Old 02-06-2007, 05:29 PM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Lightbulb perrin electronic boost control solenoid
Is this a direct replacement for the factory one? I know I ask alot of questions on here but thats the only way you learn ive researched this for a week without any luck on finding my answer maybe someone can help.
fastlanerex is offline   Reply With Quote
Old 02-06-2007, 05:43 PM   #2
jcl
Member#: 132215
06 Mitsubishi Evo
Wicked White
Yes and no.
Yes it connects right up.
No you cannot just drive on it and will need a retune.
jcl is offline   Reply With Quote
Old 02-06-2007, 05:44 PM   #3
fastlanerex
Member#: 133391
2004 boosted saleen
white
So i gotta an apv2 I need another protune?
Old 02-06-2007, 05:59 PM   #4
bluestonepath
Member#: 123641
'04 WRX Wagon
Platinum Dirty Metallic
Before you get a protune ask your tuner what they like to work with.
-cw
bluestonepath is offline   Reply With Quote
Old 02-06-2007, 09:18 PM   #5
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
You'll need some sort of EM, I have the Prodrive solenoid and tuned the boost myself with UTEC.
firebox40dash5 is offline   Reply With Quote
Old 02-06-2007, 09:31 PM   #6
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Again ask your tuner but you can get the GM BCS for much less $$ and it does the same thing as the Perrin, ie. works in interupt mode vs. bleed mode for the stocker.
blkscooby is offline   Reply With Quote
Old 02-06-2007, 09:35 PM   #7
fastlanerex
Member#: 133391
2004 boosted saleen
white
Any good tuners around delaware/maryland/pennsylvania?
Old 02-06-2007, 10:22 PM   #8
stil2stock
Member#: 51870
06 STI
isnt TurboXS in maryland?
stil2stock is offline   Reply With Quote
Old 02-06-2007, 11:15 PM   #9
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Yes they are, as is Agile, and I'm sure there's a few others too.
Old 02-07-2007, 12:04 AM   #10
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
My Perrin EBCS is setup using "fast response" which doesn't use a restrictor pill. I did this because it is what my tuner prefers. However, some tuners will want you to set it up using "slow response". Its all a matter of tuner's preference.
BTW, you can usually find a used Perrin EBCS for really cheap in the For Sale forum.
D-Speed 2.5 is offline   Reply With Quote
Old 02-07-2007, 08:15 AM   #11
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Accessport is just a flasher with base maps. You can have it protuned to any combination of upgrades etc.But yea, if you'll be adding upgrades that are out of cobb's map's reach, then you'll be needing pro tuning.
Assassin4457 is offline   Reply With Quote
Old 02-07-2007, 05:18 PM   #12
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Visit the Mid-A forum. Every tuner and AWD dyno is contained in the sticky threads. Research more as well. You don't just go swapping the BCS willy-nilly because others have. You can swap it out to the latest whiz bang BCS and it will still net you 0HP over the stock one. This is something to discuss with your tuner NOT us. As well, there are many different ways to control boost that you need to discuss with your tuner IF you need those measures. Read my Boost Control FAQ if you need a good starter.
FS:NY Perrin EBCS--Electronic Boost Control Solenoid singincanary Engine/Power/Exhaust 6 12-04-2008 08:35 PM
Perrin Electronic boost Control solenoid bmxpunk Engine/Power/Exhaust 1 12-18-2007 02:24 PM
FS: Perrin Electronic boost control solenoid Surfer Steve Engine/Power/Exhaust 5 12-01-2007 11:49 AM
Perrin EBCS Electronic Boost Control Solenoid ejh25 Engine/Power/Exhaust 5 09-24-2007 11:47 PM
