Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 11-30-2001, 12:15 AM   #1
scotto
Member#: 3635
2002 WRX Swagon
Platinum Silver
Default HVAC operating normally?
Is this normal:
With vent selector set at high/low and thermostat from cool to straight up, only heated air comes in at the lower vents - uppers are unheated. If the thermostat dial is turned past 12:00 oclock, clockwise then some heat begins to come out the upper vents. It does not matter what position the inside/outside lever is on.
This is also the case if the vent selector is just set at the upper vents (dash vents not window).
Anyone else notice this?
Scott
scotto is offline   Reply With Quote
another HVAC question...continuous fan operation? Neek Off-Topic 6 07-10-2009 03:22 PM
Normal Operating Range - EGT S-Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-10-2003 10:01 PM
What's normal operating temp? Egan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-09-2003 02:22 AM
Normal Oil Pressure Operating Range 63Alpine Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-07-2002 10:43 AM
Normal Operating Temperature? freq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-06-2002 02:29 PM
