Old 02-06-2007, 04:15 PM   #1
v8what
Member#: 69979
Default o2 Sensor always shows "NOT READY"
I have an 02 wrx and i've driven about 200 miles but for some reason my o2 monitor always shows not ready. I dont get it. I've been up and down the highway for miles, stop and go for two weeks. Monitor just wont set. I even bought an OBDII scanner and no pending codes or nothing. Anybody had this problem?? I need to pass my emissions.
v8what is offline   Reply With Quote
Old 02-06-2007, 04:30 PM   #2
UM-WRXer
Member#: 44623
did you buy the car new or used? If used, the previous owner probably wired in a electrical fix to trick the rear o2 sensor so it doesnt throw a CEL for lack of cat(s). Do you have an exhaust on the car? Catless?
If so:
Search mechanical o2 fix to solve problem. You will have to crawl under the car, remove the rear o2 sensor, and pull off the resistors. Then apply the mechanical fix.
If the car is new, go to the dealer and have them take care of it.
UM-WRXer is offline   Reply With Quote
Old 02-06-2007, 04:42 PM   #3
v8what
Member#: 69979
I bought the car new and yes I have the electrical fix. But I passed last year no problems.
I know whats needed to be done to set the EVAP. I can reset and get it done in under 20 miles. But I cant figure out what drive cycle needs to take place to get the o2 sensors to start.
Old 02-06-2007, 06:13 PM   #4
UM-WRXer
Member#: 44623
something like 200 miles to cycle the o2 sensors. Get rid of the electrical fix and do the mechanical. Then you wont ever have to worry about the rear o2 ever again.
Do what you want but it seems like a no brainer to me, the mech fix cost like 8bucks.
Old 02-06-2007, 07:25 PM   #5
v8what
Member#: 69979
Well..... I just drove to the store and for the hell of it put in the obd scanner and thank God it finally says ready!!
Thanks for your reply though
300 miles driven and ECU still "NOT READY" rage557 General Community 6 09-23-2008 11:59 AM
Inspections and "Not Ready" codes Brock31 Open Source Reflashes 9 12-29-2007 07:57 PM
Failed Inspection for monitors "Not Ready" TheMainFrame Service & Maintenance 20 10-26-2007 11:15 PM
Blinking CEL and OBD-II "NOT READY" rjp Engine Management & Tuning 4 03-09-2005 12:00 PM
I/M Monitor O2 "Not Ready" for how long? z&cobb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2002 10:32 AM
