Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-23-2011, 06:00 PM   #1526
rymaggi
Member#: 253442
Originally Posted by DrDanimalSize
Good lookin' wagon you got there!
Thanks you.
rymaggi is offline   Reply With Quote
Old 03-28-2011, 12:46 PM   #1527
Leemu
Member#: 252964
02 WRX
Picked a set of Team Dynamics over the weekend and fixed the awful white that they were.
Leemu is offline   Reply With Quote
Old 03-28-2011, 12:50 PM   #1528
Donzo
Member#: 95337
2012 Jeep Overland
I need to respray them again. They're all chipped and curbed from taking a beating this winter. Also because I literally just sprayed them in a rush. No sanding, no primer... just sprayed them. I think this is the 4th paint job they've had.
Donzo is offline   Reply With Quote
Old 03-31-2011, 01:14 AM   #1529
FIFTHGEARCHRIS
Member#: 237092
2003 Wrx
Sonic yellow
Below are some pictures about half way through the job, completed & ultimately on the car (which by the way is an 03 sonic yellow wrx). The whole process took me 2 and a half days and 2 coats of primer (white valspar), 3 base coats (rustoleum antique bronze metallic) & 3 coats of clear enamel (take your pick).
The process I used for polishing the lip was 150, 220, 330, 600, 1000 fine grit sand paper & finished up with a high speed buff (dremel tool) with a metal polishing compound.
FIFTHGEARCHRIS is offline   Reply With Quote
Old 04-05-2011, 02:53 PM   #1530
Pomones
Member#: 215716
1993 impreza sedan
Flat black
krylon paint: peekaboo blue
Pomones is offline   Reply With Quote
Old 04-06-2011, 08:12 PM   #1531
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
so i am about to do this for the 2nd time, and think I will change up how I do it. I am going to sandblast rims, then self etching primer, then mount and balance, krylon, and clear. The mounting equipment chipped everything on me last time.
Anyone else have the same issue?
phoenix_wrx is offline   Reply With Quote
Old 04-06-2011, 08:33 PM   #1532
Donzo
Member#: 95337
2012 Jeep Overland
DO NOT sand blast. You want to media blast. Sand blasting will eat into the metal and give the wheels rock-like texture. Ask me how I know...
Old 04-09-2011, 10:00 PM   #1533
scoobycoupe
Member#: 277567
99 2.5 RSti
06 LGT S2
I picked up some 03 wrx wheels for a buck fifty and powder coated them at work. Just media blasted the wheels first and used some scuff pads to prep them a little before powder.
http://i1181.photobucket.com/albums/x432/scoobycoupe1/sub1.jpg
these are some icw wheels the car came with that im in the process of spray bombing but im back and fourth with so many colors.
http://i1181.photobucket.com/albums/x432/scoobycoupe1/sub2.jpg
http://i1181.photobucket.com/albums/x432/scoobycoupe1/sub3.jpg
anyone have any suggestions?
scoobycoupe is offline   Reply With Quote
Old 04-09-2011, 11:25 PM   #1534
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
What kind of media? I just want to avoid using sandpaper/sand sponges again. My wrists cant take it.
Old 04-10-2011, 04:06 PM   #1535
Donzo
Member#: 95337
2012 Jeep Overland
Look it up. I think it's some sort of plastic bead that they use instead of sand which is super harsh and pit the metal.
Old 04-10-2011, 07:16 PM   #1536
scoobycoupe
Member#: 277567
99 2.5 RSti
06 LGT S2
At my shop we use glass bead media for the blaster it did good work on my 03 stockers
Old 04-12-2011, 05:48 PM   #1537
GrindingGears
Member#: 196637
How much are you guys sanding down the wheels before primer? I started work on a set of wheels and it took forever to get one wheel sanded. All the nooks and crannies were a PITA.
I'm considering get them media balsted instead of wasting 5+ hours of my time.
GrindingGears is offline   Reply With Quote
Old 04-12-2011, 09:38 PM   #1538
scoobycoupe
Member#: 277567
99 2.5 RSti
06 LGT S2
Just sand the wheels until you get down to the stock gray base coat you dont need to go down to the bare metal unless you really hate having functional fingers. sand with a rough (150) grit and then use a 300ish grit after that, as long as its nice and smooth to the touch the primer will cover up anything else you didnt.
Old 04-12-2011, 10:37 PM   #1539
moneymike1988
Member#: 201338
2007 STI
So how long are this paint holding up for you guys before respraying/touchup? Thinking about this over powdercoat for affordability.
moneymike1988 is offline   Reply With Quote
Old 04-12-2011, 10:48 PM   #1540
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
mine lasted without chips until I mounted a new set of tires, then the mounting equip chipped and scraped it. I am now redoing it ~3 years later.
Glass beads are what I happened to buy, 20-30 grit. Not going to bare metal either, just down to the gray (or past my last coat of primer). Then a light sanding to smooth it out and reprime. One rim down, 3 to go
The first time I did this, it took me the better part of an entire weekend. Blasting should make all prep only take about 4 hours.
Old 04-12-2011, 10:53 PM   #1541
moneymike1988
Member#: 201338
2007 STI
Awesome, I have some stock 02 UK oem rims I wanna paint, so what sandpaper do you recomend me? I wanna get ur choice since urs lasted 3 yrs! Ill post pics when im done too I wanna do bronze! Thanks
Old 04-12-2011, 10:55 PM   #1542
moneymike1988
Member#: 201338
2007 STI
Also should I take the tires off first, cuz I should prolly pain the inside of all the wheel too right?
Old 04-13-2011, 02:24 AM   #1543
GrindingGears
Member#: 196637
Ended up stripping versus sanding. My fingers, hands and wrists had enough.
Used: http://www.wmbarr.com/product.aspx?catid=72&prodid=117
Goop this stuff on, wait 15 minutes, scrap away. Done.
Old 04-28-2011, 10:35 PM   #1544
Oceans05
Member#: 263977
2011 WRX
yahoooooooooo!!! am i the first?!? came out pretty darn good!
got bored on my week vacation... two days of work
Oceans05 is offline   Reply With Quote
Old 04-28-2011, 10:51 PM   #1545
Donzo
Member#: 95337
2012 Jeep Overland
It would be cool if you didn't post tiny thumbnail photos.
Old 04-28-2011, 10:53 PM   #1546
armadatilem
Member#: 252270
2011 WRX 5dr Premium
That looks so good! Like stock!
armadatilem is offline   Reply With Quote
Old 04-28-2011, 10:54 PM   #1547
Oceans05
Member#: 263977
2011 WRX
fixed
Old 04-28-2011, 10:57 PM   #1548
Donzo
Member#: 95337
2012 Jeep Overland
Nice! Looks great! What paint did you use?
Old 04-28-2011, 11:09 PM   #1549
Oceans05
Member#: 263977
2011 WRX
Rustoleum Metallic Bronze from HD as you did
Old 04-29-2011, 12:47 AM   #1550
moore.jeff54
Member#: 218149
2009 Impreza 2.5i
how exactly did you do it? Like what steps did you take?
I want to paint mine gold and yours came out amazing, so when I get around to tackling it I just want to have an idea of what really works
moore.jeff54 is offline   Reply With Quote
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 09:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 08:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 08:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 01:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 03:35 PM
