Old 12-01-2001, 08:29 AM   #1
tonytiger
Member#: 3844
1993 Legacy 1.8
Question Removing EGR-system for power.Questions
Many have probaply thought that recycling exhaust gasses back to intake can't be a good thing. Well that is what the egr-system does. So I'm planning to remove it or stuck the hoses with a plug or something to dissable this.
Question 1:
How does it effect on my car's other electric systems (Legacy 1993 EJ18 sohc)? What does the ECM like about it?
Question 2:
How large amount of the exhaust gas are at maximum percent recycled? What about the minimum (probaply zero)?
Question 3:
How does this affect on gas consumption?
Question 4:
Has anybody done this? Experiments, please?
Question 5:
How did you do malfuntioned the system?
Thanks for all comments and knowledge.
Maybe forgot something...
tony
tonytiger is offline   Reply With Quote
Old 12-01-2001, 08:46 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
uhh leave it alone.
the egr system, improves performance and gas mileage.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
Dec. 7th subaru here I come
www.hometown.aol.com/impreza25rs2000
Old 12-01-2001, 11:00 PM   #3
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
EGR only improves part throttle performance and gas mileage. At part throttle, the EGR system reroutes a small amount of the exhaust gas back into the intake. Since exhaust gas has already been burned, it doesn't burn again when mixed with the air/fuel mixture. Instead, it merely displaces some of the air molecules in the combustion chamber. As a result, combustion chamber temperature and fuel requirement are both reduced. Since a cooler combustion chamber decreases the chance of detonation, the ECU doesn't need to pull out timing. Therefore, you would get good performance and gas mileage.
There is no EGR at idle. Your idle will be rough if your EGR system feeds exhaust gas back into the intake at idle. Likewise, there is no EGR at wide open throttle. At wide open throttle, you want the maximum number of air molecules entering the combustion chamber in order to make maximum power.
In short, there is no need to disable the EGR system for power because it's not on at WOT anyway.
Richard
Richard L. is offline   Reply With Quote
Old 12-02-2001, 12:19 PM   #4
Blindeye_03
Member#: 4418
2016 Focus ST
my friend has a 97 supra tt & he disconnected his egr...makes the engine cooler he says. Alot of toyota guys do it....I have been told that our phase II engines dont have EGR at all b/c they already meet emmissions...sounds like a load of $hit, but I wouldnt want to mess with my emmissions stuff honestly .
-justin
Blindeye_03 is offline   Reply With Quote
Old 12-02-2001, 02:29 PM   #5
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
You have been told wrong. All the EJ25 engines I've seen have EGR. Only some EJ22's don't have EGR, mine included.
If you decide to remove the EGR components, there are a few ports that will need to be plugged, and you will get a number of OBD-II codes from the ECU, and maybe even a few engine misfire codes as well. Like the others have said, leave the stuff alone. You may want to leave it off if you're building a race car just so there are fewer things to put back when you rebuild the motor, but that's probably it.
-WaC
Wayne
wac is offline   Reply With Quote
Old 12-02-2001, 10:40 PM   #6
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
According to SubyTechMaster, the '01 RS and the '02 WRX do not have EGR. Check out this thread for more details. I certainly do not see an EGR valve inside my '00 2.5RS engine bay.
Richard
Old 12-02-2001, 10:50 PM   #7
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Default Wasn't able to find an egr either.
I couldn't find an egr on my 2001 legacy motor either.
Jason
2.5GT is offline   Reply With Quote
Old 12-02-2001, 10:57 PM   #8
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Actually, EGR lowers combustion temps, and therefore eliminating it would make the engine run hotter .
yamarocket630 is offline   Reply With Quote
Old 12-03-2001, 12:16 AM   #9
Blindeye_03
Member#: 4418
2016 Focus ST
you may want to check out supraforums.com to get more info...
-justin
Old 12-03-2001, 01:33 AM   #10
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
There are tons of materials on the web about EGR. Just do a search for "Exhaust Gas Recirculation".
Old 12-03-2001, 05:17 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Actually as far as i know 99+ EJ25 DO NOT HAVE EGR valves....why you ask....3 way catalysts...EGR Valves assit in reducing the production of NOX....these engines don't run excessively hot...and plus you can copensate that but running a 3 way cat which destroys NOX.
jeremy
My 2001 SURE AS hell doesnot have one
96 LSI code 400 Best way to clean egr system? pistoljeff Normally Aspirated Powertrain 0 10-25-2006 08:03 PM
Removing ABS system question, not sure what to do next... oldhat Brakes, Steering & Suspension 5 06-18-2006 11:43 PM
Removing EGR side skirts - double sided tape MikeWRX-NJ Interior & Exterior Modification 4 04-05-2005 12:49 PM
Who has removed EGR, with stock ECU? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-03-2003 05:18 PM
EGR System joefocker20 Normally Aspirated Powertrain 5 03-30-2003 01:53 PM
