Old 02-14-2007, 12:09 AM   #1
Gemni69
Member#: 71744
Unhappy 05 wrx- block swap
Hey guys,
First of all HELP and thanks for any info.
I have a 01 2.5 rs impreza. I was doing a motor swap to a 05 wrx and when the motor was installed i learned that the block was bad. So i have to swap the block out. I was offered a USDM sti block with forged piston.
The setup i have thus far is
05 wrx motor
VF 39
STi pink injectors
STi TMIC
gruppe s headers
Injen CAI
ERZ up pipe
ERZ catless downpipe
Greddy evo catback
Now my question is can i do a block swap with out engine management? Will this block work with the setup i have with any problems? The Mech was going to do a cpu flash for the setup i had with the wrx block. But since that doesnt work he said it will still work fine. What do you guys think? Also he wanted me to do a value job before the motor goes in. The Mech ported the wrx heads. What do you guys think? I am real new to this block swap. I have been having bad luck with this swap and just want it to be done and relaible. I want a fast car and also a daily driver if needed. Any input would be great. I have to make a decision tomorrow so please help me out guys.
Thanks
Gemni69 is offline   Reply With Quote
Old 02-14-2007, 09:37 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You will definitely have to tune for the 2.5L block, but you can use the 05 wrx ecu to do it.
Tony
Old 02-14-2007, 12:27 PM   #3
Dizzuque
Member#: 98699
2007 SWP WRX
Tony
yes what he said. you may also want to get a thicker headgasket to lower the compression.
Dizzuque is offline   Reply With Quote
Old 02-14-2007, 02:22 PM   #4
Gemni69
Member#: 71744
Thanks guys. What are my tuning options? So far the mech is going to flash stage two map on my cpu. I have no access port or any EM system on it right now. Any advise?
PSM 05 STi for 05 WRX trunk swap psmBoXer South East Region Private Classifieds 1 01-14-2014 01:09 PM
05 wrx block swap Gemni69 Commercial ECU Reflashes 2 02-17-2007 08:03 PM
wrx - block swap Gemni69 Subaru Conversions 0 02-14-2007 05:02 AM
05 wrx ecu swap to 05 ecutek problem? nuhga Engine Management & Tuning 1 11-12-2005 06:27 PM
EJ20 WRX Block Swap Soon2BturbodRS Subaru Conversions 2 06-17-2003 12:45 PM
