Old 12-01-2001, 07:49 AM   #1
b00st3d
Member#: 9891
2015 RC-F
Ultra White
Default egt sensor placement?
is everyone putting their aftermarket egt sensor in the downpipe? i think i saw somewhere an uppipe with an extra bung for an egt sensor, but i have also seen a downpipe with an extra bung for the sensor....which ones best?
methadon
b00st3d is offline   Reply With Quote
Old 12-01-2001, 08:19 AM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
You can put your EGT sensor anywhere you want, and it will give you exhaust readings. The downpipe is a 'safe' location in that if your sensor fails and physically disintegrates, it won't damage your turbo. The downside is that it's further away from the cylinders, so the peak temps you read will be significantly lower (200-300 deg) than if you placed the sensor in your up pipe or manifold.
Others prefer to install their sensor in an aftermarket up pipe bung (easy, and gives higher readings) or to drill and tap a hole in one of the stock manifolds, which gives the highest, most accurate readings, but may not cover all cylinders if placed upstream of a collector. The drivers side manifold is pretty easy to pull, the passenger side a little more difficult, but many think putting the sensor at cylinder #3, the 'leanest' running cylinder, which is the rear passenger cylinder, is the best place.
I put mine in the passenger manifold collector, just before my stock up pipe.
Do a search, you will find a wide variety of opinions.
Rocky WRX is offline   Reply With Quote
Old 12-01-2001, 12:44 PM   #3
hkwan
Member#: 7536
2005 WRX STi
Great collected info. from Rocky.
hkwan is offline   Reply With Quote
Old 12-01-2001, 12:48 PM   #4
Scooby Don't
Member#: 7449
I asked Shiv the same question and here is his response (Thanks Shiv):
I suspect that cyl #1 will be the trouble cylinder with the new age WRX. That's the passenger side front (closest to front of car). I'd recommend mounting in that exhaust runner just a few inches after the exhaust port.
One more opinion from a highly reputable source,
Scooby Don't
Scooby Don't is offline   Reply With Quote
Wanted: MAF mass air sensor. 02 sensors. EGT sensor timing cover. tscott915 Private 'Wanted' Classifieds 10 10-07-2009 01:26 AM
EGT Sensor placement Kastley85891 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-25-2007 01:02 PM
a/f bung placement and egt probe placement 06whitesti General Community 2 11-12-2006 02:46 PM
EGT probe or sensor placement zeroFX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-26-2004 11:41 AM
Important information/data about EGT probe placement! ImprezaRS dot com Normally Aspirated Powertrain 15 02-15-2001 11:28 PM
