09 AM
Power steering pump grinding? dru_hill Brakes, Steering & Suspension 7 06-13-2006 12:20 PM
