Old 12-02-2001, 02:28 PM   #1
rallysquirrel
Member#: 7006
2007 SpecB
Unhappy Wierd electrical issues
I've got a 97 Subaru Outback and i'm having the weirdest electrical problem.
Current situation
The left headlight shines at normal power
right headlight shines at half power
the BRIGHTS light is on inside the panel
This happened before and all I had to do was put in the new fuse for the right headlight. Both headlights would work and I could even use the fogs.
Now when I replace the fuse for the right headlight, the right headlight turns off.
When I just run without the fuse, right headlight is off, but as soon as I put in the blown fuse the right headlight sometimes works, soemtimes doesn't. If it does I can't turn on my fogs.
If the right light doesn't work I can turn on fogs.
Please help
Thinking it's an issue with the (in order of probability)
1. wiring harness
2. somewhere in the fuse box
3. headlight
rallysquirrel is offline   Reply With Quote
Old 12-02-2001, 11:18 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
The right low beam filiment is broken and shorted to the high beam filiment. Replace the bulb. All will be fixed. I've seen it a hundred times.
yamarocket630 is offline   Reply With Quote
Old 12-03-2001, 12:31 AM   #3
rallysquirrel
Member#: 7006
2007 SpecB
Thank you, I will try that
Wierd Electrical Issue. Loss of power over night. IHeartE30s Electrical & Lighting 9 05-12-2010 08:05 PM
wierd electrical demon... cocheeze 'Old School' Subaru Forum 10 09-15-2008 06:58 PM
Wierd AFR Issues. Swinging almost a full point. simon021 Open Source Reflashes 4 02-25-2008 03:06 PM
Wierd DCCD Issue BlueDominion Transmission (AT/MT) & Driveline 9 05-21-2007 12:45 PM
Wierd wierd boost issues! CoolRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2005 08:31 AM
