Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 02-16-2007, 12:31 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default Loud screeching/metal grinding noise from passenger rear wheel!
so I notice today while commuting to work i hear a noise from the passenger side of my car. as traffic slowed down the noise became more prominent. i rolled my side windows down and i can hear this loud screeching noise. when traffic comes to a crawl i hear grinding noises like from metal to metal contact. it would go SQUEAK, grind grind, SQUEAK. after about 10 miles of this it went away. anybody know what the problem can be?
ASpec818 is offline   Reply With Quote
Old 02-16-2007, 01:39 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Checked your brake wear indicators?
UkNuck is offline   Reply With Quote
Old 02-16-2007, 02:19 PM   #3
ASpec818
Member#: 37059
03 WRX
World Rally Blue
i dont think its the brakes because it's only audible when you are moving. coming from a dead stop the noises would progress faster as you move. my foot was off the brakes and using it also didn't do anything to the sound.
Old 02-16-2007, 02:44 PM   #4
red5001
Member#: 33942
04.5 STI
wrb
My car did something similar only made a noise once in a while and not always when braking. usually when tunring or something. It was the rear inner brake bad was gone and just the backing plate was left.
Oh yeah I also had a problem after this on one of the rear rotors I put on. The little lip off the back of the rotor was rubbing on the dust shield. It only made the noise when I turned one direction and then it would make the noise at ramdom. A few wacks with a hammer to the dust shield and no problem. The rotors must have been slightly different then stock.
red5001 is offline   Reply With Quote
Old 02-16-2007, 02:47 PM   #5
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
i had a noise which was not metal though. It was a black piece of weatherstripping in the underside of the rear wheel well. Once, it came lose and hung down so the tire would scrape against it as it rolled.
it doesnt sound quite like your issue though,sorry
WRXDriftR is offline   Reply With Quote
Old 02-16-2007, 02:57 PM   #6
ASpec818
Member#: 37059
03 WRX
World Rally Blue
a did a little more searching and found out that some ppl reported rocks getting stuck somewhere in their brakes which led to the noises. Im hoping its just a rock that caused it to make that horrible grinding noise. will see if it makes anymore noises
Old 02-16-2007, 05:55 PM   #7
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Pretty common. Take rear calipers off, inspect, shake chit loose, reinstall. Usually works 90% of the time. Otherwise sitcky caliper...
REDrum is offline   Reply With Quote
Old 02-17-2007, 06:52 PM   #8
WRXPRESS
Member#: 393
1986 944T & Outback
Yellow & 99 Ducati 900ss
could be a wheel bearing...
WRXPRESS is offline   Reply With Quote
Low grinding noise from the front wheels slovak Brakes, Steering & Suspension 2 02-22-2009 04:39 AM
Grinding noise from passenger rear when turning slowly crofrog Brakes, Steering & Suspension 6 05-28-2008 03:54 PM
Sheer metal/metal grinding noise from tranny area digitaljigga Transmission (AT/MT) & Driveline 1 03-19-2007 10:58 AM
Loud humming noise from left rear wheel/suspension? S-1 Brakes, Steering & Suspension 1 05-23-2005 11:35 AM
Grinding Noise From Right Rear arbabp Brakes, Steering & Suspension 2 03-06-2004 10:47 PM
