Old 02-16-2007, 02:27 PM   #1
niko01979
Member#: 140776
Default is there a way to tell if my sti is stage II
I purchased a used 05 Sti recently and it "came" with a full turbo-back cobb exhaust. I figure the guy that had the vehicle before me probably had some sort of EM with the turbo back (or i sure as hell hope so). I noticed very minute scratches right next to the OBD II port so i assume he may have used the access port with it, maybe. I guess my question is how do i tell if im stage II. The "butt" dyno wont work since i have not driven a stock STi. My car feel very fast, and I have not had a CEL light yet. I drive conservatively sometimes, but iv push it hard before. Any input would be appreciated.
niko01979 is offline   Reply With Quote
Old 02-16-2007, 02:54 PM   #2
aus_taz
Member#: 122895
1994 E36
2011 Ram 1500
It might have been tuned but the previous owner may have removed the tune before they sold it ie an accessport they could unmarry and then sell seperate, leaving you with the stock map but with scratches around the OBDII port.
A tuner could check your map for you, or try to install an AP and see what it says. If you have a boost guage that might give you an idea as well, if you are running stock boost or above.
aus_taz is offline   Reply With Quote
Old 02-16-2007, 02:55 PM   #3
dibblejr
Member#: 94070
73 DL Race Car
WRB/ Yellow SUby Logo
Stage 2 you need EM. Once you get that and put the stage 2 map on you are good. Right now you are at an untuned stage 1.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-16-2007, 03:03 PM   #4
nerdydorkus
Member#: 67062
ask a friend with a married accessport to plug it into your obII port. once you do that if it has a map on it already then it will show a bunch of functions like change map, read boost ect.
If he unmarried the accessport, leaving you with the stock map, then the accessport wont read any of that.
nerdydorkus is offline   Reply With Quote
Old 02-16-2007, 03:09 PM   #5
dibblejr
Member#: 94070
73 DL Race Car
^^ No it wont, unless you unmarry it from his car and marry it to your car. Each AP can only be used on one car at a time.
Jay-R
Old 02-16-2007, 03:20 PM   #6
Winner
Member#: 106050
- pm Josey Wales
OP: your gonna need some sort of EM anyways so just buy an AP and that will be the end of your search!
Winner is offline   Reply With Quote
Old 02-16-2007, 03:26 PM   #7
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
While EM would be very helpful and put a big smile on your face it is not necessary for STI's with a TBE. OL/CL issues are not a problem on STI's. You may experience boost creep though. EM however might not fix that issue.
brettm is offline   Reply With Quote
Old 02-16-2007, 03:37 PM   #8
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
boost gauge would be the easiest... check with a tuner... get a cable and pull the map, compare it to a stock map, or post it up and someone will tell you
ptirmal is online now   Reply With Quote
Old 02-16-2007, 03:43 PM   #9
niko01979
Member#: 140776
thanks for the responses guys. What is the stock boost on a sti in PSI and what should stage II boost reading be? I assume the guy that had the car before me unmarried the accessport (why would he not if he sold it), but i was wondering if he just left the map. Il try the boost gauge thing, when i get a boost gauge. However i would rather get some sort of EM before boost gauge anyways. Now if i could only find some cash!
Old 02-16-2007, 03:48 PM   #10
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
If you have a boost gauge, which you really should, do a WOT run in 3rd gear starting at 3K. Look to see what boost you're hitting. If you're hitting around ~17.5 psi, you're stage 2. If you're around 13psi, you're stock.
Ziggyrama is offline   Reply With Quote
Old 02-16-2007, 04:04 PM   #11
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
And we have a winner!
Yeah, what this guy said.
abosworth is offline   Reply With Quote
Old 02-16-2007, 04:11 PM   #12
waktasz
Member#: 86356
Tactrix cable plus logging plus saving your ECU map + enginuity forumz?
Cheaper/easier than a boost gauge and allows you to flash to stage 2 if you want to in the future.
You should still get a gauge though if you are modded.
waktasz is offline   Reply With Quote
Old 02-16-2007, 04:13 PM   #13
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
Yay, I won!!!!
So, what did I win? A cookie? Because if I did, I want that cookie......no, seriosly...I want it
Old 02-16-2007, 04:41 PM   #14
bugeye829
Member#: 81995
02 WRX Sedan
WRB Stage 2
just get a boost gauge to find out your max boost, it is the easiest way to tell if you're stage 2 or not. i was in the exact same situation as you a couple weeks ago, my car already had catless UP & DP and Prodrive exhaust but i didn't know if it had EM so i got a $20 boost gauge from autozone and hooked it up (doesn't take long, just tap into the vacuum line from the IM) and found out i was boosting stock so i am also saving up for EM to get to stage 2.
bugeye829 is offline   Reply With Quote
Old 02-16-2007, 04:46 PM   #15
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
My other suggestion is to post in your local forum and ask someone with a Tactrix cable to help you out. They can easily read your map and tell you if you're stage 2 or not. If you were local to me, so unless you're willing to take an extended road trip, ask your locals for help. I am sure someone will respond and do it for you.
Or, you could just buy your own for $90. Best money I ever spent. Well, almost...there was that one time....nevermind
Old 02-16-2007, 08:54 PM   #16
niko01979
Member#: 140776
I love this freakin forum. Thank you all, you guys are very helpfull. If any of you come through charleston and get a speeding ticket perhaps, hit me up and il take care of it. Il guess il suck it up and get a boost gauge just to have one, and then EM if I need it. I still need money though, anybody wanna buyt a used cat?
Old 02-17-2007, 04:45 PM   #17
whateverwrx
Member#: 99653
05 WRX
^^which cat is it you can bring it to a salvage yard and haggle for almost 70 bucks for it-cats are huge money in the junk world
if i may add my buddy has an STi (05) with a junkie downpipe and just a set of pulleys. he has a CEL and boost hits 16+psi no EM in this car. APs raise the max rpm also if you want to rev her up to fuel cut and record the engine speed- cobb used to have map notes on there site but now its changed alot.
also...did anyone say the words cobb or accessport to you when you bought the car? id check the ecu itself for any writing on it
whateverwrx is offline   Reply With Quote
Old 02-17-2007, 07:17 PM   #18
=LPR=
Member#: 127529
05 wrx
aspen white
try a 5th gear pull to about 6k. you may hit fuel cut there. thats where my buddies 06 STI hit fuel cut when he was catless before he had AP. (believe me you will know when you have hit it). CEL should come on along with cruise control and all that. you got to speed a bit but its an easy way to figure it out as well.
=LPR= is offline   Reply With Quote
Old 02-18-2007, 12:08 AM   #19
jdbewl01
Member#: 80541
2004 WRX
what kinds of things might you expect to see written on the ecu itself? my understanding is that cobb stopped selling their accessecu some time ago, and the accessport has nothing to do with any physical alterations of the ecu.
jdbewl01 is offline   Reply With Quote
Old 02-18-2007, 09:27 AM   #20
Imprezive_04
Member#: 104591
02 Zed06
08 Evo X
Just use ecuflash to compare the map on the ecu will the stock map which can be found very easily. Like said above cheaper than a boost gauge and logging will tell you much much more than 1 single gauge will
Imprezive_04 is offline   Reply With Quote
Old 02-18-2007, 11:09 AM   #21
waktasz
Member#: 86356
You can always just look at your boost tables in Enginuity...it will be obvious if it's not stock.
is there a way to tell if I need new top hats? SubeN'Siren Brakes, Steering & Suspension 4 07-15-2008 12:21 AM
Is there any way to tell what the motor is without the sticker? darksc00by Subaru Conversions 27 11-11-2007 11:03 AM
Photoshop gurus: is there a way to tell if a jpg was doctored? Snoopy Off-Topic 9 09-21-2007 01:46 PM
Is there a way to tell if I have synthetic in my motor now? Layman Off-Topic 15 10-05-2005 07:17 PM
Is there a way to test if my USB connections are hooked up? Stroke Off-Topic 9 04-14-2004 11:49 AM
Message Board Statistics All times are GMT -4. The time now is 02:17 PM.
