Old 08-16-2010, 09:06 PM   #1451
BrownyHound
Member#: 250295
2010 Outback Sport
Hey guys. Thinking about painting my stock OBS wheels black. I'm leaning more towards flat black, but i thought i'd get a general consensus first. Flat or gloss?
And if i were to go for the flat look, what would i need to do as far as technique and/or product that i use. Like is there a type of paint or clear coat that gives more of a matte finish?
Sorry if i sound like a n00bz0rz. I am. I've only had the car for like 2 months.
BrownyHound is offline   Reply With Quote
Old 08-18-2010, 08:26 AM   #1452
mailnome
Member#: 235305
2002 blob swap wrx
was wrb
Here's mine. Wasn't really trying to match the stock color but it is hard to tell the difference. Out of like 15 silver colors to chose from at Advance Auto, I chose Platinum Silver Metallic. I wet sanded first with 400, metal etch primed, re-sanded, painted, and then got my body shop guy to clear coat. The stock 06-07 WRX wheels are worse than my 02-05 WRX wheels. Just primer on the back, no paint, and no clear from factory.
My untouched spare on left above and below.
mailnome is offline   Reply With Quote
Old 08-27-2010, 12:57 AM   #1453
mrandersonwrxman
Member#: 206022
2005 STI
CGM
06/07 Stock WRX TR Rims
3 coats of Rustoleum Midnight Black Metallic
2 coats of Rustoleum Clear Coat
Only prep work was sanding , no primer
mrandersonwrxman is offline   Reply With Quote
Old 08-27-2010, 09:29 AM   #1454
cueball89
Member#: 90513
Anybody use VHT engine metallic gold flake (SP404) yet?
cueball89 is offline   Reply With Quote
Old 08-29-2010, 11:28 PM   #1455
Aydin
Member#: 223305
2003 WRX
JDM STi 2.0l
Diamond Grey version 7's
Aydin is offline   Reply With Quote
Old 09-30-2010, 05:35 PM   #1456
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Default MY02 OEM color change
Well, I found a deal on 6 OEM wheels a while back. They're 16", but will be prefect for winter. I found some tires to suit the needs of our winters, Michelin X-ICE 225/50/R16 (physically same height/width of stock 225/45/R17). They are a little wide for the 6.5" 16" wheel, but should be fine, especially since I got a good rebate on the Michelins. I tried to match the factory color of my MY10 WRX wheels as close as I could. "Graphite" was the most plentiful. So, after about $35 worth of primer, paint and clearcoat; $200 worth of TPM sensors, and ~$500 worth of tires, I have my winter set ready to go!!
Before (spare 2 wheels/tires)
Primer after 3 coats!
Graphite paint after 3 coats!
Clearcoat after 2 heavy coats!
Inside of wheel (no clearcoat)
Centercaps after paint and clearcoat
Ready to be mounted!
Only thing left is to do is a little finishing touches to the center caps. I'm thinking of filling in the "Subaru" with blue to match the car color. Won't be long before they will need to be put on. Cold weather's coming fast! I just installed mudflaps last night. I'll have a picture show of them in the "interior/exterior" forum.
ki4syr is offline   Reply With Quote
Old 09-30-2010, 05:44 PM   #1457
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
great job, brother. don't forget to show us how it turns out with them mounted.
I need to start working on my winters as well...
kenliu84 is offline   Reply With Quote
Old 10-05-2010, 10:40 PM   #1458
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
anyone have a 08+ 2.5i sotcker painted black? I was thinking about doing this. Wanted to know how it would look. Color of the car doesn't matter but silver would be prefered
Help I'm Stuck! is offline   Reply With Quote
Old 10-07-2010, 03:34 PM   #1459
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Winter mode coming soon....
Uploaded with ImageShack.us
DrDanimalSize is offline   Reply With Quote
Old 10-11-2010, 12:43 AM   #1460
killaforniakrystinax
Member#: 180822
1997 vw <3
mean green
Originally Posted by PARANOID56 View Post
1. cleaned rims
2. sanded rims
3. cleaned rims again
4. masked rims
5. painted rims with green hi temp (engine) paint. put 4 coats on them
6. let them dry.
7. enjoy
i loove this car <3
killaforniakrystinax is offline   Reply With Quote
Old 10-19-2010, 06:46 PM   #1461
armadatilem
Member#: 252270
2011 WRX 5dr Premium
If I want to paint a set of 02 wrx wheels gold, should I paint them white first and go with the primer, gold and clearcoat ?
armadatilem is offline   Reply With Quote
Old 10-22-2010, 05:30 PM   #1462
Twister
Member#: 238715
2004 STi
No, you don't have to do that. If you want them to be a bright gold, make sure you use a light colored primer.
Twister is offline   Reply With Quote
Old 10-23-2010, 05:02 PM   #1463
m0isturizer
Member#: 225193
08 sti
spark silver
Default sticky weights
Anyone have issues with sticky weight adhesion to a diy painted wheel? thinking of painting my bbs wheels but wondering if i should just do the face or remove the existing sticky weights and do the inside as well.
m0isturizer is offline   Reply With Quote
Old 10-23-2010, 06:27 PM   #1464
armadatilem
Member#: 252270
If I want a normal gold like the stock BBS Sti or something like this..., which primer colour should I check for ?
Old 10-26-2010, 01:32 PM   #1465
m0isturizer
Member#: 225193
08 sti
spark silver
anyone? i want to paint the inside of the wheel but afraid of the stickies peeling off. i'm guessing with proper prep/painting the stickies will stay on?
Old 10-26-2010, 02:00 PM   #1466
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
You should have no problem with the weights coming off, you may have a problem with the paint come time to take the weights off.
I have been running stick on weights for 2 years on self painted wheels with no problems
Rene2.5RS is offline   Reply With Quote
Old 10-27-2010, 03:56 AM   #1467
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Here you go! Nice and tiny wheels!
Old 10-27-2010, 01:42 PM   #1468
CTsubyRS
Member#: 181352
2005 Impreza RS
Hey guys, so I'm going to paint my stocks flueorescent yellow in a few weeks. I have to take my summers off of them and put on my winter wheels. Should I take the summers off, paint them, and then get the winters put on. Or should I get the winters put on than paint them. Thanks
CTsubyRS is offline   Reply With Quote
Old 10-27-2010, 01:42 PM   #1469
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
What kind of wheels are these?
I'm finding that I love 16x7 wheels. Slap the right tire on there and it's the most versatile combo... just like the car. It can do DD commute in comfort, or track day (summer tire), or spontaneous romp on the dirt (all season/winter/etc)
chimchimm5 is offline   Reply With Quote
Old 10-27-2010, 01:51 PM   #1470
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
They look like late 90's Legacy wheels
Old 10-28-2010, 12:38 AM   #1471
armadatilem
Member#: 252270
Are those product would work good ?
Primer = Dupli-Color Primer Sealer
Paint = Dupli-Color Gold
Clear = Dupli-Color Acrylic Enamel or Clear Wheel Coating
Do I need to sand after some coat of primer ? or just before...
And sorry guys to ask you that, but here where I live they don't have those exact products. But in a week im going in Maine for a trip. Do someone know in which store I can find those things ?
Thanks !
Old 10-28-2010, 06:50 PM   #1472
armadatilem
Member#: 252270
Someone ?
I don't know in which stores I can get that in the US.
Old 10-28-2010, 10:09 PM   #1473
DrDanimalSize
Member#: 254097
2010 2014 Impreza
That stuff would work fine, my Quebec friend! The more you sand, the smoother it will look. I went with a 'hammered' finish so that it is rougher, and therefore hides the imperfections more.
Old 10-29-2010, 10:15 AM   #1474
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Someone ?
You should be able to buy these paints in the US at a chain automotive store such as, Pepboys, Autozone, Advanced Auto Parts
Old 10-29-2010, 03:07 PM   #1475
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Yup, they're Legacy GT wheels form a '99. 16x6.5 actually.
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 08:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 07:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 12:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 02:35 PM
