Old 02-15-2007, 11:35 AM   #1
BlowDro
Member#: 112116
2006 WRX
Default o man, now what did i do. remote clicker, radio, clock dead
this morning i decided to move my 2 maddad gauges. they were installed properly but the wires fell out of the harness a whle back and i never got around to re-installing them. so this morning, i unplug the harnesses from the back, then go to take out the harnesses, only one wire was still attached so i just pull it off. then i go to leave and lock my car.
the remote clicker wont lock the car. huh, w/e ill just lock it manually, batterys probly dead cuz its been lossig its distance. then just to check that did mess something up bad i get in the car, starts first time like normal, but now the clock and radio r dead.
so i uninstalled unworking gauges, disconect one wire and now my remote clicker, radio and clock are all not working. cant help but laugh at the situation cuz thats kinda funny. im gonna try reinstalling the gauges a little later but anyone got any other ideas about what i did?
never gonna mess with anything on this car again, ever.
BlowDro is offline   Reply With Quote
Old 02-15-2007, 11:45 AM   #2
jasonallenross
Member#: 125978
2002 WRX Wagon
Check the fuse?
jasonallenross is offline   Reply With Quote
Old 02-15-2007, 11:47 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
You probably blew a fuse - that's why it's always best to disconnect the battery before messing with electrics
UkNuck is offline   Reply With Quote
Old 02-15-2007, 11:50 AM   #4
BlowDro
Member#: 112116
2006 WRX
which fuse?
Old 02-15-2007, 11:54 AM   #5
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
most fuse panels have a diagram and there is ususally one labeled "clock/radio" or the other way around, most likely that one has been blown, not a huge deal, just check it out
clemsonteg is offline   Reply With Quote
Old 02-15-2007, 12:05 PM   #6
BlowDro
Member#: 112116
2006 WRX
what about the remote clicker? coincidence?
Old 02-15-2007, 12:09 PM   #7
ProoF
Member#: 140639
2007 WRX Impreza LTD
On a lot of cars, the radio and clock run on the same circuit so it's possible your grounded out one of the wires while disconnecting them. Probably just a 15-20 amp fuse that has to be replaced.
EDIT: Some remote starters have their own inline fuses under the hood of the car near the battery. Depending on what model you have, it could be under the hood or under the dash, generally around the steering column where the main Ignition wires are located.
ProoF is offline   Reply With Quote
Old 02-15-2007, 01:05 PM   #8
dibblejr
Member#: 94070
05 LGT
^^ As stated fuse. Your speedo ect. probably dont light up either.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-15-2007, 02:31 PM   #9
BlowDro
Member#: 112116
2006 WRX
well i swaped out the radio fuse on, nothing changed
Old 02-15-2007, 02:42 PM   #10
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Was the fuse blown, or did you just swap it?
02WHITEDUB is online now   Reply With Quote
Old 02-15-2007, 02:46 PM   #11
steep
Member#: 90890
2011 Brocoma
Silverstreak
More importantly you need to cover any bare wires or the fuse will continue to blow. Be careful with electrical doodads.
Car Fires FTL
steep is offline   Reply With Quote
Old 02-15-2007, 02:48 PM   #12
jasonallenross
Member#: 125978
2002 WRX Wagon
(If I remember correctly)
There is a "always on" circuit to keep the radio and clock going, and another to provide power/illumination to the actual devices themselves ... make sure you check both.
Also, check under the hood. This problem really sounds like something shorted and blew the fuse.
You know you should always disconnect the battery when doing electrical work, right? This is why --- I'm guessing that the hot lead was still hot, then it touched something metal, completed the circuit, sparky sparky and you are done. If there was no power to the system it would not have happened. I've gotten a few jolts, myself, so I don't try and "cheat" anymore, I always diconnect/turn the breaker off/check it with a meter to make sure it's dead.
Old 02-15-2007, 02:56 PM   #13
steep
Member#: 90890
2011 Brocoma
Silverstreak
double post oops
Old 02-15-2007, 03:42 PM   #14
BlowDro
Member#: 112116
2006 WRX
a blow fuse will rattle, the same way a blow lighbulb does, right? also can someone direct me to the fuse under the hood? i will go check the radio and the illu fuse now.
also like jay-r said, my gague cluster will not light up, yet stuff like the cel i have from my exhaust is still working.
Old 02-15-2007, 03:48 PM   #15
BlowDro
Member#: 112116
2006 WRX
check the illu and that one looks broken, not the radio one i checked and switched before, looks like i need to run and get a 10 mini.
i also tried re-installing the gauges to see if that maby helped the problem idk im desperate right now. would the blow illum fuse be reason that the none of the gauges functions worked? like the red blinking light.
Old 02-15-2007, 03:57 PM   #16
jasonallenross
Member#: 125978
2002 WRX Wagon
Get some extra fuses while you are there, you may possibly blow another testing stuff out, and they are cheap.
The descriptions in the fuse box should give you an idea of what goes where.
And settle down, it's probably just a fuse, the car is still running. If it's not, you can at least drive it to a shop and don't have to pay for a tow
Old 02-15-2007, 04:01 PM   #17
BlowDro
Member#: 112116
2006 WRX
well i put a new fuse in the illum, still nothing changed
edit
i check the box under the hood, that ones blow too
alteast i feel like im getting closer to solving my problem.
Old 02-15-2007, 04:31 PM   #18
disque71
Member#: 57330
2008 WRX
check both fuse boxes(in the engine bay right side and behind interior dash driver side)
disque71 is offline   Reply With Quote
Old 02-15-2007, 05:52 PM   #19
steep
Member#: 90890
2011 Brocoma
Silverstreak
If you haven't stopped the wires from grounding out the fuses will continue to blow. I didn't see from your original post where you had taped these up. Can you tell us more about what you have done/changed?
Old 02-15-2007, 06:03 PM   #20
BlowDro
Member#: 112116
2006 WRX
fixed, i found 3 blown fuses, 2 in the cabin and 1 under the hood. i give myself 1 banana.
Old 02-16-2007, 08:24 AM   #21
BlowDro
Member#: 112116
2006 WRX
i tried to hook the gauges up and im pretty sure they r wired correctly, is it possible my short out killed them?
Old 02-16-2007, 08:39 AM   #22
dibblejr
Member#: 94070
05 LGT
^^ Unlikely that a short killed the gauges. You may have wiring problems thats why you blew the fuses. (Thats what fuses are for to prevent damage to componets connected) Just dont get in a hurry and you will find your problem(s).
Jay-R
Old 02-16-2007, 08:42 AM   #23
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
im like 99% sure its a 10A fuse, and i bet anything its in one of the fuse boxes.
bhhamblin is offline   Reply With Quote
Old 02-16-2007, 09:00 AM   #24
dibblejr
Member#: 94070
05 LGT
Usually if you tapped where most everyone else taps then your speedo cluster does not illuminate.
Jay-R
Old 02-16-2007, 09:57 AM   #25
BlowDro
Member#: 112116
2006 WRX
i think u guys missread, i fixed the fuse problems, everythings back to normal. i blew the illum and radio fuses in the cabin and a clock one under the hood.
now my problem is the gauges seam to be dead, i think the short out killed them. is it possible to have them repaired? they are maddad v2
so what did you do in this heatwave today? this is what i did... shukes24 Mid West Subaru Owners Club Forum -- MWSOC 44 07-17-2006 03:39 PM
Okay, so what did brucelee do now? Full_Clip Off-Topic 9 04-02-2005 12:46 AM
UH OH! What did I do now. Hondaslayer Forester Forum 18 08-30-2004 09:46 PM
Wagon: What did I do now?? 4x4GGG Off-Topic 44 02-25-2004 04:33 PM
Ugh! What did I do now? Help needed...stripped threads in caliper Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 3 04-12-2003 11:53 PM
