Old 12-01-2001, 04:50 PM   #1
TurboRex
Member#: 8635
04 STI, 07 FXT
Default Translating the O2 Sensor Readings
I recently purchased an obdii scanner and noticed it is giving me O2 sensor readings. The readings on a test run went from 0.16 - 1.01. Closed loop readings are only good to see that the ecu is adjusting trying to get the proper a/f ratio. At wot, the readings would tell my a/f ratio. However, I don't have a conversion chart. Does anyone know where to find this? Also, if these are readings of the wideband o2 sensor, then would need this conversion chart. I don't know much about o2 sensors but I would think that if I am getting a 1.01v reading then it must be off the wideband sensor. I think the range is 0.00 - 2.0v on the wideband...is that correct?
Thanks for any info,
Greg
TurboRex is offline   Reply With Quote
Old 12-03-2001, 06:37 PM   #2
TurboRex
Member#: 8635
04 STI, 07 FXT
If I understand right (after a little more research), the front o2 sensor gives two signals. One from outside air and the other from the exhaust. Thus, the o2 sensor reading (say on the obdii)you get is the voltage difference between these two signals. Does anyone have any knowledge of this?
I have the data as does anyone with an obdii. I just need to know how to interpret it.
Greg
UTEC Q: does UTEC intercept stock O2 sensor readings? happasaiyan Engine Management & Tuning 6 12-10-2004 01:29 PM
O2 Sensor readings Mike4kz Normally Aspirated Powertrain 1 11-30-2003 09:42 PM
o2 sensor reading? DangeRS Normally Aspirated Powertrain 14 04-15-2003 02:30 AM
Stock MY98 EGT and O2 sensor readings! R Diamond Technical Forum Archive 8 09-10-2000 12:56 PM
O2 sensor readings for MY99s efoo Technical Forum Archive 3 07-25-2000 08:05 AM
