Old 02-12-2007, 11:33 AM   #1
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Default Splitter with big TMIC
How much harm or rather how inefficient is it to run a tmic with no splitter?
I have a cf hood with no splitter at the moment and I haven't really noticed any difference since going from a factory splitter to none with the stock turbo...
Now I'm moving to a vf34 with a big top mount and I was wondering what I should do... I don't want to change my hood scoop and it seems the STi splitter is also too small for the IC...
Is it something that will greatly effect boost?
Is there any other option to going with a big top mount besides home depot weather strip? I don't want it to look like crap...
ptirmal is online now   Reply With Quote
Old 02-12-2007, 11:43 AM   #2
Crawdads
Member#: 30907
SWP GDB-G
An sti splitter with new bellows (rubber skirt) will work with most big TMICs...you also have a bugeye, so there are more splitter options out there for you.
A splitter is a part you want to have, it will help the intercooler come out of heatsoak faster by making all the air flow through it instead of a lot of air going around it.
Crawdads is offline   Reply With Quote
Old 02-12-2007, 01:34 PM   #3
ptirmal
Member#: 82243
07' Acura TL-S
What splitter options do I have? Judging from website pictures it seems a bigger scoop is needed to fit bigger splitters, is this right? If I do get an STi splitter what kind of bellow do I need?
The top mount is an ssac eBay one...
Old 02-12-2007, 06:18 PM   #4
dibblejr
Member#: 94070
05 LGT
Splitters and scoups are all interchangeable in any combination for SAME model years. You can fit a bigger scoop and smaller splitter and you can put a larger splitter with a smaller scoop. (Dont know why anyone would do this though) If you order an STi scoop and have an AM TMIC you will want to spend the extra $ to buy the Sti splitter.
If you order the Sti splitter you should order the Sti splitter seal that is made for it. You can reuse the snaps, but you could also buy new snaps for the seal.
** Note there are two hidden screws when you are trying to remove the scoop and splitter. One on each side hidden underneath the insulation.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-12-2007, 06:21 PM   #5
dibblejr
Member#: 94070
05 LGT
Here's the difference in splitters on the Ebay TMIC. Looking at my pic you can see the OEM Splitter mark *smaller diameter and the Sti Splitter * larger diameter. Even the Sti splitter leaves a little to be desired.
Old 02-12-2007, 07:20 PM   #6
CynicX
Member#: 48199
06 WRX
Wow talk about hot spots. Have you done anything in attempts to cover more of the IC? I have a SSAC TMIC looking at me and been debating over what to do as far as the splitter goes...
CynicX is offline   Reply With Quote
Old 02-12-2007, 07:44 PM   #7
dibblejr
Member#: 94070
05 LGT
Na, I am happy with what I am happy with my intake temps, so no need. I suppose I could fabricate something but not at this time.
I wrapped the turbo, I use a heat shield and I have alky/H2o so I am all good.
I always use this picture in threads like this because it clearly shows that the STi splitter is not really that much larger than the Wrx splitter.
I considered a chimney, but changed my mind. The other thing is I do not run a belly pan.
There is one vender here cant remember who right now that sell a larger splitter but at too high of a price IMO.
Use this as a reference and rethink what YOU want to do.
Jay-R
Old 02-12-2007, 08:36 PM   #8
CynicX
Member#: 48199
06 WRX
meh I'll prob use the STI splitter it seems the coverage is good. I just didnt know if there was another option. I wanted to have all my ducks in a row before I have it protuned then find out I can buy a 20 dollar part that covers the entire TMIC then be paranoid I didnt get the best bang from the protune, you know...
Old 02-12-2007, 08:36 PM   #9
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
which ebay top mount is that?
DigitalPunk is offline   Reply With Quote
Old 02-12-2007, 08:52 PM   #10
dibblejr
Member#: 94070
05 LGT
Autodynasty
Old 02-13-2007, 09:14 AM   #11
ptirmal
Member#: 82243
07' Acura TL-S
when they tune it your hood is open so the splitter doesn't really matter at that moment...
The main reason i don't want to buy a new scoop is the only cf sti ones I have seen are pretty expensive...
So I should be able to run a stock scoop with a bigger splitter?
Old 02-13-2007, 11:56 AM   #12
dibblejr
Member#: 94070
05 LGT
Only on a DYNO tune, hard to drive +100mph with a hood open. You could run a syock scoop with a larger splitter, however you will not be able to take full advantage of the splitter. Thats why the scoops are larger as well.
Jay-R
Old 02-13-2007, 01:55 PM   #13
ptirmal
Member#: 82243
07' Acura TL-S
Jay-R
brain fart, I wasn't thinking...
I know the reasoning but I didn't think they'd fit... from some pictures it looked as if part of the splitter goes into the scoops contour...
Does it just screw in or what? I don't wanna drill into my cf hood more than necessary
Old 02-13-2007, 02:28 PM   #14
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
splitters are very important especially if you have a cf hood. i have a cf hood and i kept my splitter off for a few months and the hood moved so much that it began to get crack in the resin around the scoop. i put the splitter in and the movement just about stopped.
jbwrx is offline   Reply With Quote
Old 02-13-2007, 04:27 PM   #15
dibblejr
Member#: 94070
05 LGT
Both splitters have the same amount of holes in the exact same place. The difference is in the used portion of the splitter, thats all.
Jay-R
Old 02-14-2007, 03:12 AM   #16
emeessen
Member#: 117741
2012 STI Ltd SWP
2006 Saab 97x Arc
Hey here is all you need to know about the splitter solution. Search.
http://forums.nasioc.com/forums/show...1134434&page=2
emeessen is offline   Reply With Quote
DIY Hooscoop Splitter for big TMIC paintbing Interior & Exterior Modification 41 09-06-2012 08:21 AM
STi splitter with stock TMIC BlackRex05 Newbies & FAQs 5 12-12-2008 05:27 PM
Process West Splitter with other TMICs? verdee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-02-2008 12:36 AM
what splitter for big tmic pux888 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-01-2005 11:53 AM
Splitter with MRT TMIC? WRXagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-02-2002 09:17 PM
