Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Legacy Specific Parts
Old 02-17-2007, 11:22 AM   #1
OZrally
Member Sales Rating: (4)
Member#: 40952
1999 Legacy GT Lim
Default 06' STi Front and Rear Stock Swaybars
I was wondering if the front and rear stock swaybar from a 06 STi would fit my 99 legacy GT??? Also if it dose would it make that much of a difference? Thanks,
Kelsey N.
OZrally is offline   Reply With Quote
Old 02-17-2007, 11:38 AM   #2
ten80
Member Sales Rating: (124)
Member#: 53625
00 16' FXT
front won't fit because it's specific for the turbo crossmember. I'm not sure about the rear, I do know that it fits imprezas of the same vintage as your car. It would make a HUGE difference as the 20mm (AFAIK) rear sway is much stiffer than your stock 13-16mm bar (unsure of actual size, but it is very small).
ten80 is offline   Reply With Quote
Old 02-17-2007, 01:22 PM   #3
OZrally
Member#: 40952
1999 Legacy GT Lim
Ok, Hey thanks for the quick answer!!!
Old 02-17-2007, 03:21 PM   #4
that one legacy
Member Sales Rating: (1)
Member#: 103665
what if he gets a cross member from a WRX or STi though? anyone know if it will fit then?
as far as the rear, if that one won't work, you can always go with a '97-'99 outback rear sway, which is an 18mm unit.
that one legacy is offline   Reply With Quote
Old 02-18-2007, 04:58 AM   #5
jamal
Member Sales Rating: (6)
Member#: 71875
98 Legacy GT
my wheels fit
no neither will fit. The front bar gets in the way of n/a exhaust, and is the wrong length/width. The rear bar is also too wide because the STi has different lateral links.
jamal is online now   Reply With Quote
Old 02-18-2007, 06:28 AM   #6
Kraziken
Member Sales Rating: (3)
Member#: 38629
1999 Legacy GT (STI)
I have a turbo crossmember and I'm running a Perrin WRX front swaybar.
Kraziken is offline   Reply With Quote
Old 02-18-2007, 06:31 AM   #7
rougeben83
Member Sales Rating: (62)
Member#: 115154
2005 Outback XT
White on grey
Running the turbo x-member precludes you to use the turbo front swaybar too.
rougeben83 is offline   Reply With Quote
Old 02-18-2007, 07:26 PM   #8
that one legacy
Member#: 103665
so then from what i gather, the WRX front sway will work if you also swap to a WRX crossmember, but the STi one just won't fit period?
Old 02-18-2007, 08:18 PM   #9
jamal
Member#: 71875
98 Legacy GT
my wheels fit
WRX wagon, sedan, and STi swaybars are all different lengths I think. Unless you swap crossmembers and control arms for that correspoding car, the swaybar will not line up with the endlinks.
WRX wagon control arms are the same as gc arms but the wrx front bushings are wider.
People have gotten STi and Tribeca (25mm n/a) bars to fit on a narrower tracked car by putting the swaybar on the outside of the endlinks. As long as the links are vertical and it doesn't rub I don't see that being too much of a problem.
Old 02-19-2007, 07:43 AM   #10
ten80
Member#: 53625
00 16' FXT
ok, swapping the cross member to install a sway bar is ridiculous. That's a hell of a lot of work, time, and potentially money wasted, since you also have to get a cross-member and will need an alignment afterwards. Not to mention that I think the diameter of his front sway bar is already 19 or 20mm, so an STi bar would not be an upgrade. If you want less front roll, why not do it the simple way and get an aftermarket GC sway bar? they fill fit with no modifications and are available in a variety of diameters. I'm pretty sure that a wrx/sti sedan rear sway will fit and some came in 20mm diameter, which makes a hell of a big difference over the stock 13mm bar.
FS: (PA): MINT 06' STI front and rear seats.STI gauge cluster,STI titanium shift knob EklipzGSXkid Interior/Dressup/Audio & Security 23 12-03-2009 05:41 PM
FS: 06 sti 20mm rear swaybar with sti front and rear swaybar bushi nelli-son Suspension/Brakes/Handling 1 09-21-2008 10:37 AM
FS: Stock 2005 STi Front and Rear swaybars with mounts and endlinks Computergeek24 SCIC Private Classifieds 4 07-18-2007 12:11 PM
FS: SoCal Stock 2005 STi Front and Rear swaybars with mounts and endlinks Computergeek24 Suspension/Brakes/Handling 0 07-16-2007 10:02 PM
front and rear stock swaybar sizes quazimoto Brakes, Steering & Suspension 4 06-19-2005 08:26 AM
