Old 12-02-2001, 03:20 PM   #1
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
Default Hooked up my A/F gauge today.....
I just got done taking my car for a spin after I installed my A/F gauge. I noticed that the only time the gauge readings are constant is under WOT in which it reads rich which is normal to my understanding. When Im just at crusing speeds though the gauge bounces around A LOT from lean to stoich and doesnt stay constant by any means. Is this just the ECU relearning my driving or what? I just want to make sure my O2 sensor isnt cracked out and my wiring is fine. Thanks in advance for the help.
Kyle
MY98 Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 12-02-2001, 03:38 PM   #2
Silverscooby27
Member#: 9124
2014 335i xDrive
Sorry, I don't have a solution for you as I'm working on getting the A/F gauge + sensor mounted. But, I have a ? for you:
Did you mount an additional O2 gauge or did you use the second O2 sensor?
Silverscooby27 is offline   Reply With Quote
Old 12-02-2001, 04:11 PM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Kyle: it's all good. It's not learning your driving style - that's how it always runs under low loads. Enjoy.
S27: Kyle has a 1998 model that uses normal 0-1V O2 sensors front and back. They can work with the normal AFR gauges. The 1999 models should be the same as well.
-WaC
Wayne
wac is offline   Reply With Quote
Old 12-02-2001, 07:08 PM   #4
kelley nelson
Member#: 135
Some good reading in 'Halmeter Info':
<a href="http://www.twminduction.com/Catalogs/Catalogs.html">http://www.twminduction.com/Catalogs/Catalogs.html</a>
It explains in there why the meter sways back and forth from lean to rich. It's totally normal. The reading will only stabilize under 80% and greater throttle.
kelley nelson is offline   Reply With Quote
Old 12-02-2001, 09:42 PM   #5
Silverscooby27
Member#: 9124
2014 335i xDrive
My understanding was that the MY99 used the "wide-range" O2 sensor at the front, but the 0-1v after the cat (which would be useless for tuning). Can anybody confirm this?
hooked up my gauges now no radio... lennybootzz Electrical & Lighting 6 08-16-2009 02:49 PM
What wire to use to hook up my Air fuel gauge? BrysImpreza Forester Forum 3 02-22-2004 02:49 PM
How and where to hook up my air/fuel ratio gauge PumpsGOTAWD Electrical & Lighting 2 02-24-2003 09:33 PM
need help hooking up my gauges wrxxed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-13-2003 04:17 PM
Audio fool- can hook up my home entertainment system subwoofer to my car? desiwrx02 Car Audio, Video & Security 5 09-22-2002 10:13 PM
