Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 12-02-2001, 03:22 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Quick oil question, need quick answer.
Does the 4.5 quarts refill include the oil in the filter, or do you fill the filter and then put another 4.5 quarts into the engine? Thanks.
garface is offline   Reply With Quote
Old 12-02-2001, 03:37 PM   #2
au112
Member#: 4412
MY01 Impreza 2.5RS
BRP
I heard that it is about 4.4L in total
au112 is offline   Reply With Quote
Old 12-02-2001, 10:29 PM   #3
NotoriousWRX
Member#: 9026
That's the total amount, including what you put into the filter.
NotoriousWRX is offline   Reply With Quote
Old 12-03-2001, 03:36 AM   #4
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Isn't it 4.2 quarts?
CosmoTheCat is offline   Reply With Quote
Old 12-03-2001, 01:50 PM   #5
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Yes, it should be 4.2 quarts for MY00 2.5RS, and this includes the oil in the oil filter.
Richard L. is offline   Reply With Quote
Old 12-04-2001, 01:56 AM   #6
garface
Member#: 1581
MY00 RS/STi7
Doh, I forgot to take off the oil cap while draining. Does that matter? I only got 3 full to the top quart bottles out of the engine including the filter. I checked the oil right after a mild drive and it was up to the top part of the twist on the stick before it gets flat. The old dino oil looked like coffee, still somewhat transparent, is that good? Thanks fo all the help. Just started doing my own oil changes since I decided to go synthetic and didn't want to pay for it not even knowing what they actually put in.
Old 12-04-2001, 02:38 AM   #7
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
It is best to remove the oil cap before draining. Oil level on the dipstick will be inaccurate right after a mild drive since most of the oil is still up in the engine. You must allow sufficient time for all the oil to drain back down to the pan before checking oil level. Wait at least ten minutes after you shut off the engine before pulling out the oil dipstick.
Richard
Old 12-06-2001, 03:44 PM   #8
knightsnke
Member#: 9461
The shop put 5.5 liters in my wrx should i take some out?
knightsnke is offline   Reply With Quote
Old 12-06-2001, 03:54 PM   #9
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
knightsnke, check your owner's manual for the oil capacity for your WRX. Check your oil level. If it's too high, then drain some out. I still don't understand why some people do not bother to read the owner's manual.
Richard
A quick question. Need help answering! houstonwrx02 Texas Impreza Club Forum -- TXIC 5 07-14-2009 03:33 PM
oil change question need quick answer rex dorifto Newbies & FAQs 1 03-14-2004 11:21 PM
Quick Oil Question mr2guru Newbies & FAQs 3 10-06-2001 08:32 PM
Amsoil filter installed - dumb question needs an answer please Joe Lee Technical Forum Archive 3 06-29-2000 07:17 PM
