Old 05-03-2007, 11:50 PM   #51
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Originally Posted by javastiwagon24 View Post
Sticky i think. " if this has been covered i havent read it" to make things clear. you can not use 5 speed clutch and flywheel. however you may use the 5 speed clutch disk. they seem to be alittle more affordable and i am currently running a six puck. the tobearing is the same. clutch fork is needed from 6 speed. the slave cylinders are identical the 6 speed is slightly thicker cast but is the same. i made the mistake of buying the 6 speed slave and paid 90 wasted money. u will need to get a auto wrx driveshaft or get yours shortened 1.5 inches of the front shaft. that is all i see that needed to be corrected thanks. ps if going with the 6 speed, yes it costs alot i didnt do much research on other stronger 5 speed gear sets i think i was driven toward the extra gear. but i will tell you what. i have an 05 sti trans, if you want to maintain the same 5th gear feeling the six speed is very close in same finial drive ratio. 3-4 are awesome, the whole car feels so much more refined. it feels as though you are always in boost and seems to get to 100+ way faster. hope this may help some of u stuck or trying to weigh the options ! "i was stranded for 1 month trying to figure out why the clutch was slipping." because i was told to use the 5 speed clutch and flywheel. good luck.
I'm using the 5 speed clutch and flywheel along with the STI clutchfork and it works like a charm. A friend of mine has been running this setup or quite some time on his 04 and has had nothing but great luck with as well.
BiggSean is offline   Reply With Quote
Old 05-09-2007, 04:34 PM   #52
sumfoo1
Member#: 82146
2005 Legacy GT
Is the 07 legacy 6 speed the same as the 07 sti 6 speed w/o dccd?
Are the gear ratios the same?
sumfoo1 is offline   Reply With Quote
Old 05-17-2007, 09:28 PM   #53
16G4ME
Member#: 69792
05' wRxElementTuned
HydraW/Hydramist & GT65
*** There may be a difference between the 05 axles and the 02-04 axles on the WRX. There may have been a change to the axle and some 05 wrx might be able to use their stock axles. I have not verified this, just read some threads suggesting it.
Has there been any verification of this info? I am in the middle of ordering my parts and am curious if this is true.
16G4ME is offline   Reply With Quote
Old 05-18-2007, 07:53 AM   #54
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
The 05 axles have stubs on them that slide into the tranny. The 02-early 04 axles don't have stubs....the stubs are on the tranny itself. The axles slides onto those stubs and a pin locks in place.
CoolRex is offline   Reply With Quote
Old 05-19-2007, 04:55 AM   #55
v_dubbsub
Member#: 148539
2005 WRX
blue
Default tranny Q's
i got a 2005 wrx auto, i wanna do a 5spd tranny swap what would i need to do it, and what some1 would like to trade for a auto
v_dubbsub is offline   Reply With Quote
Old 05-24-2007, 01:39 PM   #56
WRXBob
Member#: 12455
02 WRX
My 6 sp swap is almost complete until I realized that the $1100 Drive Shaft shop axles do not have the metal covers near the diff. This suck because without that the seal will not last very long.
WRXBob is offline   Reply With Quote
Old 05-31-2007, 02:22 AM   #57
solarin006
Member#: 109975
06 WRX's have a 3.70/1.0/3.70 R&P
06 STi's have a 3.90/1.1/3.54 R&P
For 6MT swaps into a 2006 (unsure about 07) WRX, you need to change to a 3.90 R&P if installing a 04-05 6MT or a 3.54 R&P if installing an 06 6MT.
solarin006 is offline   Reply With Quote
Old 06-01-2007, 04:48 PM   #58
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
What is the rear R&P on the 05 STi rear diff?
What do I need to do for my clutch setup on my 06 WRX since they changed engagement styles in 06? To run the hubs I need the STi rear brakes but not the front? Do I need brembo's up front to run the front hubs? Can I just do an STi BBK instead?
AWD>FWD is offline   Reply With Quote
Old 06-01-2007, 05:37 PM   #59
solarin006
Member#: 109975
05 STI's have a 3.90 R&P (in an r180 diff)
You'll need to swap slave cylinders, clutch fork and run an STi clutch.
To run 5x114.3 STi hubs in the rear, you'll need either STi rear brakes or 5x114.3 compatible aftermarket brakes (i.e. not WRX brakes). Also 5x114.3 bolt pattern wheels, STi axles, r180 rear end, and STi driveshaft.
However you can run stock wheels/axles/brakes if you change the ring and pinion in your r160 diff and run a driveshaft from an auto.
To run STi hubs up front you'll need STi front brakes or compatible aftermarket brakes (not WRX), STi axles. However I think the 06's have male axles, you'll need to research which 6MT tranny you have as to whether it'll hook up or if you can convert it.
Old 06-03-2007, 02:45 PM   #60
svx_my_bay
Member#: 150412
Curious if there is an answere to this.
svx_my_bay is offline   Reply With Quote
Old 06-21-2007, 01:48 PM   #61
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
I wonder if I can just swap the 07 sti 3rd and 4th gear into my 04 tranny, as it seems all the other gears are the same.
ilivas is offline   Reply With Quote
Old 08-27-2007, 11:12 PM   #62
crashtke
Member#: 120912
Not sure 100%...we had a guy do this swap, I will see if I can get some info on it.
crashtke is offline   Reply With Quote
Old 08-27-2007, 11:48 PM   #63
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
when swapping the hubs into my02, do I have to change anything else? Or is it just that straight up?
domestic_abuser is offline   Reply With Quote
Old 08-31-2007, 05:00 PM   #64
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
I swapped an 04 STi tranny into an 06 WRX. Reused my stock 06 axles, but they kept popping out of the tranny...
Switched to 04 STi axles, but now my ABS doesn't work and they were a real bitch to get in... :-/ Anyone else gone this route?
Bullitt 2496 is offline   Reply With Quote
Old 09-01-2007, 06:32 PM   #65
The_Anti_Hero
Member#: 100943
02 wrx
blue
i'm gathering the pieces to swap an USDM 04 STi trans into my bug, do i need a 6mt trans mount/crossmember?
The_Anti_Hero is offline   Reply With Quote
Old 09-02-2007, 10:48 PM   #66
crashtke
Member#: 120912
Not sure on the crossmember, but I believe just the mount is what you need. The transmission is MUCH bigger.
Old 09-04-2007, 06:36 PM   #67
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
So i have a question about my late 04, or 05 STI trans swap into my 03 wrx. can i use the STI male CV shafts with my front hubs? or do i have to get the stubs from the dealer and use my WRX CV shafts? I thought i may have read somewhere that STI CV shafts can be used on the front, just not the rear.
Thanks in advance
Jon
Jpizzzle is offline   Reply With Quote
Old 09-06-2007, 04:45 PM   #68
Bala
Member#: 112510
2006 WRX, Black
I am trying to find out what exactly is involved in doing a tranny swap from a 07 Legacy Spec B into 06 WRX.
Here are some questions i have:
Will I need Legacy's rear Diff? If so, what Diff does the Legacy comes with?
Will I have to use a different drive shaft? If so, which one?
If i do have to change the rear DIff in order to accomodate the Legacy's tranny, will i have to change the rear axles/hubs and brakes?
6 spd manual, spec.B only
1st 3.636
2nd 2.235
3rd 1.521
4th 1.137
5th 0.891
6th 0.707
final 3.454
Ok, I will start a parts list for this swap and you guys please correct me if i m wrong and also tell me what i need to add or take off the list.
2007 Legacy Spec B 6MT tranny swap into 2006 WRX:
1)2007 Legacy Spec B 6MT trasmission
2)SPT 6-speed short throw linkage
3)6-speed shift knob, STI lower dash peace with STI boot
4)2006 automatic trasmission drive shaft (please correct me if i am wrong)
5)6-speed clutch fork (please correct me if i am wrong)
6)STi slave cylinder (please correct me if i am wrong)
7)Reuse stock 2006 WRX rear Diff
8)Reuse Stock 2006 5-speed WRX clutch
Please confirm the above parts are correct or if i need to add additional parts
THanks
The reason I prefere to do the Legacy's Spec B tranny swap over the STI's is because it does not have the DCCD and the tranny itself is cheaper.
Please help, any comment welcomed.
Thanks.
Bala is offline   Reply With Quote
Old 09-13-2007, 01:33 PM   #69
InfamousDX
Member#: 25413
Curious if anyone can point me to a swap thread regarding a 2007 USDM STI into a 2003 (or equivalent) USDM WRX. Looking to keep the factory r160 as well.
Old 09-20-2007, 11:18 AM   #70
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
My question is whether a tranny from a 98 legacy will accept an RA gearset and fit in my 03 WRX without a problem? I need a tranny soon, and I found a great deal on this one. I figure the RA gearset would solve the gear ratio problem if there is one, and if I'm gonna go that route all I need is a case to accept it. Right? Buying a broken tranny and replacing the gears should decrease the downtime of my baby. Is there a difference in the case of the Legacy trannys and the WRXs. Or is this a bad idea?
I'm a little bit ignorant as to what is compatable with what, but I've learned so much from reading your threads. great job guys!
SubiSam is offline   Reply With Quote
Old 09-20-2007, 06:36 PM   #71
crashtke
Member#: 120912
My concern would be the center and front diff...probably different.
Old 09-21-2007, 12:11 AM   #72
SubiSam
Member#: 156401
'03 WRB WAGON
Not sure what the final drive is on the '98, but it's my understanding that the '96 legacy has a 4.11 ratio. Probably the same with the '98. I beleive the RA gearsets come with a 3.90 though, so none of this should matter. Right? I'll have to change the rear diff no matter what.
Why would the center diff be an issue? This brings up another question. I've heard that the sti is rear wheel drive until the rear wheels slip and the wrx is front drive until the front wheels slip. Is there any truth to this, and if so, is there a way to reverse it? I always thought that symetrical awd meant equal power front and back. Are they both considered symetrical? Maybe this question is in the wronge thread, but if this is the case I might rather have the sti tranny. Maybe I'd have to win the lottery first though.
Old 09-22-2007, 10:23 PM   #73
wrxvette009
Member#: 138386
02 WRX
SRP
I just put an 05 STI swap into my 02 WRX. In a few months I wanted to have Neetronic install the DCCD. My question is not having that hooked up will not burn out any thing will it. Thanks
wrxvette009 is offline   Reply With Quote
Old 09-27-2007, 08:27 PM   #74
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
Does anyone have a successful write up how to swap in a STI transmission from any STI year to a 2006 WRX? I am really looking forward to looking into this considering I am in need of the swap! Please pm me or post links thank you. Or would the 04 sti transmission work with the 06 WRX. I am asking because I read in this thread the clutch setup is different. Please specify Thank you.
06wrxlbart is offline   Reply With Quote
Old 10-02-2007, 07:50 PM   #75
swiftwrx06
Member#: 130897
2006 6 speed WRX 18G
330awhp 355ft/lbs
Bump
I need an answer to an axle stub question from those who have done this before.
I have an early 04sti "stubbed" trans, but my 06 wrx has male axles.
Can I just remove the stubs from the 6 speed and pop the wrx axles in? If they fit what else would I need? new circlips?
swiftwrx06 is offline   Reply With Quote
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 02:02 PM
FOR SALE 06 STI 6 speed transmission wrx swap!!! felixwankel88 Drivetrain 10 09-06-2009 08:26 PM
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 10:04 PM
FS: MD brand new exedy twin disc for 04-06 sti 6 speed $1200 sr55stiguy Drivetrain 14 09-02-2007 03:03 PM
SPT short throw shifter for 04/05 STi 6-speed tranny JDM addict Private 'For Sale' Classifieds 28 09-17-2004 01:53 PM
