Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 02-07-2007, 09:28 PM   #1
greenhand
Member#: 97677
1998 Impreza 2.5 RS
Question 1998 2.5RS Headgasket Repair...What else?
Has 141,000 on it. I'm going to do the repair myself, what parts should I replace while I'm in there? What should my shopping list look like?
1. Subaru Overhaul Gasket Set
2. Timing Belt?
3. Water Pump?
4.?
If anyone has experience or useful advise, I'd greatly appreciate it.
Thanks Again,
Seth
greenhand is offline   Reply With Quote
Old 02-07-2007, 09:49 PM   #2
shaggie
Member#: 36022
2000 08 OBS
Silverthorn Metallic
a good calibrated torque wrench
and a service manual.
shaggie is offline   Reply With Quote
Old 02-07-2007, 10:01 PM   #3
kwh29
Member#: 22100
I'm in process of doing the same, and already have the manual and tq wrench. Any suggestions on things I should do? I've got a shop freshening the heads and am going to replace the knock sensor as well just for security, since the compression ratio will bump up a touch.
Probably also going to replace the idler pulleys and timing belt - the water pump was replaced fairly recently. The clutch and PP are almost new too.
Can anyone suggest something else? I was considering bypassing the water heating on the throttle body when I put it back together. Any pros/cons on that?
--Kevin H.
kwh29 is offline   Reply With Quote
Old 02-07-2007, 10:23 PM   #4
redwagon
Member#: 2181
2008 SpecB
Delta reground cams!
redwagon is offline   Reply With Quote
Old 02-08-2007, 09:05 AM   #5
8Complex
Member#: 922
04 FXT
Red
Depends what else has been done at that mileage. I would expect a timing belt and maybe water pump to be up there if it hasn't been done in the last half of the cars' life. More than likely a good check over the rest of the hoses/wiring to see if anything is degrading, and possibly even a coolant/radiator flush.
Old 02-08-2007, 09:47 AM   #6
Mike1967
Member#: 87762
If you are sending the heads into a machine shop then I would recommend getting a valve job done. Cost should be under $200.00 for resurfacing and replacing the oil seals....and they will also check the springs, seats, valves, guides etc. to insure everything is working properly.
remove the oilpump and check the backing plate for loose screws.
Replace the oilpump O-Ring
Possibly a new tensioner if it has never been replaced.
Replace the rear plastic plate (oil separator plate) with aluminum plate
Set the Valve Lash on all 16 rockers (after you put the timing belt back on.)
Since you are already buying the head gaskets....you might want to consider buying the overhaul gasket set if have not recently already replaced the rear main seal and oil pump O-Ring.
IF you buy the overhaul gasket set then:
Front Crank Seal
CAM Seals
REAR MAIN SEAL
Valve Cover gaskets
Front cover gasket
(And many other misc seals/gaskets)
Mike1967 is offline   Reply With Quote
Old 02-08-2007, 09:48 AM   #7
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Don't forget the multi-faceted head bolt socket. Anybody know what it's called?
Old 02-08-2007, 01:23 PM   #8
8Complex
Member#: 922
04 FXT
Red
The 12 point socket that is for a 14mm hex?
Old 02-08-2007, 02:12 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Idler pulleys and knock sensor seem like kind of random things to replace. I guess it can't hurt to replace either of them, it just seems like two things that really don't need to be on one's preventive maintenance list. I don't think I've ever seen anyone here complaining about an idler pulley seizing up on them - mine are rollin' smooth as silk after 180,000 miles. And the knock sensor really doesn't break or degrade, so if you don't have a knock sensor CEL then replacing it isn't going to do anything but burn $80.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 02-08-2007, 09:12 PM   #10
kwh29
Member#: 22100
All the idlers seem a bit gronky and noisy. Most of the front of the engine stuff was replaced about 20k miles ago by the previous owner, although I think he kept the original idlers. The water pump was replaced then too and it _definitely_ spins smooth as silk.
Thanks for the reminder on the hoses - the heater hoses are really nasty, definitely need to add those to the list.
I've got a shop doing the head now - I'm having them pressure test, do the valve seats, put in new valve guides and seals, and slightly deck the heads if there is any warpage. Hopefully there won't be any bent/burned valves or head cracks...
--Kevin H.
1998 2.5rs To 1999 2.5rs gc8v6 Subaru Conversions 2 11-02-2009 12:59 PM
What can cause oil leaks in 1998 2.5rs? RexHead64 Normally Aspirated Powertrain 3 05-01-2009 11:16 PM
Getting headgaskets swapped, what else should be done while motor is open? kaisersouse New England Impreza Club Forum -- NESIC 1 11-18-2005 09:07 AM
FT: 1998 2.5rs Black 2 door GOLDIES! loudbay Private Vehicle 'For Sale' Classifieds 2 03-03-2005 06:49 PM
2000 2.5RS' limited slip diff -> 1998 2.5RS ? grue Transmission (AT/MT) & Driveline 3 04-13-2004 02:59 PM
