North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 02-13-2007, 01:14 PM   #1
PowderMan420
Member#: 33737
Default Who can weld cast aluminum?
looking for some help to fix my water pump cover on my 2002 Vor 450 enduro its cast aluminum yes I know its not subaru related but I know some of you sudy peeps can fix anything so any help is much appreciated thanks In Renton WA by the way
PowderMan420 is offline   Reply With Quote
Old 02-13-2007, 02:20 PM   #2
96WRX
Member#: 30610
1996 WRX STi Type R
555 Blue
I don't know of anyone who does it, but cast aluminum can be welded. Back in my racing days, I threw a rod out the side of my Alfa's engine block. I had the block welded. The guy said that he had to heat the block up in an over first, then weld it.
96WRX is offline   Reply With Quote
Old 02-13-2007, 03:11 PM   #3
Ferg
built to spill
Member#: 14145
02 WRX BLOD
76 C30 Dually
PM David Medina, he's a certified welder. Not sure if he can do cast aluminum though.
Ferg is offline   Reply With Quote
Old 02-13-2007, 07:39 PM   #4
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
probly needed to pre-heat it to get deeper penetration into the block.
i used to weld aluminum extremely well, but i havnt even touched a tig or even welded aluminum since my first welding job after i got out of school, nor do i even own a welder of my own yet. been welding nothing but structural steel for the past year and half.
but if you have one or whatever, ill do it for you.
edit: what about worldone's tech? dont know if hes even done alum. but can try him too.
David Medina is offline   Reply With Quote
Old 02-13-2007, 09:57 PM   #5
PowderMan420
Member#: 33737
here is the problem its about a 1/8" thick the nozzle previously extended out an inch. Should I try a hotrod shop to see about making a duplicate? or is this fixable
Old 02-13-2007, 10:52 PM   #6
hibrid
Member#: 97440
2002 STG 2
shaggin wagon
Look up STA-WELD in redmond. Its a one man company runned by a guy named larry (Big Lar). He is a freakin wizzard with aluminum and other diceplins of welding and brazing. Im not positive that he can do the cast alluminum, but is worth a shot. Might be more of a braze than a weld
Ive had him weld several custom built things for me on my K5 Project (Alluminum radiator bung and neck, Custome made brass fitting that serves three purposes and is the only one ever made, and hes done some beadlock wheels for me too)
(425) 885-3757
15609 NE 113th Ct
Redmond, WA
hibrid is offline   Reply With Quote
Old 02-13-2007, 11:39 PM   #7
hanahawaiian
Member#: 140699
2006 Evolution IX
World one performance have alum Welder. i think so
hanahawaiian is offline   Reply With Quote
Old 02-14-2007, 12:23 AM   #8
hibrid
Member#: 97440
2002 STG 2
shaggin wagon
In this case (Cast alluminum) Its not about the equipment, its about the technique used. Cast is a very pourus material and it is very dificult to make a good weld with good penetration, yet not make it brittle.
Call STA-WELD
Old 02-14-2007, 01:07 AM   #9
PowderMan420
Member#: 33737
Thanks I'll give STA-WELD a call..I still need to make a stronger piece any ideas?
Old 02-14-2007, 10:45 AM   #10
hibrid
Member#: 97440
2002 STG 2
shaggin wagon
Afetermarket?
Old 02-14-2007, 05:42 PM   #11
PowderMan420
Member#: 33737
Dropped the piece off with Larry he seems like a really nice guy. I hope it works out so I can ride my bike soon. I asked about getting a custom piece made he said it would cost 200-300 so I might have to bite the bullit and do that someday
Old 02-14-2007, 07:27 PM   #12
hibrid
Member#: 97440
2002 STG 2
shaggin wagon
ya, if there arent clearance issues Larry should be able to fab one from scratch for you. But he has a hourly rate of like 65+ per hour, so it will cost you.
Need someone who can weld Aluminum IcedearthWRX Tri-State Area Forum 6 06-14-2008 12:08 AM
Will pay cash to someone who can weld in NYC area or CT!! 2002bugeye Tri-State Area Forum 5 03-10-2006 08:22 AM
Suggestions on someone in md who can weld a bung into a set of headers mpower22 Mid Atlantic Impreza Club -- MAIC 3 12-30-2004 09:40 AM
Local: Who can weld egt bung? nizz Tri-State Area Forum 3 10-29-2004 06:03 PM
