Old 02-08-2007, 02:53 PM   #1
Member#: 91177
Default normal sti oil pressure?
What is the normal pressure range in a sti when idle and when at wot?
STI@LI is offline   Reply With Quote
Old 02-08-2007, 03:06 PM   #2
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Mine runs 70 lbs. cold. Hot, it idles between 10-15 lbs., and about 60 lbs. wot
Okeyd57 is offline   Reply With Quote
Old 02-08-2007, 03:21 PM   #3
Member#: 91177
Mine seems to run about 100psi, I was wondering if it could be the way my gauge is hooked up or if the sender is broke? I used a greddy oil sandwich adaptor. My idle pressure is about 15lbs also.
Old 02-10-2007, 07:04 AM   #4
Shakes
Member#: 44396
2001 RSTi
AW
Im in the same boat as you are. Get anywhere with it?
Shakes is offline   Reply With Quote
Old 03-18-2007, 12:26 PM   #5
Member#: 91177
No, but I think its the sender.
Old 03-18-2007, 02:43 PM   #6
cbourbs
Member#: 117749
at warm idle it's about 2 bar. and when at WOT it's about 6 bar.
cbourbs is offline   Reply With Quote
Old 03-18-2007, 03:15 PM   #7
Badler
Member#: 133597
Is this when it is warm, or cold. Cold oil psi is 100.
Badler is offline   Reply With Quote
Old 03-18-2007, 07:53 PM   #8
StiGoddess
Member#: 52161
04 Wrx Sti
Blue, silver rims
on my autometer gauge it is at 100 psi when cold, 20 psi at warm idle and 75 psi at warm WOT
StiGoddess is offline   Reply With Quote
Old 03-18-2007, 07:56 PM   #9
520hpsti
Member#: 108965
2005 Subaru WRX STi
i see about 30-35psi when warm. ( idles at 1100) and about 75-80psi when cruising ~3k and at WOT i see 80psi.. 85-95 when idling cold.
520hpsti is offline   Reply With Quote
Old 03-19-2007, 01:20 AM   #10
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Oil pressure doesn't change if you are WOT or NOT. Only RPM.
drees is offline   Reply With Quote
Old 03-19-2007, 07:10 PM   #11
520hpsti
Member#: 108965
2005 Subaru WRX STi
^ I figured as much.
bump for a good thread.
Old 03-19-2007, 11:57 PM   #12
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
this is mine
cold about 100psi give or take
warm idle 30-40psi
warm in gear 80psi
kevinh211 is offline   Reply With Quote
Old 03-20-2007, 12:43 PM   #13
adesso
Member#: 59892
2004 Harman Tuned
GT30R .82 JBP STi
Doesn't it really depend on how and where you have your pressure sensor hooked up, as well as what weight oil you are using? I'm using the oil galley plug on the top back portion of the block, running Amsoil 0w-30 Series 2000. I typically see cold oil pressure at 87PSI, warm idle is 29PSI.
adesso is offline   Reply With Quote
Old 03-20-2007, 02:38 PM   #14
Black-Falcon
Member#: 106318
14 Cadirrack
ATS
Cold Idle ~100
At Temp Idle ~20
At Temp in Gear ~80
WOT ~85
Black-Falcon is online now   Reply With Quote
Old 03-21-2007, 02:53 AM   #15
drees
Member#: 25905
2003 Silver Wagon
I'll say it again.
Old 03-21-2007, 08:48 AM   #16
Mykl
Member#: 14311
2010 GTI
Unless our Subarus are unique in some way, the general rule is that you want roughly 10 psi of pressure for every 1000 RPMs. If you're way over that, you may want to consider using a lighter weight oil.
Mykl is offline   Reply With Quote
Old 03-21-2007, 10:01 AM   #17
TheMadScientist
Member#: 23717
2005 Big red
That does not hold true with the subaru's.
My hot idle is ~20psi. I have 75psi at 2000rpm. This is on 10-40 dino.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-21-2007, 10:04 AM   #18
Mykl
Member#: 14311
2010 GTI
TMS
75 psi at 2000 RPM's??? There has to be something wrong with the pressure sender or gauge. That can't be right.
Old 03-21-2007, 10:51 AM   #19
TheMadScientist
Member#: 23717
2005 Big red
It is.
I have seen the same on many other subarus. They run stupid oil pressures.
TMS
Old 03-21-2007, 12:46 PM   #20
Mykl
Member#: 14311
2010 GTI
Man, that's just wierd... is this a boxer engine thing or just a Subaru thing?
Old 03-21-2007, 12:50 PM   #21
TheMadScientist
Member#: 23717
2005 Big red
My years hotroding SB chevy's your rule of thumb aplies. When I got my first subaru and put an oil pressure gauge on it I went WTF. Every subaru I have seen runs stupid amounts of oil pressure compared to the old V8's.
TMS
Old 03-21-2007, 01:22 PM   #22
widespread panic
Member#: 104944
I'll say this about Subaru oil pressure...if you want to run a b.b. turbo on a Subaru you better put a resrictor in the oil line like Garrett recomends. I know there are some turbo manufaturers that sell b.b. turbos w/o oil line resrictors for Subaru applications. IMO this is........wrong.
I think Garrett says like 40psi max with their b.b. center cartridge.
widespread panic is offline   Reply With Quote
STI Oil Pressure Reading? Low and High RPMS diplo12 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-21-2006 03:24 PM
STI Oil Pressure Reading? Low and High RPMS diplo12 Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-17-2006 03:57 PM
STi Oil pressure Thorshamm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-04-2005 02:29 AM
Stock STi oil pressure at idle? traganoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 12-28-2004 01:13 PM
STi - Oil Pressure Install... artdoesart Electrical & Lighting 5 05-22-2004 07:49 PM
