Old 12-02-2001, 01:49 AM   #1
JaBooo
Member#: 12898
2004 WRX
Java Black Pearl
Default Valve tap???
2000 Subaru Impreza 2.5 RS
I'm very new to the Subaru scene and I'm not sure if my engine is supposed to sound like it does. A friend told me Subaru engines sound different. It sounds almost like i have a slight valve tap at around 2-3000 rpms. Is this normal?
It's not loud, I can only hear it with the windows up. Engines got 23k on it and Synthetic oil is used and was used by the previous owner. I was a VW guy before this so this is all new to me.
--Justin
JaBooo is offline   Reply With Quote
Old 12-02-2001, 02:29 AM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
The ej25 engine is kinda a loud engine. Its normal to have a bit of ticking, etc. Dont worry about it too much unless it get loud.
Midwayman is offline   Reply With Quote
Old 12-02-2001, 08:04 AM   #3
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
It's very possible it's valve tap, I had valve tap.(1st engine) and blew a cylinder on my second engine and my car is currently at Subaru getting it's 3rd engine put in. It all depends on how hard you drive your car. I'm convinced my Impreza is a rally car so I drive it everywhere as if I were in a Rally. The Impreza is such a fun car to drive that it's really hard not to drive it HARD!
Dam Subaru parts cost as much as Porsche parts.....
SuBart is offline   Reply With Quote
Old 12-02-2001, 06:55 PM   #4
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Ticking... My car sounds like a time bomb on crack. Bet it's really loud right now without the headers on, but i'm not going to turn the engine over to find out But the ticking has been there for a long time, not as bad after the car warms up a bit, so it's probably just due to some valve clearance issues.
-Paul
(With half the car in pieces on the ground)
paulnose is offline   Reply With Quote
Old 12-02-2001, 11:13 PM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
When I installed my Cobb cams at 12,000 miles, I checked the valve clearance before I took anything apart, and there was a wide range of clearances, from almost to tight to almost too loose. (they were all in spec though) after installing the cams and adjusting the valves to the same spec (.015mm intake and .020mm exhaust) the enigine is much quiter.
yamarocket630 is offline   Reply With Quote
Old 12-03-2001, 04:37 AM   #6
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Well I picked up most of the pieces, 'couse I added the timing belt into that pile on the floor. Now I think I put it together okay, but If not i'll share the funny noise that will make with everyone.
And da** you yamarocket, now I almost feel like adjusting my valve clearances, maybe save it for next year so I can afford to get some turbo cams, and have more than one reason to pull off that cover.
Old 12-03-2001, 05:12 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
is it a ticking or a knocking?? a ticking would prolly just be valve clearance...a knocking IIRC there was a bulletin for a bad timing belt tensioner.
jeremy
Old 12-03-2001, 10:46 AM   #8
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
i didn't know there was a bulletin for the timing belt tensioner, cause when I took mine belt off that tensioner wouldn't compress for anything, Had to use a vise and allen key hold the tensioner down, and then it really didn't seem to go back to the normal position afterwards, dang it, maybe I need to take a trip to the stealer, although they will probably make me pay for the damn thing since I took the damn belt off, will have to inspect it. Thanks for the warning though.
Old 12-03-2001, 11:02 AM   #9
fabulous12
Member#: 6831
98 impreza 2.5RS
black
I've got the same ticking, im pretty convinced it's a valve clearance problem through reading up in a bunch of threads on the ticking issue... anyone know how much it would cost to have this adjusted? I wouldnt even know where to begin if i were to do it myself... I'm getting tired of hearing this ticking though, it can be pretty loud at times, especially at low rpm acceleration (between 2k and 3k), and idle.
fabulous12 is offline   Reply With Quote
Old 12-03-2001, 12:02 PM   #10
outback bosco
Member#: 12075
2K OBS blue/silver
Lobotomized 86 & 87 XT
Default TICKING
I get a ticking too.
I was getting a misfire in my #2 cylinder. i replaced the spark plug wire and this annoying ticking started. It is isolated on the left side of the engine. The ticking for me does not stop it just gets faster with the engine.
Does that sound farmiliar.
I wish I could offer a solution but right now I am just as confused as you.
BW
outback bosco is offline   Reply With Quote
Old 12-03-2001, 08:12 PM   #11
JaBooo
Member#: 12898
2004 WRX
Java Black Pearl
It's a tick. I have noticed that you can hear it better when its cold, like in the morning. I'm not low on oil, and there is no engine work. I guess I'll get it looked at. I just hope warranty covers it.
--JaBooo
89 Loyale with passenger side valve tap jem1 'Old School' Subaru Forum 6 08-03-2006 07:59 PM
valve tap on a 2.2 JamiePasson Normally Aspirated Powertrain 11 08-03-2006 12:16 PM
Engine/ Valve tap pistoffjstr Legacy Forum 8 02-15-2006 09:06 PM
valve tap? 5zigenwrx Southern California Impreza Club Forum -- SCIC 2 02-13-2004 11:45 AM
Valve tap?!? SoLo OnE Factory 2.0L Turbo Powertrain 5 02-11-2004 12:08 AM
Message Board Statistics All times are GMT -4. The time now is 06:38 PM.
