Old 02-16-2007, 12:37 PM   #1
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Question Fix-A-Flat in cold temperatures...?
Has anybody ever tried using Fix-A-Flat in sub-freezing temperatures (around 10 to 30 degrees F)?
Does it work okay?
^For the effort...
GringoGomez is offline   Reply With Quote
Old 02-16-2007, 12:57 PM   #2
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Anybody?
Old 02-16-2007, 01:02 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
fix a flat doesn't do anything except destroy rims and tires
Old 02-16-2007, 01:03 PM   #4
Cole
Member#: 64219
2011 Outbackness
2008 Legacy NA Hellastock
You are a lazy bastard.
http://www.fixaflat.com/Contact.htm
Technical Assistance
800.416.1600
8 am - 5pm, Mon.-Fri. CST
Cole is offline   Reply With Quote
Old 02-16-2007, 01:04 PM   #5
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
.........so, that's a no?
Old 02-16-2007, 01:06 PM   #6
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
800.416.1600
Thanks, Chief! Their operators are not standing by...
Old 02-16-2007, 01:12 PM   #7
markman
Member#: 93623
i disagree... when I was dirt-broke-ass-poor trying to make it through school I at one point had ALL 4 of my cars tires filled with fix-a-flat... I drove it like that for months until I had enough cash to buy new tires.
When I brought the car in to get the tires put on the mechanic dude was all pissy with me because he had to basically unglue the tires from the rim
can't help you with the tempature thing though... that was in south florida where there is only one season.
markman is offline   Reply With Quote
Old 02-17-2007, 02:43 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
funny, i replaced a $178 tire tonight that had a puncture that was repairable because they put a $10 can of fix-a-flat in rather then pay $20 to have the tire fixed correctly
Old 02-17-2007, 07:25 AM   #9
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I agree, that crap is worthless. I'd rather drive on a flat tire.
subbyspeed is offline   Reply With Quote
Old 02-17-2007, 07:34 AM   #10
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
I'd rather use my puncture repair kit and fix it myself.
Quick, cheap, permanent.
rogue is offline   Reply With Quote
Old 02-17-2007, 08:22 AM   #11
Dick Fitzwell
Member#: 25684
That's your best bet. Said kits can be had at Autozone and Walmart so you really don't have an excuse (they aren't that much more than a can of fix-a-flat either). If you can't fix it with the kit (i.e. on the sidewall, etc) your best bet is to just replace the tyre. Also I have ran into problems with fix-a-flat throwing off the balancing and like others have already mentioned, the tyre-monkeys will hate you for it as it is a SOB to clean up.
Lastly I'd never use it in a set of rims I really liked regardless of the situation.
Dick Fitzwell is offline   Reply With Quote
Old 02-17-2007, 08:57 AM   #12
Hazdaz
Member#: 14611
And how exactly do you propose fixing a tire when you are stuck in the middle of nowhere after hours with no tire places even remotely close by??
You drive on a flat too long and changes are it might separate from the rim, causing lots more problems for you.
I always keep a can of the stuff in my trunk for emergencies.
Hazdaz is offline   Reply With Quote
Old 02-17-2007, 02:14 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
spare tires and plug kits are a MUCH better alternative...and plugs can even temporarily fix sidewall issues, at least long enough.
Everyone should have a small compressor and spare tire in the trunk.
Old 02-17-2007, 03:59 PM   #14
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Well, it worked... Then I drove it down to the Sunoco and put 40lbs of air into it. Did this yesterday and the tire looks healthy after a long cold stretch. My car was lodged in/on 8 inches of ice, so I didn't feel like trying to jack it up.
This is for a cheap studded snow on my stock rims. I'll ride them out for the season, but I will heed the advice of HndaTch627 and get an air compressor to tye down in the boot.
So, Fix-A-Flat does indeed work in cold conditions (around 20 degrados). Yay.
Old 02-17-2007, 05:21 PM   #15
thechickencow
Member#: 16840
14 Outback
Should work for the temperatures.
The guys that run screw tires use it to seal them up and tahts for ice racing. Thats my plan when I finish mine up since I think tubes would get torn up by the screw heads over time.
My work in progress:
thechickencow is offline   Reply With Quote
Old 02-17-2007, 09:03 PM   #16
Jessie James
Member#: 2072
To answer the question, you're supposed to warm the can up and then use it. Read the directions...
Jessie James is offline   Reply With Quote
oil temperature higher in cold ??? ronf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-18-2005 11:14 AM
Tires Plus Fixed a Flat and scratched my rims! What to do? ~GEO~ Brakes, Steering & Suspension 4 03-25-2003 01:47 PM
Fix-A-Flat in the Trunk? (combustion possibility?) NeoteriX Newbies & FAQs 4 03-14-2003 11:06 AM
Fixing a flat on Z-rated tire? zzyzx Brakes, Steering & Suspension 6 07-09-2001 09:52 PM
FIX-A-FLAT WARNING HRE | giulio General Forum Archive 15 05-26-2000 04:12 PM
