Old 11-30-2001, 01:43 PM   #1
RaceCarRiot
Member#: 6542
1997 Ver IV
Default constant burning smell = cat going bad?
argh. i don't know what it is, but i smell it every time i drive my car! it's just this hot, burning smell, and it comes through the vents at a stoplight. it smells almost like burning rubber, but not quite...
i'm a shade under 100K mi, so...?
-adam-
RaceCarRiot is offline   Reply With Quote
Old 11-30-2001, 01:56 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
are you sure there's not a plastic bag caught ont he tailpipe or driveshaft hitting hte exhaust as it goes around?? Look for animals as well......no matter how odd i've seen it.
jeremy
Old 11-30-2001, 03:03 PM   #3
fabulous12
Member#: 6831
98 impreza 2.5RS
black
I had the same problem a few months ago... turns out i had a small crack in the oil pump and oil was dripping onto the belts... I had to have the oil pump and the belts replaced... Cost somewhere around 400 for parts and labor.
fabulous12 is offline   Reply With Quote
Old 11-30-2001, 03:04 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I am getting the same thing, but could be a separate problem. It happened after I put the new pulleys/belts on. It smells of a burning belt, but I can't see any visible smoke. Also, my A/C won't blow any cold air. I never have heard any squeeling from the belts, and they are tight on the pulleys. Could this be the same problem?
Charlie
wcbjr is offline   Reply With Quote
Old 11-30-2001, 04:43 PM   #5
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Could be a common ailment. Small oil leak dripping onto hot exhaust. Not enough to cause billowing smoke or big oil spots under the car, but enough to be annoying. Lived with it for years in my Gen1 Legacy! Crawl under and have a look.
Glenn O
nuburu2 is offline   Reply With Quote
Old 11-30-2001, 05:39 PM   #6
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
My car had a nasty smell a few months ago. Turns out it was the plastic bag melting to the cat syndrome. You might want to check it out too.
iodine23 is offline   Reply With Quote
Old 11-30-2001, 09:36 PM   #7
Drift Freak
Member#: 6447
2001 Impreza RS
Every time I go on gravel or dirt, the dust cakes up on my cat. and smells like burnt toast!
Drift Freak is offline   Reply With Quote
Old 12-02-2001, 11:51 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
peek under your car.. near the cat.. see if something, fluid is dripping onto the exhaust/cat and burning off...
it's very likely axle or gear oil.
the axle seals are not the best on the Subaru and will be covered under warranty...
i had the seal replaced and axle grease swapped out on my 99 GT....
and just last week the inner seal on my 2001 RS was no good and gear oil was leaking everywhere....
both replaced under warranty...
good indication of this is the "burning smell" that you get...
hope this helps.
regards,
Jamie
www.subiegal.com
Possible burning smell from the cat...? ZACKARU Newbies & FAQs 10 03-03-2007 06:56 PM
Cat going bad? helievacpilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-28-2006 03:05 PM
Need input please, car made bad burning smell ThermalFlow General Community 6 10-12-2004 08:10 PM
clutch burn smell, good or bad?? IMPEXRALLY Newbies & FAQs 6 04-30-2003 11:05 PM
burning smell when going 65mph or above NYCshopper Normally Aspirated Powertrain 16 10-18-2001 02:31 PM
