02-05-2007, 06:39 PM | #1 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
GC/GF transmission strength
For those of you with swapped L's and maybe RS's (if they use the same tranny)
And are using a WRX or STi motor, how have they held up?
02-05-2007, 06:43 PM | #2 |
Member#: 21764
RMIC
Vehicle:Some GDM V8, JDM Flat 4 X2 |
What do you meen by GC GF, usdm? jdm?
The jdm 5spd is quite a good transmition, but like everything else if you abuse it, it will break. The stock 1.8 and 2.2 tranny's are not as strong, but will hold up to the power as long as there is no 5K clutch drops or hard shifting. Kirill |
02-05-2007, 06:59 PM | #3 |
Member#: 132130
TXIC
i meant the stock transmissions on the mid 90s imprezas (obs,L,etc) i guess USDM..dont really plan on making the car i want to get "JDM"
sorry i wasnt clear enough |
02-05-2007, 07:57 PM | #4 |
Member#: 109828
Vehicle:03 WRX wagon Sonic Yellow |
I'm also wondering this...Since I basically learned how to drive manual on my 95 L I've ground the gears a few times (>_<) I was just curious how much unintentional abuse can they take?
02-05-2007, 08:03 PM | #5 |
Member#: 80663
SWIC
Vehicle:2005 STi |
My guess is not very well. Reason I say this, is that the previous owner of my current Legacy went through 2 or 3 stock trannies with his 12-14 psi 16g setup (power levels about like a very lightly modded WRX). This was on stock Legacy turbo trannies, which I would imagine are as strong or stronger than that of a GC8.
02-05-2007, 09:35 PM | #6 |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
Mine has held up just fine after 70k miles w/ stock engine, doing auto-x's, track stuff, etc.
And its still good as new after roughly 15k on the stage 2 wrx setup. I'm relatively easy on transmissions and clutches. |
02-05-2007, 09:58 PM | #7 |
Member#: 132130
TXIC
well if i were to get a brighton and do a wrx swap its not like id be doing burn outs with it
just some accelerated cornering when no one else is around.. ..and some spirited driving, no 5K rpm clutch drops or nothing. |
02-05-2007, 10:29 PM | #8 |
Member#: 77106
South East
Vehicle:'02 Brodozer '11 Outback 3.6R |
It all depends on how you drive it.
Bang the gears and launch it all the time, and it'll break, no doubt. Slip the clutch, and take it easy on shifting, and it should last a long time. The 5-speed just can't deal with shock to the gears. It can hold steadily applied power, but can't be slammed on a regular basis. If you're gonna do that, get a 6-speed.... |
02-05-2007, 10:45 PM | #9 |
Member#: 111735
Vehicle:97 Impreza L Rust and White |
the key to a surviving tranny is a gentle clutch. I went 13.4 on the stock L tranny. Lauched at 6k when I was at the track and really banged the gears.
02-05-2007, 11:12 PM | #10 |
Member#: 132130
TXIC
hey turboL, you're the dude with the turbo'd 1.8L coupe right? how much hp are u getting out of it?
02-06-2007, 01:46 AM | #11 |
Member#: 79798
The RS tranny should be fine with a WRX motor. The L tranny might not be such a good idea tho. If you go easy on the L tranny you should be ok for a while but count on it failing.
cheers garrett |
02-06-2007, 01:01 PM | #12 |
Member#: 132130
TXIC
whats the difference between the RS and L transmissions?
some of the newer Outbacks and legacys use the 2.5 engine and im assuming they are similar if not the same to the L's |
02-06-2007, 03:54 PM | #13 |
Member#: 2780
Vehicle:junk yards rule! Project FrankenSTien |
I swapped a 2.2 legacy turbo motor into a Brighton and used the 5MT. I had to change the clutch because it couldn't handle the torque, but otherwise it was fine.
It got replaced 2 years later when the main bearing was going out. |
02-06-2007, 07:53 PM | #14 |
Member#: 43044
Vehicle:01 sedona red ej20 stage 3 vf23 rs |
my rs tranny is holding up fine with my swap. im running cobb AP stage2 and exedy street clutch. i dont launch and i dont bang gears. i know a few people that drive harder on the rs tranny then i do and they have been holding up too. kyle
02-07-2007, 04:51 AM | #15 |
Member#: 107569
NWIC
Vehicle:1998 Forester S SRP |
2nd gear burn outs on the stock rs tranny. not from dumping the clutch just from power. I think the shock is the worst for them so don't drop the clutch at 7k.
p.s. the gt4088r goes on next week. we will see what the tranny can really take. |
02-07-2007, 04:06 PM | #16 |
Member#: 63977
NESIC
Vehicle:2005 STi WRB |
I've got about 4k on my stage 2 wrx swap in my brighton and the brighton tranny is holding up just fine.
02-07-2007, 05:18 PM | #17 |
Member#: 99614
Vehicle:12 STi Limited Black |
So you're going to run an sti engine with a gt40r with the stock rs trans? Good luck picking up the pieces of the trans off the road..
02-13-2007, 08:38 PM | #18 |
Member#: 68120
Vehicle:1998 RS 2.0 vf23 STi & MK6 GTI |
My 98RS trans didnt last too long after my EJ257 hybrid and it was only on wastegate boost. Second gear decided to it had had enough. I havent had the car too long though, it had no motor when I bought it. Owner said it spun a bearing, so maybe it wasnt completely my fault. Car only had 94k when the motor went. Think the previous owner was pretty rough on it. Through a stocker back in it last november and Ive been pretty easy on it till i can build up the original.
02-14-2007, 08:52 PM | #19 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I'm on a '00 RS tranny w/ my EJ22T swap in my '99 Impreza L Wagon. We'll see how it goes.... I don't bang into gears, I just make the shift a smooth quick flow. I only do this because I've had experience with driving the tranny different ways. Rush it and it won't feel too good. I'll be looking into the Outback XT tranny, or the FXT tranny. If there's a JDM 6spd for a good price and condition, I'd take that. |
02-14-2007, 09:14 PM | #20 |
Member#: 107569
NWIC
No I'm saying I have been running the stock RS tranny for over a year now with the ej257 and a gt35r .82ex. Now I'm putting a gt4088r on! If I do break the tranny it will be at the track. but I hope I can get a few more good passes out of it before then.
02-14-2007, 09:43 PM | #21 |
Member#: 79798
lol. It's all in the wrist huh?
cheers garrett |
02-14-2007, 10:24 PM | #22 |
Member#: 3687
02-18-2007, 06:20 AM | #23 |
Member#: 25324
Vehicle:2016 WRX Dark Gray Metallic |
Some people get away with it, and they claim all you have to do is shift properly, but I suspect there's a lot of luck involved, too. So, you can try it, but don't do it unless you can afford to replace the tranny, too. It's pretty common.
02-18-2007, 04:37 PM | #24 | |
Member#: 132130
TXIC
Perhaps..when/if I get the car its going to be a side project and not a daily driver but I still prefer something reliable then not (who doesnt? lol) I dont really plan on doing 5K launches, just occasional spirited driving and hopefully track days in the future and basically a cool car to drive around in, not that my OBS isnt cool, i like the sedan/coupe alot |
transmission strength | crsect | Texas Impreza Club Forum -- TXIC | 12 | 03-07-2007 12:01 AM |
06 Wrx transmission strength | ScottC | Transmission (AT/MT) & Driveline | 9 | 03-29-2006 08:34 PM |
WRX Transmission Strength | MISTEROBOTTO | Transmission (AT/MT) & Driveline | 23 | 11-08-2002 09:59 AM |
Further Transmission strength debate | goose | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-09-2001 11:50 PM |
