Welcome to the North American Subaru Impreza Owners Club Friday November 28, 2014
Old 02-13-2007, 06:16 PM   #1
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
Default clicking noise at 2k and under
mod list
perrin 35r kit
hydra
stock motor
meth injection
twin disc clutch
for the past few weeks my motor has been leaking oil from the gaskets(we think) how ever in the last 2 days I have noticed a loud(can hear over moderate music) when the motor is in or out of gear at 2k and gets louder as it gets lower.
now is this serious or could it be dealing with the -1 temps outside.
the car still pulls like crazy and the A/F readings are normal.
Should i be worried or just let it go.
also i dont beat on the car hard i rarely get on it, latly(month or so ) i havnt gone over 4000k.
also the oil level is normal
WrxWonderWagon is offline   Reply With Quote
Old 02-13-2007, 08:11 PM   #2
CypherAZ
Member#: 139680
2008 WRX STi
you have a 35r and don't go over 4k?
CypherAZ is offline   Reply With Quote
Old 02-13-2007, 09:00 PM   #3
flycaster
Member#: 60142
2011 WRX
Grey
This "clicking" - does it vary along with the rpm? And you say it "goes away" above 2K, or is it perhaps that you can't hear it above 2K? Does it do this just when it is warming up, or does it do it all the time? Does it make this same noise with the car stationary, and you just rev it? Clutch in and out, the same?
flycaster is offline   Reply With Quote
Old 02-13-2007, 09:39 PM   #4
subiescooby
Member#: 106303
'04 STi
WR Blue Pearl
gonna need some more info to help you out i.e. what kinda temps, and what do you mean you can't hear it over 2k?
subiescooby is offline   Reply With Quote
Old 02-14-2007, 12:11 AM   #5
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
temps
-2 ranging to 20 the past few days
the clicking noise stops after 2k it no longer makes the rattle noise
it does this even when it is warmed up
yes it does it stationary
Old 02-14-2007, 12:18 AM   #6
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
clutch in and out
same
Old 02-14-2007, 10:23 AM   #7
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
bumpping
Old 02-14-2007, 11:44 AM   #8
benw
Member#: 103320
2005 wingless
aspen white
use a screwdriver to your ear to pinpoint the sound or post up a sound clip, I don't think you are going to get anywhere by trying to translate a sound into words and hoping for advice.
benw is offline   Reply With Quote
Old 02-16-2007, 12:40 PM   #9
flycaster
Member#: 60142
2011 WRX
Grey
OK, at least you've established that it isn't a moving rattle, or drivetrain noise. Pop the hood and start listening - see if you can locate it. If you can't tell, put it on a lift with the engine running, pop the shroud off and listen to the bottom side.
Clicking sound between 2k and 3k rpm jmodica Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-29-2007 07:41 PM
Wierd clicking noise at partial throttle Rice18 Service & Maintenance 5 03-09-2006 12:46 AM
Urgent: Strange noise at 2k rpm's and up. njskatchmo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 01-17-2006 11:07 PM
Clicking noise at shut off... BlackedOutRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-09-2005 08:44 AM
rhythmic clicking noise at idle Raiden Transmission (AT/MT) & Driveline 18 11-20-2004 08:15 AM
