Old 02-16-2007, 12:09 PM   #1
NYCshopper
Member#: 5126
Default Honda A-VTEC Details Break Cover at USPTO
http://www.vtec.net/news/news-item?news_item_id=659664
Weve been hearing rumors of a next generation VTEC technology for years. In 2005, Honda finally confirmed that they were well along on the development path of their next generation Advanced VTEC (A-VTEC) system. Apart from promises of superior economy and performance, scant details were revealed. Our suspicions were that this would be a system that could continuously vary lift or duration (akin to BMWs innovative Valvetronic system), rather than using a stepped change as both VTEC and i-VTEC have used. As tidbits of information began to coalesce into a meaningful picture, some of our readers pointed us to a patent filed by Honda for a continuously variable lift system. After poring over the details of this public document, it would seem that the cat is out of the bag. With a high degree of certainty, we believe that this patent does indeed represent the next generation A-VTEC valvetrain technology.
As you can see from the drawings, the implementation of A-VTEC is classic Honda technological innovation. It is simple and compact, with a minimum of moving parts and easy adjustability. The key to the system lies in an innovative circumferential, cam-centric rotationally adjustable drum mechanism. To put it more simply, the intake camshaft (and the intake camshaft only in the proposed implementation) is surrounded by a drum that rotates around the same axis as the camshaft. The position of this drum is determined by a computer controlled gear.
What makes this rotating drum so important is what it carries a new intermediate rocker shaft that moves with the drum. Explaining the function of this drum is probably best done by first covering how a traditional valvetrain works. Take, for example, a traditional DOHC i-VTEC setup. A camshaft lobe acts upon a follower (underneath the cam). This follower (using a roller to reduce friction) acts upon the valve tip underneath it, often multiplying the lift of the cam through the use of a lever ratio. While various and sundry alterations have been made to such systems over the years, the basic principle is the same. The A-VTEC system changes things in several ways. First, the camshaft is located below the follower. While this is not novel, it is new for Honda DOHC engines (Honda SOHC engines typically locate the camshaft underneath a follower as well). Outside of some small changes in valvetrain mass and inertia, and cylinder head dimensions, this relocation of the follower isnt all that significant in and of itself. The significance all lies within the intermediate rocker shaft.
According to the technical drawings on the patent (which are not necessarily to scale of course), the intermediate shaft is able move on its drum over a range of about 45 camshaft degrees. Theoretically it could move by a much larger amount if so desired. This has two effects on valve timing. First, it alters cam timing by a similar amount (about 45 degrees in the case of the drawings). Second, it alters valve lift and duration. At one extreme (with the drum rotated fully counterclockwise in the illustration), valve lift and duration are minimized and valve opening is fully advanced. At the other, lift and duration are maximized and valve opening retarded. The variation in lift and duration between minimum and maximum positions is determined by the profile of the intermediate follower.
For anyone acquainted with the basics of camshafts, the benefits of such a system will be obvious. But in case youve never dealt with reading a cam card (like most of the population), heres a brief synopsis. First, advancing a camshaft tends to improve low end power. This is not a hard and fast rule, but a general principle that holds true over a wide range of conditions. Conversely, retarding a camshaft tends to improve high end power. Next, reducing camshaft duration tends to improve low end power, while increasing improves high rpm output. Advanced readers will have already noticed that the A-VTEC system alters both advance and duration simultaneously in a way that optimizes either low or high rpm performance. Finally, during periods of maximum advance and minimum duration (low rpm optimization), lift is also minimized (theoretically close to zero if desired). While lift variation is not the major factor in rpm optimization (more lift generally means more power everywhere), it is highly useful if you want to do something like eliminate the throttle (as BMW has done with Valvetronic).
So, now that we know the basics of A-VTEC, where, how and what can we expect from the application of this technology in real world Honda engines? First of all, the patent sheds a couple of clues for us. The first is in the specific language that outlines a single camshaft with both intake and exhaust lobes in other words, a SOHC engine. While it would seem unusual for Honda to take what most would deem a backward step, A-VTEC would seem to apply very well to a SOHC design. The timing variation on the intake valves would behave very similarly to the intake cam changes afforded on current DOHC i-VTEC engines. And the changes in lift and duration would offer peak output similar to that of current DOHC i-VTEC engines as well. Furthermore, the elimination of the second (high rpm) lobe on current SOHC VTEC engines would allow the implementation of 2-stage VTEC on the exhaust side instead of the current fixed (and compromised) exhaust profile on SOHC VTEC applications.
The patent is also quite clear that the specifics of the valvetrain geometry are not fixed to just those depicted in the drawings. This certainly leaves room for a DOHC application. In fact, if the cam timing functionality of A-VTEC eliminates the need for the VTC portion of i-VTEC on the intake side, we could see VTC being applied to the exhaust side of Hondas DOHC engines. Personally, I am not convinced that a performance application of A-VTEC could be maximized without VTC on the intake cam, but Ill defer to the expertise of the Honda engineers on that one.
Based upon what is known so far, we believe that A-VTEC will likely be applied in an economy application first. Whether this is in a SOHC or DOHC engine is up in the air at this point. But the elimination of throttling losses and the total control of lift and duration certainly makes Hondas claims of double digit gains in fuel economy over existing Honda engines believable. And, even in focused economy application, I see no reason for Honda to sacrifice any top end power. In fact, I foresee low and midrange torque gains with modest increases in high rpm power as being completely reasonable.
The more curious among you might want to know how A-VTEC compares to the only other continuously variable lift and duration system on the market today BMWs Valvetronic. While BMW certainly trumped the rest of the market on getting such a system into production, Hondas additional years of research seem to have paid off with several advantages. Take a look at the drawings here - http://www.bmwworld.com/technology/valvetronic.htm You will notice several things about BMWs application. First, Valvetronic increases the height of the valvetrain and cylinder head quite substantially. Second, BMWs intermediary actuator (I cant quite call it a follower) is quite large, adding extra moving mass in the valvetrain (perhaps explaining the rpm limitations of the first generation Valvetronic engines). Finally, BMWs implementation does not alter valve timing by moving the cam centerline. This means that in order to optimize low lift valve timing, BMWs VANOS VTC system _must_ be applied as well to advance valve opening. By comparison, VTC control seems far less critical on A-VTEC. So, in summary, reduced size, mass and self regulating VTC all would appear to be advantages of A-VTEC over Valvetronic. Of course, the proof is in the pudding. Or, as I like to say, implementation is more important than theory and we still need to see Hondas implementation. But based on past performance, I have little doubt that A-VTEC will be very effective.
A-VTEC will most likely first appear in the 2008 Accord, which makes the introduction of that model even more highly anticipated than it already was. We were also led to believe that A-VTEC will first appear on a 4 cylinder engine. Will it be SOHC or DOHC? Will it be a variation of the K-series or R-series, or a whole new engine? Perhaps most intriguing to me is whether or not this technology will appear on the J-series V6? If it works as predicted, the life of the J-series could be extended significantly. Class leading top end power could be matched with vastly improved midrange torque and fuel economy all while remaining smaller and lighter by virtue of using a SOHC design. Pay close attention in the coming months for official news from Honda on this exciting new technology.
NYCshopper is offline   Reply With Quote
Old 02-16-2007, 12:17 PM   #2
JoeyW
Member#: 100192
i
do
not
know
what
im
looking
at
JoeyW is offline   Reply With Quote
Old 02-16-2007, 12:26 PM   #3
registering
Member#: 89332
2007 Miata
Very cool. I've always been amazed VTEC/i-VTEC work as well as they do, due to the stepping of the adjustment with a pin(!). It'd be great if this leads to more power and fuel economy. If this DOES actually show up in the 2008 Accord it'd be great, as we're considering one of those....
registering is offline   Reply With Quote
Old 02-16-2007, 12:29 PM   #4
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
^what he said Willis^
I DO
nTO Kwno
wtah I
ma LokONig
At....
SubyDuz is offline   Reply With Quote
Old 02-16-2007, 12:32 PM   #5
drew510
Member#: 13319
2000 OBS stage MM
Sedona Red
All I know is that they better start producing stickers!!!
My A-VTEC is mad tyte yo! ;-)
drew510 is offline   Reply With Quote
Old 02-16-2007, 01:04 PM   #6
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
But now you won't be able to yell out "VTEC!!!" whenever you hit boost yo!
Capt Crunch is offline   Reply With Quote
Old 02-16-2007, 01:23 PM   #7
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
sure you will..
You will just have to start at idle!!
SCRAPPYDO is online now   Reply With Quote
Old 02-16-2007, 01:29 PM   #8
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Very interesting. Duel cam followers with the first one setting the range that the second one operates in. Bitch'n.
Now you can yell "Ahhhh-VTEC"
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 02-16-2007, 01:49 PM   #9
IronMike
Member#: 140917
v-TeC jusT kicKeD-In y0!
IronMike is offline   Reply With Quote
Old 02-16-2007, 01:59 PM   #10
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
gotta hand it to Honda -- that set-up is freaking brilliant!
this rates 3 disco monkeys!
Spenk is offline   Reply With Quote
Old 02-16-2007, 02:24 PM   #11
Lantec
Member#: 48685
2010 Prius
Well BMW and Porsche has had systems like those for years.
Lantec is offline   Reply With Quote
Old 02-16-2007, 03:41 PM   #12
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Porsche's Variocam Plus works basically just like VTEC (and VVTL-i, MIVEC, etc), there is a distinct cross-over point where there's a switch to a different cam profile. So far, only BMW's Valvetronic has the continuously variable lift.
BMW's Valvetronic seems more elegant, but also takes up more vertical room. I wonder how much trouble aftermarket tuners are going to have with the A-VTEC since the cam timing changes mechanically as the lift is changed.
For comparison...
Valvetronic:
Old 02-16-2007, 04:46 PM   #13
SublimeGTP
Member#: 5497
2003 WRX Wagon
This better than the BMW system, because all the components look compact and more importantly light. Valvetronic gets real expensive quickly (in HP robbing terms) as RPMs rise. Thats why all the Valvetronic engines have fairly low redlines, like the engine in the 4.4 V8 in the old 540i which made peak HP at 5400 rpms.
Like valvetronic the mpg improvement is because there's no throttle plate. Which I never understood why that helped, you're still creating a vacuum, its just restricted to the cylinder rather than the whole intake manifold.
SublimeGTP is offline   Reply With Quote
Old 02-16-2007, 04:57 PM   #14
ted dibiase
Member#: 94752
2003 wrx
wrb
E46s have an 8000 rpm redline.
ted dibiase is offline   Reply With Quote
Old 02-16-2007, 05:22 PM   #15
Len
Member#: 39937
2011 328i 6MT
LMB
No they didn't and they didn't have Valvetronic.
I see that A-Vtec lumps duration control with timing control, unlike Valvetronic which can adjust one independently of the other. But Valvetronic is too heavy and complicated while A-Vtec seems to be smaller and simpler. I'm guessing this will be another round of victory for Japanese efficiency over German over-engineering.
Len is offline   Reply With Quote
Old 02-16-2007, 06:56 PM   #16
Hazdaz
Member#: 14611
Yea, well German over-engineering is still better than American laziness or stubbornness.
Hazdaz is offline   Reply With Quote
Old 02-16-2007, 10:30 PM   #17
jsalicru
Member#: 58031
Yes, american engineering is very much Ripoff & Duplicate... and even then they don't get it right...
jsalicru is offline   Reply With Quote
Old 02-16-2007, 11:20 PM   #18
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
^ ROFL nice, display of american technology
SiFuSpEc is offline   Reply With Quote
Old 02-16-2007, 11:30 PM   #19
the real suby dude
Member#: 125497
02 Alpine White M3
Rouge Engineering !!!
instead of a diffrent kind of vtec ..why dont they make a turbocharged engine damitt
the real suby dude is offline   Reply With Quote
Old 02-16-2007, 11:38 PM   #20
Len
Member#: 39937
2011 328i 6MT
LMB
Well why don't you check out the Acura RDX damitt
Old 02-19-2007, 09:25 AM   #21
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Yeah.. the 'mericans ripped off the Germans when developing push-rod engines.
While I somewhat agree with your comment, it doesn't relate to the posted diagram at all.
Buick Business Hybrid Concept breaks cover in Shanghai - Details and Photo Gallery AVANTI R5 Non-Subaru News & Rumors 6 04-22-2009 12:32 AM
Fiat Bugster Concept to Break Cover at Sao Paulo Motorshow AVANTI R5 Non-Subaru News & Rumors 2 10-22-2008 12:21 AM
FS: 1994 Honda Prelude VTEC overdose Mid West Subaru Owners Club Forum -- MWSOC 5 01-26-2004 11:55 PM
98 Honda Prelude VTEC THAI Private Vehicle 'For Sale' Classifieds 0 09-19-2003 04:59 AM
Does Honda use vtec in F1? Gambit Motorsports 12 04-28-2001 01:54 AM
