Old 02-08-2007, 06:09 PM   #1
bruza12
Member#: 137661
2005 STi Cobb Stg. 2
Default Routine Maintenance
So I did some searches but I still have a few questions. The car has just under 18k miles on it and this is going to be the first time we service it ourselves. I was just going to change the oil, oil filter, rotate tires and balance them, and check fluids. Now when they say "oil, filter, lube". What do they mean by lube? And how should I balance the tires (same air pressure?)? Anything else I should do? Sorry if they're total noob questions. Thanks.
bruza
bruza12 is offline   Reply With Quote
Old 02-08-2007, 06:48 PM   #2
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
bruza
Oil/filter/LUBE is just a generic name. Our Subaru's don't get the 'lube' part, as the undercarriage is all sealed up, with no zerks to grease. Lubing goes with the name because older vehicle needed bushing, seals, etc.. lubed everytime you changed the oil, much like heavy equipment, dirtbikes, fourwheelers, etc..
If you are on stock tires, you want to use the stock recommended pressures, or depending on where you live you can add or subtract a tiny bit. Some places like Wal-Mart will only fill your tires to stock tire sticker pressure, even if they aren't stock tires, so watch out. I'd research what the best pressure for your particular tires is, and then ask them to inflate it to that point. If you have cold weather, it's ok to put a tad bit more in, because the cold reduces tire pressure, just don't put more than +2 or +4 lbs. in more, and make sure to have it balanced out as our AWD systems like everything "fueng shei"
As far as balancing tires, I'd say go to a shop that has good equipment and can balance using the inner tire stick on weights. Our alloys come with them on the inside, might as well keep it that way. It doesn't(shouldn't) cost extra, just some mechanics don't like doing it because it requires more precision and is more difficult to re adjust.
Hope that helps a bit, I used to work at a TLE, so I'm just going from experience. I don't know it all, so other more knowledgeable people may chime in later
~Levi
ScubaruImpreza05 is offline   Reply With Quote
Old 02-08-2007, 06:50 PM   #3
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
assuming you are on OEM wheels/tires, they should already be balanced. do a search for "wheel balancing" for more info. you will want to check your tire pressure periodically, however.
if this is your first time doing any maintenance, check the maintenance schedule that came with the car and make sure you stick to that at a minimum. be sure to search here and at scoobymods.com - this should give you all the info you need.
chewbakarox is offline   Reply With Quote
Old 02-08-2007, 07:04 PM   #4
Hayes
Member#: 11808
I lub the rear door hinges, hood hinges and hood locking mechanism with white grease. No need to rebalance tires unless you are having problems. JMO Ed
Hayes is offline   Reply With Quote
Old 02-08-2007, 10:29 PM   #5
bruza12
Member#: 137661
What about cleaning the air filter? I have an APS cai and we live on a dusty road. Should I clean that too? If so, how? Thanks
bruza
Garage Near Nampa For Routine Maintenance OnTheGas North West Impreza Club Forum -- NWIC 0 11-19-2005 12:15 AM
NASIOC.com will be down for routine maintenance from 4:30 - 4:40am EST 24 Off-Topic 3 10-07-2005 04:57 AM
96 Legacy Outback - Routine maintenance parts rogue Legacy Forum 6 03-08-2004 03:00 PM
question on routine maintenance? spike Service & Maintenance 4 04-27-2003 01:02 PM
Subaru routine maintenance ???? WRX-1977 New England Impreza Club Forum -- NESIC 3 12-19-2000 09:21 PM
