Old 02-05-2007, 01:45 PM   #1
a1autosports
Member#: 73658
2002 Subaru WRX
GREEN
Default Punctured gas tank! need instructions on removal
It sounds stupid but I accidently mounted a stereo fuse box underneath my rear seat and I didn't know that I was actually drilling into part of the fuel tank! Now I have to remove it, reweld it and put it back on. Does anyone have ANY instructions on removing the ENTIRE fuel tank? Any help would be appreciated.
a1autosports is offline   Reply With Quote
Old 02-05-2007, 02:36 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Wow.. theres a first time for everything i guess!
You might need a shop manual, or to go to a mechanic or even a subaru dealer with your car. If your going to do it yourself you should see if there are instructions even general instructions on how to do this. There is significant risk if you do this wrong Im sure you know so do some research first. Sorry I cant help you bro.
paul
PaulRex is offline   Reply With Quote
Old 02-05-2007, 03:39 PM   #3
orndog
Member#: 34670
2013 No gears!
Saltine American
You accidentally mounted a fuse box?
Dude, take it somewhere and have it fixed. Do not attempt to weld a gas tank yourself unless you are trained in these things. Gas fumes go boom, kapisch?
orndog is offline   Reply With Quote
Old 02-05-2007, 04:08 PM   #4
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
Get a couple of quotes.
For fixing the tank by trained personnel or replacing it, again, by trained personnel.
Neither one of the above options are for the do it yourself guy, it is way harder and way, way more dangerous, than it sounds. The reason I say that is because I read the TSB for removing/replacing the gas tank for the MY05 Nissan Sentra, that I used to own, not the same as Subaru, but the difficult and dangerous issues still apply.
joecerv is offline   Reply With Quote
Old 02-06-2007, 02:03 AM   #5
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
This is not the end of the world really. I own a car dealership and have repaired 2 tanks like this in the last year. First remove fuel from the tank using a sciphon method. Second drop the tank. Third sand with hand sand paper around the hole. Fourth seal with a fuel resistant epoxy available at most major car part chains. Fith re-install tank. Trust me this SUCKS time wise but it does work. CB!
neighbor667 is offline   Reply With Quote
Old 02-06-2007, 09:22 AM   #6
ptirmal
Member#: 82243
07' Acura TL-S
JB weld ftw!
ptirmal is online now   Reply With Quote
Old 02-06-2007, 10:28 AM   #7
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You have to remove the rear diff among other things to change out the fuel tank- major PITA.
Brian
Old 02-10-2007, 12:09 AM   #8
a1autosports
Member#: 73658
2002 Subaru WRX
GREEN
Hmmm....the holes are less than a 1/8in in diamater and I can see them from right under the back seat, I wonder if I can squirt the fuel resistant epoxy right from there to fill the holes?
Old 02-10-2007, 03:26 PM   #9
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Or you could put small screws into the holes to seal them
Mike Wevrick is offline   Reply With Quote
Old 02-10-2007, 03:40 PM   #10
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Using a screw with some epoxy on the threads might be an acceptable repair. I think he might want to make a bigger hole (CAREFULLY) in the body so he can get the screw head to seal against the tank, and use a short (1/4 to 1/2") shoulder screw that would seat against the tank. With epoxy, a flat surface of the screw glued to the tank top, and glued screw threads it ought to be as good as needed - and very easy to do.
Alan is offline   Reply With Quote
Old 02-10-2007, 10:26 PM   #11
a1autosports
Member#: 73658
2002 Subaru WRX
GREEN
would getting this epoxy into the gasoline affect it at all?
Old 02-10-2007, 11:32 PM   #12
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
If you mean once the epoxy dries and hardens, will gasoline affect it - the answer is no. If you drop the mixed epoxy into the tank, I suppose it could be affected by the gasoline, and maybe little bits of it would find their way to the fuel filter. I'd recommend doing the repair with less than 3/4 tank of gas to be sure to not have gasoline wetting the top of the tank, and letting it cure for a couple of hours before driving. Just to be sure.
Old 02-11-2007, 12:38 AM   #13
a1autosports
Member#: 73658
2002 Subaru WRX
GREEN
thanx for the help! I love NASIOC
Instructions on removing front bumper on 05" STi Gecks Interior & Exterior Modification 0 07-23-2005 02:46 PM
Instructions on removing and installing starter. Dre2932 Normally Aspirated Powertrain 4 08-23-2004 08:29 PM
Need some specific instructions on removing turbo exhaust housing. lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-07-2004 01:56 PM
punctured gas tank jmcn New England Impreza Club Forum -- NESIC 4 01-07-2002 09:18 PM
Any instructions on removing heads? Eric SS Normally Aspirated Powertrain 4 08-21-2001 02:14 PM
