![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 1015
Just letting the people know who have been wanting these. M2 Performance ordered the first set of GC8 struts built to their specs to do some testing on a customer's car. As soon as they are satisfied with it they will be available. I see no reason they won't perform just as incredibly as their WRX version. So we are talking maybe only a month away or so, maybe not that long. It depends on how soon they give an answer.
Spring rates will probably be 260 front/225 rear and rebound will be increased a similar amount as with the WRX spec. You can reach M2 Performance at www.m2performance.com Keep in mind it will be another week or so yet before that first set arrives so be patient.
#2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Any idea if the GC8 suspension would be compatible with my beloved Legacy? Are the "normal" DMS Golds that I have now any different than the GC8 Impreza version? If not, then I guess the GC8 M2s should work also.
Pat Olsen '97 Legacy 2.5GT sedan |
#3 |
Member#: 8718
Vehicle:2005 STi, SpecMiata 05 NASA SM - Most Wins |
AAAAAAAAAAAAAAAAAAhhhhhhhhhhhhhh.
Deciding on coil-overs is killing me. I was going to order myself some LEDAs this week. But with this new news, I'm torn again. ![]() Its a possibility I may get these now, keep me updated. ![]() |
#4 |
Member#: 1015
Patrick, yes the GC8 versions will fit on your car. The main difference is in the brackets, as your Legacy has the narrower track like the GC8. Then you just get the GC8-GD rear top mount adapter kit and a pair of GC8 rear top mounts. You can get rid of those pesky angled spring seat adapters that way, too.
#5 |
Member#: 1133
Vehicle:'02 996 C4S '95 993 '71 911 3.0 '04 STI |
Hi Dave,
The spring rates are 260/225 instead of 180/180. This must change the handling balance towards understeer a bit. What size rear swaybar is recommended with the original and with the M2 kit (GC8 body of course)? The rebound damping is firmer with the M2 kit. To what extent will this compromise rough/gravel road handling? I'm not going rallying, but it would be nice to know that if I hit a long washboard I won't end up on the bump stops by the end of it! One more question: is 40mm the overall outside dimater of the strut, or is that the piston size? Tire sidewall clearance is pretty tight in back as it is. |
#6 | |||
Member#: 1015
Oh, and Kevin Williams (gtguy) has driven his WRX wagon with 260/225 springs and DMS Golds if you want to chat him up about handling comparisons. Quote:
#7 | |
Member#: 120
AKIC
Pat |
| Thread Tools | |
| Display Modes | |
| How many grown men still jump on the back of the shopn' cart on the way to the car? | chris619 | Off-Topic | 88 | 08-17-2005 10:33 PM |
| The new kicks are on their way | Samuelleeogden | Off-Topic | 20 | 12-01-2004 05:33 PM |
| Oh crap...the Columbia House legbreakers are on their way | live311 | Off-Topic | 4 | 10-05-2004 10:24 PM |
| VIDEOS are on there way | ^jynx^ | Tri-State Area Forum | 5 | 11-05-2001 12:53 PM |
