Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 02-05-2007, 06:29 PM   #1
_sti_05
Member#: 72313
16 STi
Default Anyone in the TXIC, running 245/45/17 on stock suspension?
looking to get new tires, any opinions?
_sti_05 is offline   Reply With Quote
Old 02-05-2007, 06:30 PM   #2
prototypeWRX
Member#: 78739
2015 WRX
I think javwrx is running that(or larger) on his 05 STI lowered on Tien springs. Should fit stock springs fine since they're higher than the dropped ones.
prototypeWRX is offline   Reply With Quote
Old 02-05-2007, 06:37 PM   #3
aschen
Member#: 30733
2007 tiny car
striped
you will have no probs at all on an 05 sti unless you have weird offset wheels.
aschen is offline   Reply With Quote
Old 02-05-2007, 06:39 PM   #4
_sti_05
Member#: 72313
16 STi
i have the rota torques. I believe the offset is 48
Old 02-05-2007, 06:40 PM   #5
_sti_05
Member#: 72313
16 STi
There shouldn't be any rubbing issues on turns right?
Old 02-05-2007, 07:02 PM   #6
jamesohoh7
Member#: 39070
GTF off my lawn!
Correct, should be no rubbing. I ran 245/45/17 Falken 615's on a set of Rota Torques all last year for autox, which surely puts more demands on tire clearance than daily-driving, and I had zero rubbing issues. My car is roughly at stock ride height (Espelir GT springs + camber plates in front, stock springs in rear). The tiny drop the GT's give is eaten up by the stack-height of the camber plates in front... hence I say my car is still basically stock height.
I currently run 17x9 e45 rims with 245/40/17 Neovas for autox, which is quite a bit wider setup and still no rubbing. A WRX or 04 STi would probably need to roll the rear fender though to run that setup.
jamesohoh7 is offline   Reply With Quote
Old 02-05-2007, 08:17 PM   #7
_sti_05
Member#: 72313
16 STi
nice, thanks for all the great info guys.
Old 02-05-2007, 10:34 PM   #8
Davidss
Member#: 27446
I've seen 275s on stock springs on an 05 sti, this was for competition not on the street though...
Davidss is offline   Reply With Quote
Old 02-06-2007, 08:26 AM   #9
jamesohoh7
Member#: 39070
GTF off my lawn!
Yep... if pics of this past Sunday's afternoon autox run-group get posted, there should be some of Martin's car... running AS on 275's Kumho V710s that are stuffed on to some Rota Torques. I am not sure what (if any) spacers might be in there, I think none, but Martin can weigh in.
Nice 'location' you have there ... Mooninites, FTW!
Old 02-06-2007, 08:48 AM   #10
LiquidIQ
Member#: 6408
2014 FiST 2004 MSM
Race Red & Velocity Red
I run 245/40/17 on my LGT on 17x8 Torques. Stock height it was fine, even now dropped on coilovers. I had a tiny bit of rub in the back when I had some super low springs on, but only when I was hauling people on big bumps.
LiquidIQ is offline   Reply With Quote
Old 02-06-2007, 11:56 AM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
There were no spacers, it may have rubbed the strut in the rear if he used the stock rims. We did rub the front fender liner but it was pretty minimal. For some reason when I would drive a miniscule portion of the right rear would rub on the fender but it was nothing to be concerned about. Suspension was not completely stock though, he has a whiteline fsb.
afpdl is offline   Reply With Quote
245/45/17 on stock sti rim Alpha_32 Tire & Wheel 27 06-25-2010 02:07 PM
Anybody run 235/45/17 on stock 09 wrx wheels? WRX_Convert Tire & Wheel 1 11-22-2009 09:53 PM
245/40/17 on stock suspension? sssp Tire & Wheel 2 08-14-2007 12:31 PM
245/45/17 on stock 2004 sti ? rapidus Tire & Wheel 16 03-30-2006 12:10 PM
what tire pressure for s03's...225/45/17 on stock suspension?? wrxxtc Brakes, Steering & Suspension 10 03-22-2002 11:05 AM
