Old 02-07-2007, 03:32 PM   #1
Dakken
Member#: 24570
wrx [email protected] 1/4
1.72 best 60ft
Default Overheating after Turbo-reinstall
Problem: Overheating
Experience: working on subi's for a few years now as a hobby (not a paid mechanic)
Story: I had a major oil leak from the oil line on the bottom of my VF39.. I installed it 6months ago, but somehow (perhaps the cold) it just recently started leaking oil last week.. Heavy (As in, a quart a day..all over the bottom of my car..whatever.) I removed the turbo, confirmed the problem, reinstalled the turbo properly (after much work in a freezing garage) and tightened everything down correctly. Refilled the oil, but not the coolant.. Forgot that.. But remembered about 2minutes of very very easy driving. Pulled over, happened to have a bottle of water in the car, so I added that (plenty, perhaps more then enough, but I figured it would just spray the excess out in that case) While driving to the auto parts store to pick up antifreeze and another quart of oil just in case, the car started overheating pretty bad. The car wasnt even warmed up enough for the heat to work (Or is this related to the problem?)
Again.. the fluids are all topped off, everything is reinstalled correctly and there are no pinched lines.
Ideas?
I've only come up with..thermostat.. clog in a line somewhere.. or maybe some other freak problem. I need to get this fixed by tonite, so this is semi urgent. Any takers?
Thanks
Scott
Dakken is offline   Reply With Quote
Old 02-07-2007, 03:35 PM   #2
hondaeater69
Member#: 60324
did you properly burb the system? that's my bet.
Old 02-07-2007, 03:38 PM   #3
Dakken
Member#: 24570
1.72 best 60ft
I didnt.. good call. I don't even know how to do that, I've never had to haha is it just opening up the tank and resivoir and keep adding fluid til its full?
Old 02-07-2007, 03:55 PM   #4
hondaeater69
Member#: 60324
pretty much. i believe you are supposed to do it from the highest point, which would be the overflow tank coming off the turbo. basically open tank (with engine cold), let car heat up, continue to allow coolant to circulate and fill as needed.
Old 02-07-2007, 04:04 PM   #5
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
i believe repeated revving opens up the system and allows any air that's trapped to be burped out, but my experience is in motorycles...i'm assuming that the cooling systems are pretty much identical.
Tahoe SC is offline   Reply With Quote
Old 02-07-2007, 07:54 PM   #6
Dakken
Member#: 24570
1.72 best 60ft
It's a little cold out to be doin this now, so I'm going to have to wake up early before work tomorrow. Definatly going to burp it up..Any other ideas?
Thanks!
Old 02-07-2007, 08:27 PM   #7
tdxflex
Member#: 13634
I run the engine without the pressure cap until the thermostat opens. Usually one cycle gets rid of all the trapped air. You may get some overflow so either put a funnel at the top or have rags ready.
tdxflex is offline   Reply With Quote
Old 02-07-2007, 08:30 PM   #8
bergs
Member#: 124376
turn the heat knob to HOT to open the entire system
bergs is offline   Reply With Quote
Old 02-08-2007, 08:29 AM   #9
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
From another thread...
Originally Posted by dibblejr View Post
The Owners Manual has all the answers but I will help you. This is the only PROPPER METHOD to add coolant and purge air from the system
AT NO TIME OPEN THE RADIATOR CAP
Use propper 50/50 mix for all coolant resevoirs.
1) Fill the coolant resevoir (plastic bottle) to the fill line (put cap on)
2) Fill the Turbo Coolant Reevoir (small metal right in front of turbo) (put cap on)
3) Start car and turn on heater (high)
4) Hold RPM's at 3000 for 10 minutes ( even if temp = H)
5) Turn engine off and leave key to ACC (keep heater on)
6) Let engine cool to "C"
7) Repeat steps 1-6 until no coolant is required to fill resevoirs
While replacing my turbo took 45 minutes to complete the process.
Like I said above DO NOT open radiator cap at anytime, to do so will negate everything you are trying to do.
Any other ways mentioned to burp the system on our cars are Shade Tree Mechanics.
Jay-R
ptirmal is offline   Reply With Quote
Old 02-09-2007, 11:21 AM   #10
Dakken
Member#: 24570
1.72 best 60ft
Update:
Burped a ton of coolant into the system. It must have been low before.. doh.
Not overheating while driving, but sometimes it comes up while stopped and the heat isnt very hot anymore. Thermo stuck open?
Overheating after turbo install Mekks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-14-2009 09:00 AM
car overheating after turbo swap noonagon Newbies & FAQs 11 03-14-2009 08:35 AM
after motor reinstall, no fuel pressure, no start. help me diagnose! jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 74 11-04-2005 01:36 AM
Overheating after turbo install sKOOTeR WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-13-2005 02:46 PM
Help!! Car Overheating after turbo install! bcristea Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-07-2004 01:04 PM
