Old 02-05-2007, 12:07 PM   #1
MKXIII
Member#: 130388
2007 WRX STI Limited
Urban Steel Gray Metallic
Default Stuck Clutch Pedal
this weekend i was driving to a friends house for the superbowl when the clutch pedal got stuck about halfway down....it wasn't so stuck that it wouldn't move...it was just stuck down half way that i had to stick my foot under it and pull it up...then i cycled it by pushing down leting go and so on...what should i do or check about this stuck clutch pedal problem?...by the way i have a 2007 limited sti.....and it has happened once or twice before....also i dont think it had anything to do with it but it was 2 degrees out side....help please
MK
MKXIII is offline   Reply With Quote
Old 02-05-2007, 12:22 PM   #2
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
What Happened When You Got It Unstuck? Did It Pop Back Up, Or Did It Lack The Pressure Needed To Pop Back Up?
kharris4 is offline   Reply With Quote
Old 02-05-2007, 05:06 PM   #3
MKXIII
Member#: 130388
it poped back up into its normal position....
Old 02-19-2007, 08:02 AM   #4
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I'm having the same issue in my '02 WRX Wagon right now.
edit: I bled the system A LOT. It feels like it's fixed now. I'll have to see if it happens again. If so there is a leak somewhere.
Jard is offline   Reply With Quote
Old 02-24-2007, 09:23 PM   #5
Sean LTD
Member#: 130439
2007 STi LTD
Urban Metallic Grey
My clutch became completely unresponsive when shifting from first to second. The grind was terrible. Pressing the peddal did nothing. I pulled over, turned off the car, started it again, and presto. It worked. I've grinded 2nd a few times since buying the car because it doesn't disengage all the way all the time. I'm taking it in after the weekend. Thought the problem was similar to yours. Keep us posted.
Sean LTD is offline   Reply With Quote
Old 02-25-2007, 11:05 AM   #6
noitseuq
Member#: 136439
i need legitimate post!
noitseuq is offline   Reply With Quote
Old 02-25-2007, 11:33 AM   #7
former3g
Member#: 58858
'10 EVO X GSR w/SSS
'15 Fiesta 1.0 Ecoboost
I had this problem once when it was cold out. I had it checked out at the stealership service shop and they “could not duplicate”
former3g is offline   Reply With Quote
Clutch pedal stuck to floor Change Transmission (AT/MT) & Driveline 30 10-13-2012 06:32 PM
Stuck Clutch Pedal MY98 ehime Forester Forum 4 08-10-2008 01:05 PM
Stuck clutch pedal in cold weather? ASpec818 Transmission (AT/MT) & Driveline 4 12-26-2007 08:30 PM
My leg gets stuck on a clutch pedal! *sigh* paulney Outback Forum 2 12-22-2005 04:26 AM
Clutch pedal keeps getting stuck to the floor. powerlabs Transmission (AT/MT) & Driveline 9 07-06-2005 10:12 PM
