#1 |
Member#: 8486
Vehicle:2002 Impreza WRX Blue |
I installed the remainder of my TurboXS exhaust yesterday.. shaaaweet! Downpipe, replacement cat and midpipe. Not much louder, but has an interesting 'whistle' sound to it now.. sound very cool. Turbo spool up is much sooner now and boost comes on quicker.
I had a slight fitment problem with it though. I am forwarding pictures of the issue to Mark@TurboXS. They have installed this exhaust on three cars and I'm the first to have a problem with it though. My fix was pretty easy though. I also have his new stage 2 program for the UniChip I received today.. This is a new program as of Wednesday. I haven't driven it yet to test, going to do that shortly. The new program uses the stock restrictor hose instead of the blue one provided. It should help contain boost spikes, and help me keep my EGTs down. I had been seeing peaks as high as 1700 (ow ow ow).. I'll report back later! dale
#2 |
Member#: 4525
Vehicle:2002 WRX Wagon White |
Stage 2 does that mean you have the upgraded intercooler and water spray kit
#3 |
Member#: 7536
Vehicle:2005 WRX STi |
Would you let me know what the peak boost is? Also, what has changed to the program that allows the stock tubing to be used?
#4 |
Member#: 6773
Vehicle:wrx impreza |
A bit off subject, but for the spikes , would it go away if you added the unichip boost controller to the unichip ??
How does cobb do his tuning, since he kepts the same restrictor ? And can't Marc use the same restrictor and increase boost anyway ?? thanks |
#5 |
Member#: 7536
moe. - look in the post titled "Boost with Unichip" or various posts has the Unichip title in this forum. Wealth of info. on the topic, no need to reiterate it here.
#6 | |
Member#: 8486
dale |
#7 | |
Member#: 8486
I'm not entirely sure what the programming changes were, but I like this - less psi and lower egt's = longer engine life. dale |
#8 |
Member#: 7536
I don't know if this is Stage 2 or if your new program is actually similar to the "fix" from T.XS that have been talked about. I believe you new program is very similar to CA's Unichip program. Phil has told me that the CA chips have been shipping out with the newer, less boost program. Forgot what he said about the timing for the chip though.
#9 |
Member#: 4355
Phooka what is your boost now at from 5k to redline, compared
to other program? because i'll be gettin my stage 2 pretty soon. i personnally want more boost since i got uppipe, m2 intercooler, intake, full turbo back exhaust my system is beggin for more boost it already will spike to almost 15psi with all stock ecu controls, except for above 5k rpms. later |
#10 |
Member#: 10874
Vehicle:2002 WRX WR Blue |
Could you please elaborate on your fitment issues...i have a DP on order and would like to know :-)
Thanks Greg |
#11 |
Member#: 1416
BAIC
Vehicle:2/01 WRX SportWagon Aspen White |
I guess we'll have to call Mark and Phil to find out if the "fix" is in and how to get the reprogrammed/no spike chip.
Anyone find out yet? |
#12 | |
Member#: 8486
How does the m2 intercooler compare to the stock one? I have looked at that one for a while now as a replacement option. dale |
#13 |
Member#: 8030
Vehicle:2002 WRX Platinum Silver Wagon |
anyone know if the down and mid pipe would work on an auto wagon? are they the same?
Dan |
#14 |
Member#: 4355
Phooka it's way better than stock one hoses are that samco kind
and bigger. when it was about 85 here not to long ago it was alot more resistant to heat soak , i think its from the bar and plate design. if you sit for like 15 to 20min it will warm up but it cools off fast and stays cooler longer. i might get the auto waterspray kit later next year before it hits 100+ degrees anyway and since we get the crap gas here to. i think the fmi would be good but its 500 more and those long metal intercooler pipes will get hella hot . i've already wrapped my injen intake with turbo wrap it helps alot, to keep it somewhat less prone to heatsoak. later what's your boost at redline in the lower gears? later |
| Thread Tools | |
| Display Modes | |
| F/S: turboxs downpipe & cat back adaptor pipe | Ricowrx | Private 'For Sale' Classifieds | 0 | 11-29-2004 02:17 AM |
| TurboXS downpipe & heat-wrapping? | savka | Factory 2.0L Turbo Powertrain | 37 | 11-09-2002 10:10 PM |
| Now this would be cool: Vishnu & TurboXS & Cobb Unichips... | dug-e-fresh | Factory 2.0L Turbo Powertrain | 7 | 12-17-2001 08:09 PM |
| Attn: TurboXS - new Unichip program questions | hkwan | Factory 2.0L Turbo Powertrain | 18 | 12-06-2001 01:09 AM |
