Old 02-05-2007, 03:31 PM   #1
SilverSpool
Member#: 55869
YOTA Taco
M796
Default Squeeling and whining A/C
when i turn the fans on.. with, and without the AC on, i hear a squeeling sound, when i look at it, it looks like it hardly wants to turn(ac compressor, sound coming from it as well)
and this is running the heater also
04 wrx, 63k miles, bone stock drivetrain..
any thoughts?
SilverSpool is offline   Reply With Quote
Old 02-06-2007, 12:09 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
dead or dying ac compressor would be my guess
you might want to get it in to a tech for the official say so....
Old 02-06-2007, 08:56 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
worn/loose belt?
Old 02-07-2007, 11:15 AM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Since it's free, check to see if your belt is loose or needs tightening. Here's a how-to:
http://forums.nasioc.com/forums/show...92&postcount=2
Hank3 is offline   Reply With Quote
Old 02-07-2007, 01:02 PM   #5
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Had the same noise. At first I was convinced it was the compressor but then realized it made the noise if the compressor wasn't on also.
Then thought it was the AC fan clutch because that is spinning whether or not it's engaged with the compressor.
I finally realized it was the AC pulley after snipping the belt. Pulley would barely turn by hand.
Edit : just to clarify, it's the A/C idler pulley (small pulley that supplies the tension on the belt located between the crank pulley and the AC pulley, AKA the tensioner pulley)
z is offline   Reply With Quote
Old 02-10-2007, 06:20 PM   #6
SilverSpool
Member#: 55869
YOTA Taco
M796
and the fix?
Old 02-13-2007, 03:03 AM   #7
z
Member#: 41762
04 STi
Sorry, been offline for a few days...If the said pulley is your problem, the fix is to replace the pulley. It's like $20 something.
Either loosen the tension on the belt so you can see if it spins freely, or do what I did, cut the belt off with scissors. I plan on replacing it when it warms up, too cold to be dealing with it now. Got rid of the noise though!
Old 02-13-2007, 03:21 AM   #8
z
Member#: 41762
04 STi
Number 13 is what was causing my noise. It was pretty much an all the time type noise, with or without the AC on, because that belt is always spinning.
http://www.subarupartsforyou.com/cp_...hp?partid=5483
edit - sorry jamie, couldn't find it on your site.
Old 03-10-2007, 01:17 AM   #9
MrWhite
Member#: 80123
I had this same problem with my A/C compressor. Basically what is happening, is that the oil inside your A/C lines have leaked out of your main seal and has gotten onto the clutch surface of your compressor. The oil as well as an uneven clutch surface was causing major slippage. If this is your problem here's how I fixed the problem of course depending on how mechanically proficient you are:
1) Take allen key and remove clutch pack. You might have to pry a little bit with a screwdriver. You'll need to just work it off as gently as possible. Just try not to bend it.
2) Look at the metal clutch contact surface and look for black crap. You'll need to wipe this off.
3) Take a bastard file, and with the engine running, hold the file against the clutch surface to refinish the surface nice and smooth.
4) Next, take the clutch pack and try to resurface this area as best as possible.
5) Reassemble
You're basically trying to make the contact surface between the metal as smooth as possible. Feel free to PM me if you have further questions.
MrWhite is offline   Reply With Quote
Old 03-16-2007, 02:29 PM   #10
SilverSpool
Member#: 55869
YOTA Taco
M796
the pulley doesnt even turn anymore.. the belt just slips... AC compressor pulley
Old 03-16-2007, 02:57 PM   #11
SilverSpool
Member#: 55869
YOTA Taco
M796
i took the clutch off, the pulley turns fine, but the clutch and the shaft its connected to, to the AC compressor doesnt turn, is my AC compressor toast?
Old 03-16-2007, 03:48 PM   #12
avk
Member#: 17252
'06 WX8
59E
It should be possible to turn the compressor by hand, grasping the cluch hub. If it doesn't budge at all, it must be seized.
avk is offline   Reply With Quote
Old 03-16-2007, 04:05 PM   #13
SilverSpool
Member#: 55869
YOTA Taco
M796
yea, its stuck, wont turn by hand
Old 03-17-2007, 03:16 AM   #14
SilverSpool
Member#: 55869
YOTA Taco
M796
will a JDM v7 STI AC compressor fit in my 04 wrx?
Old 05-04-2007, 01:47 PM   #15
initial_D
Member#: 81864
I’m currently having the same problem.
When the ac is turned on, a get a screeching noise as the accessories belt tries to turn the AC compressor but can't.
I guess I will check the belt first to make sure it’s not loose. Then the clutch and finally the AC compressor.
Does anyone have instruction on how to properly replace the AC compressor?
Thanks.
initial_D is offline   Reply With Quote
Old 05-21-2007, 10:26 AM   #16
KKoepp31
Member#: 13544
2011 ML550
I just found this weekend that the tensioner pulley had fallen apart. The bearing was still attached to the bracket, but the pulley itself was nowhere to be found. The belt was down to just a sliver left, so I snipped it and got it out of the way until the new part shows up. I was worried my compressor had died, but it still spins, so I don't think that is what caused the failure.
KKoepp31 is offline   Reply With Quote
Old 05-23-2007, 12:16 PM   #17
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Have a Nice Day?
More like $40 at my local dealer...
Coati is offline   Reply With Quote
Old 05-23-2007, 12:20 PM   #18
z
Member#: 41762
04 STi
$29 for online subi parts dealers...http://www.subarupartsforyou.com/cp_...hp?partid=5483
2 dealers local to me had the part in stock, both for $33 (list price)
concordville subaru and delaware subaru.
Matt Slap Subaru tried to gouge me for $41 too though.
Belts squeeling and wierd noise? bigolrig Newbies & FAQs 13 02-03-2010 07:28 PM
After belt change PS pump squeels and a wobbly wheel. Midnightsilence Brakes, Steering & Suspension 8 03-23-2009 02:59 AM
A/c causes squeel and I smell RUBBER....help needed pls. ILSMKU2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-08-2005 03:00 AM
WRX Rumble and Whine j0k3r Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-24-2002 08:22 PM
Clunks, creaks, rattles and whines... AWDriver Technical Forum Archive 3 05-30-2000 10:30 AM
