Old 02-05-2007, 10:30 AM   #1
MAJRMSA
Member#: 22399
2002 wrx
250k mile high club
Default How to disable or remove a/c compressor?
Is there a way to disable the a/c compressor without removing it? Is it safe to run with the a/c compressor disabled or removed? Any helpful links on how to remove or disable the a/c compressor. Thanks
Roldan
MAJRMSA is offline   Reply With Quote
Old 02-05-2007, 10:52 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Depends on what your purpose is. If you just want the AC to never run, you really don't have to do anything. The compressor isn't engaged unless you either turn on the AC or use the defrost mode on the HVAC. At all other times the compressor clutch is disengaged and the pulley is freewheeling, with no load on the engine.
If you want to make absolutely certain it will never engage, you can just unplug the electrical connector that goes to the compressor clutch and that will be the end of it.
If you are looking to save weight for competition purposes, then you can physically remove the compressor along with the other accessible AC components, but you would first have to discharge the system.
Old 02-05-2007, 03:13 PM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Or you can remove the drive belt to the compressor.
Alan is offline   Reply With Quote
Anyone know how to disable or disconnect Factory STi alarm? mikecoscia Electrical & Lighting 1 11-26-2006 10:25 PM
How to Disable or Turn off the Day time Running light mop Electrical & Lighting 1 06-23-2006 06:16 PM
Mortar shell help! Or how to no-surgically remove a finger in thirty seconds or less! Hondaslayer Off-Topic 12 07-04-2004 11:10 PM
('93-'01) How to Disable the Air Bags malaki Impreza Forum 17 05-24-2001 10:09 AM
