Old 01-11-2016, 03:26 PM   #1
Siouxbie
Member#: 383867
2013 WRX
PBP
Default 18x8 on a GR chassis?
Hi, I'm fairly new to aftermarket rims and would really appreciate your advice! I am looking at a set of 18x8 RPF1's for my 2013 WRX hatch. The stock wheels are 17x8 and the STi comes with 18x8.5. So I am wondering, is there any negative effects to using an 18x8 rim on the chassis when an 18x8.5 is the stock size?
Thanks for your help!
Siouxbie is offline   Reply With Quote
Old 01-11-2016, 11:17 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Probably the only negative effect, if you can call it that, is that your tire width selection would be a little more limited with 8" wheel vs 8.5". If you're fine sticking with 235 or 245 section width tires (same as your stock 17s or 10mm wider) then it's nothing to worry about.
Old 01-13-2016, 10:27 AM   #3
Spinnich
Member#: 348275
2012 Impreza WRX Sdn
WR Blue
It's all important to educate yourself on wheel offset and how changing that along with the wheel width may affect your suspension geometry and potential clearance issues.
Spinnich is offline   Reply With Quote
