Old 02-10-2007, 11:35 AM   #1
metoo
Member#: 4764
2004 STi sold :(
forizzle
Default 225/40/18 vs 235/40/18
Weights specified are all for the same tire brand and model
I will be putting these on 18x7.5 wheels. Edit 235s should be on at least 8" rims.
225/45/17 stock size for reference
weight (lbs) per tire: 23.7 = 94.8 for four tires
weight for RE070: 27 (info from one uncredited resource)
diameter (in): 24.97
circumference (in): 78.45
225/40/18
weight (lbs) per tire: 23.6 = 94.4 for four tires
diameter (in): 25.07
circumference (in): 78.81
Advantages over 235/40/18:
*Will not noticeably effect gas mileage or gauges based diameter alone
*should have a less flexible side wall
*$23 per tire cheaper for this particular tire.
*lighter than stock size and nearly 9 lbs lighter than the compared tire size set, making for less mass to accelerate and deccelerate.
*lower profile looks better from the side
*less chance of hydroplaning
235/40/18
weight (lbs) per tire: 25.8 = 103.2 for four tires
diameter (in): 25.40
circumference (in): 79.80
Advantages over 225/40/18:
*will fill the wheel well better
*wider look betters from views other than the side.
*better wheel protection laterally and vertically
*technically softer ride (but doubtfully noticeable)
*probably better mid and top end acceleration with my GT30R setup
*wider means more grip on dry road for cornering, acceleration, and braking
What about gas mileage? Upon acceleration, the 225 has an obvious avantage. It has a smaller diameter and a less rotating mass. At cruise, I'm not sure which wins out. The 235 would cover more ground per revolution, but does the engine require more effort move the 235 a mile. The 235 has greater rolling resistance and greater frontal area (less wind resistance).
I'm just not sure whos avantages are better.
What are your thoughts.
metoo is offline   Reply With Quote
Old 02-10-2007, 12:02 PM   #2
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Most (all?) 235/40-18s list 8" as the minimum width...I'm sure you could get them on there, but would they look bulged? Dunno.
waktasz is offline   Reply With Quote
Old 02-10-2007, 02:06 PM   #3
metoo
Member#: 4764
2004 STi sold :(
forizzle
Thanks for the info. It seems you're right.
For 235/40/18:
Kumho says 7.5-9
Falken says 8.0-9.5
Fuzion says 8.0-9.5
Toyo says 8.0-9.5
What I don't understand is why the size range goes down a given width on 17's. For examle a 225/45/17 Falken Azenis calls for a 7.0-8.5 wheel. The same tire in a 225/40/18 calls for a 7.5-9 wheel. I guess the reason is, for a given width, the shorter side the wall the greater the angle of the wall would be to the bead seat of the wheel as you decress wheel width.
I guess I'm stuck with the 225s, but this is still a good thread for those with 8" wheels.
235/40/17 vs. 235/40/18 purduephigam Tire & Wheel 52 12-05-2006 10:51 PM
225/40/18 Great Tires vs 235/40/18 Good Tires JxOxExY Tire & Wheel 18 04-04-2006 04:12 PM
225/40/18 or 235/40/18 jland67 Tire & Wheel 2 05-19-2005 11:15 AM
225/45/17 vs 235/40/17 atomicapples Tire & Wheel 6 06-16-2004 10:01 AM
225/40-18 or 235/40-18 paikia Tire & Wheel 6 10-22-2003 11:39 AM
