Old 04-26-2008, 09:14 PM   #551
Donzo
Member#: 95337
2012 Jeep Overland
Donzo is offline   Reply With Quote
Old 04-26-2008, 10:44 PM   #552
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
haha d'oh! I certainly think your bronze looks waaaay better than the original. it was just too close to gunmetal with a bronze tint. now it's more gold-ish, which I really dig. that's what I was going for, but they came out more brown than intented. I think it's the reddish-brown primer I used. next time ... more coats!
2point0 is offline   Reply With Quote
Old 04-27-2008, 03:18 AM   #553
NorCalSubie07
Member#: 156751
07 LMTD sti #359
anyone have pics of 06/07 stock wrx wheels painted black with wrb lip?
NorCalSubie07 is offline   Reply With Quote
Old 04-27-2008, 11:00 AM   #554
RobE
Member#: 114550
yes..
RobE is offline   Reply With Quote
Old 04-27-2008, 12:50 PM   #555
NorCalSubie07
Member#: 156751
07 LMTD sti #359
haha ok then, can i see a pic of them?
Old 04-27-2008, 01:51 PM   #556
RobE
Member#: 114550
sure...
Old 04-28-2008, 12:12 AM   #557
NorCalSubie07
Member#: 156751
07 LMTD sti #359
well i saw this but its photoshopped, its gets the idea across though. thanks.
Old 04-28-2008, 10:37 AM   #558
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
MS paint FTW!^^^^
phoenix_wrx is offline   Reply With Quote
Old 04-28-2008, 02:12 PM   #559
Donzo
Member#: 95337
2012 Jeep Overland
Thanks! I will post pics of them on the car once it stops raining out.
Old 04-28-2008, 03:46 PM   #560
misterwaterfallin
Member#: 101091
finally got these mounted and on the car. the pics are horrible and there a lot brighter in real life. the orange came out sick
and evidentially i dont know how to size pics properly but go to the link if you want full size
misterwaterfallin is offline   Reply With Quote
Old 04-28-2008, 04:18 PM   #561
RobE
Member#: 114550
^^^ what link?
Old 04-28-2008, 04:32 PM   #562
Nick-subiefan
Member#: 164500
2004 WRX
This great thread inspired me to paint the stockers of my 04 WRX Sedan. So as soon as got my summer wheels installed and the stock ones were with the tires removed I started painting them. I painted them Black Night Metallic with a chrome lip (witch turned out more like silver lip after I applied the clear coat). Anyway they turned out way better than I expected. I’ll post pics as soon as I download them from my camera.
Great thread with a lot of great info and great ideas to change the look of our cars.
Thanks guys for posting your work and I’ll do the same for the next ones to come after me.
Nick-subiefan is offline   Reply With Quote
Old 04-28-2008, 05:43 PM   #563
Nick-subiefan
Member#: 164500
2004 WRX
As I was thinking to go all the way with painting my wheels (front and back with lip and clear coat on top) I took my time doing this.
For the whole project I used the following:
-3” fine coarse wire wheel on a power drill – 1 piece
-320 sand paper – 3 sq ft
-800 sand paper – 2 sq ft
-3/4” wide painters tape – 1 roll
-2” wide painters tape – 2 rolls
-Dupli-color sandable primer (DAP 1692 Gray Hot Rod Primer) – 3 x 12oz cans
-Rust-oleum Metallic (7250 Black Night Metallic) – 4 x 12oz cans
-Dupli-color Chrome (CS101 Chrome Spray Enamel) – 1 x 12oz can
-Dupli-color High Performance Wheel Coating Clear (HWP 103) – 3 x 12oz cans
-Cloth towels and protecting paper.
I removed the tires, valve stems and center caps to begin with.
First I started by cleaning the back/inside of the wheels with a wire wheel (3” fine coarse from Home Depot) mounted on a 18V cordless drill (I recommend a corded drill since I had to charge the battery twice/wheel)
Than I used 320 sand paper on the back and front of the wheel to break in the glossy paint and also to remove the stains and dirt. I did not wash them after the sanding process. I only wiped them clean of dust with cloth towel. If you wash them you have to rinse them very good so no soap will dry on them.
Than I used 2" wide Blue painter’s tape to protect the area you don’t want painted and started with primer. I did 3 coat of primer on the back of the wheel 15-20min apart (depending on the air temperature and humidity) and gently sanded the primer with 800 sand paper before each coat to get a smooth surface and cover small scratches. Let dry before I flip over the wheel and did the same with the front. I let them dry/cure for 24 hours before I sand again and apply the paint.
... to be continued in the next post ...
Old 04-28-2008, 05:50 PM   #564
Nick-subiefan
Member#: 164500
2004 WRX
... continued ...
I started applying the paint on the back side of the wheel first. I did 3 coats 15-20 min apart and gently wiped the surface before each coat to ensure smoothness. Let dry, flipped over and did the same with the front of the wheel.
I let it dry for 24 hours before I lay the protection for painting the lip. Here is where I used the 3/4” wide tape to separate the lip from the rest of the wheel. Protect everything but the lip and applied 2 coats of primer and 2 coats of chrome paint 15-20min apart. Let dry 24 hours before removing the protective tape for the lip (not the rest of the protection) and applied 3 coats of clear coating on the back of the wheel and after dried I did the same on the front. Let dry for 24 hours before handling and enjoy. I will let dry/cure for a few months until I install tires on them since they are my winter set.
I did the same with the removed center caps.
Old 04-28-2008, 05:54 PM   #565
Nick-subiefan
Member#: 164500
2004 WRX
... continued ...
I hope this gives you an idea of how much work is needed and how they look before/after.
Before:
After:
Do not forget to use clean paper every time you flip over the wheel so you don't scratch the primed/painted surface (specially the front side).
Thanks for reading this ,GOOD LUCK with your projects and keep posting them.
What do you guys think of these going on a PSM 04 WRX. All feedback is welcome. Thanks guys.
Old 04-28-2008, 06:00 PM   #566
Nick-subiefan
Member#: 164500
2004 WRX
I think the lip will look even better after the tire is installed.
Unfortunately they are my winter wheels and we will not be able to see them on the car until I get my winter tires (when the winter comes).
Old 04-28-2008, 06:09 PM   #567
strew3
Member#: 82834
2012 Toyota Tundra
Super White
very very nice work. they should look very good going on a psm wrx. I am hoping and planning to paint my stockers midnight black metallic this summer while they are sitting in the garage. I might not take the wheels off though and just mask them and the valve covers off for the painting.
strew3 is offline   Reply With Quote
Old 04-28-2008, 06:13 PM   #568
Nick-subiefan
Member#: 164500
2004 WRX
Thanks.
I took my tires off the wheels since they needed to be replaced and it was a good time to have the wheels painted.
Good luck with yours.
Old 04-28-2008, 06:21 PM   #569
strew3
Member#: 82834
2012 Toyota Tundra
Super White
thanks. I'll definitely get them posted up once they get done sometime in the next month or so. gotta finish the semester before I get started on them.
Old 04-28-2008, 11:03 PM   #570
Donzo
Member#: 95337
2012 Jeep Overland
So, how about you follow the first post in this thread and tell us what paint you used?
Looks good though, A+ for originality.
Old 05-01-2008, 04:01 PM   #571
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Wheels and tires are getting mounted right now. As long as they don't butcher any of the wheels I will be putting them on tonight. I can't wait to see how they look on the car!!
-Rene
Rene2.5RS is offline   Reply With Quote
Old 05-01-2008, 04:07 PM   #572
strew3
Member#: 82834
2012 Toyota Tundra
Super White
can't wait to see them rene
Old 05-01-2008, 05:45 PM   #573
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Yeah!
-Rene
Old 05-01-2008, 10:17 PM   #574
strew3
Member#: 82834
2012 Toyota Tundra
Super White
very slick. looks awesome.
Old 05-03-2008, 11:10 PM   #575
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Thanks I think so too. Unfortunately I need to give my exterior some tender loving. I just put the rebuilt engine in 2 weeks ago after the car has sat for 2.5 months and now is begging for a detail.
I am also surprised that no one else had made any comments as quite of few people asked to see picture of the wheels mounted on the car.
-Rene
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 08:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 07:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 12:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 02:35 PM
