#1 |
Member Sales Rating: (463)
Member#: 3310
South East
Updated: 3/9/09 This is the most current post that says what is and isn't available, READ it. If you pm me asking me for something that has already been sold, then you obviously didn't bother checking the list and I'm going to delete your pm.
This is a complete part out of an 02 wrx that was wrecked in the front, so there are TONS and TONS of OEM parts. Please read this before asking what I have. Pics are below (note that since these pics were taken the rear doors have been traded for dented ones). The car has 104,222 miles on it. Also, if you're thinking about buying oem parts from someone else, check my feedback and rest easy knowing you'll get what you paid for. This is wrecked wrx part out #3. As of right now currently these parts are: Unavailable or Damaged: Edit: 9/16 The shell was sold as a roller and the following parts were left on the car and are unavailable (of course): hubs, springs/struts/tophats, front sway bar w/endlinks, front and rear xmembers, steering rack, rear lateral links, rear trailing arms, gas tank, all 4 doors, and trunk steering wheel (went with car shell) trunk carpet/liner (pending) jack handle and tranny support bolts (pending) Shane wrx wheels (did not come with stockers) inlet tube (messed it up) wrx trunk board that covers spare (little warped/damaged) wrx power steering reservoir (damaged) wrx radiator (damaged) wrx a/c condensor (damaged) wrx front bumper (damaged) wrx grill (damaged) wrx hood (damaged) wrx driver and passenger side fenders (damaged) wrx headlights (damaged) wrx abs unit (damaged) lower portion of airbox (damaged) rear bumper (damaged) hoodscoop (damaged, let the owner keep it as a momento) What is SOLD already hks bov - SOLD - Kevin wrx clutch master cylinder SOLD- Kevin wrx clutch slave and line SOLD - Kevin wrx pedal box assembly SOLD - Kevin wrx complete dash setup (trim/cluster/fan box/heater core box, hvac controls, trim around shifter, center console, shift boot, everything but the passenger side airbag) SOLD - Kevin wrx 3 gauge pod from center of dash SOLD - Kevin wrx wrb side mirrors SOLD - Trey wrx rear doors (traded for dented doors)SOLD - Trey wrx left rear exhaust bracket with bolts )SOLD - Michael wrx under seat subwoofer w/harness SOLD - Pablo wrx auto dimming mirror SOLD - Pablo under hood clips/door sill clip/rubber wiper bolt cover - SOLD - Christian wrx 6 disc radio SOLD - David wrx 3rd brake light SOLD - Trey wrx taillights SOLD - Andy wrx a/c compressor SOLD - Charles wrx front 02 sensor SOLD - Charles wrx rear 02 sensor SOLD - Aphex wrx front calipers w/brackets/rotors/pads SOLD - CJ wrx iacv (idle air control valve) SOLD - Chris wrx maf SOLD - Adam wrx ecu & fuse box cover pocket SOLD - Julian exhaust manifolds SOLD - David left trunk liner SOLD - Ben fog light switch SOLD - Alex passenger front window SOLD - Ben metal trim around shifter SOLD - Philip fuel injectors SOLD - Eric bulkhead/front harness w/ fp controller & rear harness SOLD - Tim wrx starter and 4 coil packs SOLD - Tim front left axle and alternator SOLD - Nathan rear diff SOLD - Disraili wrx sideskirts SOLD - Trey stock bpv SOLD - Charles 2 firewall plugs behind intercooler, covers for rear seatbelts, trunk light SOLD - Justin anchor bolt for seatbelt on B pillar SOLD- Gary rear axles and one front axle SOLD- Sam wrx heads w/cams/valves/cam gears SOLD- Matt engine harness & intake manifold SOLD- Matt tgv sensors SOLD- Matt tgv housings & tps (throtte position sensor) SOLD- Matt engine sensors minus throttle body sensors & coil packs SOLD- Matt coolant crossover pipe SOLD- Matt busted mainshaft wrx trans SOLD- Matt stock scissor jack SOLD- Greg fog lights SOLD- Justin heatshield/top bracket/egt sensor SOLD- Nathan rubber door stoppers SOLD- Rasmus stock clock w/surround SOLD- Eric Intercooler brackets w/ bolts SOLD- Eric wrx power steering lines SOLD- Calvin power steering pump SOLD- Douglas timing belt tensioner/idler wheels SOLD- Brian windshield washer reservoir with motor SOLD- Brian defi gauges SOLD- Jerry stock td04 turbo w/coolant and oil lines SOLD- Daniel passenger side airbag w/cover and passenger front seatbelt SOLD- Ching Ricer rims SOLD- Tim A/c line from firewall to compressor (L) SOLD- Evan factory bcs (boost control solenoid) SOLD- Eduardo transmission SOLD- Paul a/c bracketry w/pulley SOLD- Damon driver rear window switch SOLD- Patrick coolant reservoir (metal tank) SOLD- Ben thermostat housing w/bolts SOLD- Dan driver front window motor SOLD- David wrx sunvisors SOLD- Shawn intercooler SOLD- Gabe top and bottom steering column trim pieces, e-brake cables, e-brake hardware, front door lock actuators SOLD- Stephan uppipe SOLD- Cory intake hose from airbox to inlet pipe SOLD- AJ throttle body (no tps or iac) SOLD- Josh wiper motor SOLD- Matt rear 20mm stock sway bar with mountsSOLD- Norm The shell was sold as a roller, so the following parts went with it: hubs/13" steel wheels/xmembers/steering rack/springs/struts/springs/control arms/lateral links/4 doors/gas tank/trunk w/wing SOLD- Robby rear calipers with brackets SOLD- Benny Catalytic section after the dp SOLD - David front and rear seats SOLD - CJ wiper stalk assembly SOLD - Ken damaged driver side airbag SOLD - Wing wrx shortblock w/ 104k SOLD - Andrew water pump SOLD - Andrew brake master cylinder SOLD - Omar magnaflow muffler on stock axleback SOLD - Justin driver side sidemarker SOLD - Andrey egt sensor SOLD - Kevin front driver side abs sensor SOLD - Philip motor mounts from psm wrx SOLD - Shaun dome light SOLD - Abel glove box wiring/switch/bulb SOLD - Abel trunk/gas tank release assembly minus cables SOLD - Jacob "map sensor" - pressure sensor on throttle body SOLD - Andrew Downpipe - SOLD - Tyler a/c line from condensor to compressor (H side) - SOLD - Jeff alternator belt cover - SOLD - Patrick 4 interior door panels (still have 2 others) - SOLD - Russ tool bag, intercooler splitter, & a-pillar trim for driver's side (still have another splitter) - SOLD - Marc helix cel fix - SOLD - BJ passenger rear window switch - SOLD - John headlight/turn signal switch stalk - SOLD - Robert mirror switch (I have another one) w/connector/wiring - SOLD Daniel 3 wire vehicle speed sensor harness - SOLD - Jan Christian A/C bracket - SOLD Drew driver side rear abs sensor (have more) - SOLD -Daniel overflow coolant reservoir - SOLD -Daniel carpet for sedan SOLD (2 more left) devarian floormats SOLDdevarian dead pedal SOLD (2 more left) devarian driver side front window SOLD (at least 1 left) devarian trunk/gas relase handles SOLD devarian mesh bugeye fog covers SOLD devarian driver side front door card SOLD Seth green test mode connectors from leftover chopped up harness SOLD wrx transmission xmember/brace SOLD Joshua Impreza L shifter and knob SOLD Andrew wrx coolant overflow tank SOLD Andrew wrx throttle cable SOLD Jesse driver side radiator fan assembly w/shroud SOLD James gauge cluster bezel surround SOLD Stephen 1 carpet and 1 passenger rear interior door panel SOLD to myself wrx oem intercooler splitter w/hardware - SOLD Josh power steering pump bracket - SOLD Trey What is AVAILABLE Not a complete list by any means, ask me if it's not pending or damaged wrx engine shortblock parts - 3 pistons/rods wrx fuel pump front end links (off another car I parted) rear end link (only 1) cruise control unit (2) a/c line from firewall to strut tower and strut tower to condensor throttle body to intercooler coupler wrx brake booster (booster only) wrx manual driveshaft gas caps (2) valve covers cowl trim (2) (covers the windshield wiper arms/motor) e-brake handle (2) glovebox light/switch w/wiring (1) wrx middle sunvisor (3) power mirror switch/controls (1 or 2 left) wiring harnesses for the doors (have all 4) cruise button (2) wrx map lights (1) wrx dome light (1) wrx ecu cover/kickplate (3) psm fuel door pretty much all interior trim is available that isn't related to the dash, a pillar trim for the passenger side, b-pillar trim, section below b-pillar trim, c-pillar, door card trim, and door sill trim driver and passenger side rear seatbelts front driver side seatbelt windshield wiper arms/motor (from a previous car) all power window/lock switches and motors (all of the single window switches have been sold, I do still have the main driver switchblock ) miscellaneous screws/clips/bolts all door glass minus the passenger front rear deck cover (2) antenna assembly (2) exhaust manifold heatshield for driver's side (minus the crossover pipe) spare wheel/tire (1 of these - black steel with mini-tire) some e-brake components - shoes/springs/clips/etc Impreza L/RS rubber clutch pedal cover - new in bag - 36015GA111 Impreza clutch pedal assembly for hydraulic clutch - new 95 Impreza L power steering lines 95 Impreza L rear axle (only one, the other has messed up threads) 95 Impreza L radiator fans/shrouds 95 Impreza L throttle cable 95 Impreza L fuel pump Again, do not ask me for components that I have specifically said are not available right now, I'll call you a noob . If it's not in the list and you have a question about it, feel free to ask. If it is in the list and I've said it's not available, don't expect me to pm you back, b/c you've failed to read (wastes my time and yours).![]() ![]() ![]() ![]()
Last edited by Aspen_2.5RS; 02-20-2011 at 01:43 PM. Reason: updated parts list 9/12/09 |
#2 | |
Member Sales Rating: (24)
Member#: 82391
Vehicle:08 OBP Sti stg2.... 279awhp, 299tq |
You still have the ecu i wanna get a buddy to look at this if you do. ![]() |
#6 |
Member#: 3310
South East
I don't have an armrest extension. I do have a lower black B-pillar trim piece.
Edit: radio was sold Cam ![]() ![]() brake booster (master cylinder SOLD), High pressure a/c line SOLD, windshield wiper motor/assembly ![]() cruise control unit (3) ![]() coolant tank SOLD ![]() uppipe SOLD and egt sensor SOLD Last edited by Aspen_2.5RS; 03-04-2009 at 02:06 PM. Reason: added more pics |
#7 |
Member Sales Rating: (29)
Member#: 86191
TXIC
Vehicle:2000 brp GC ...and still adding to it |
Thanks for the PM.
I'm looking for the plastic trim that covers the bolts that hold the seats down to the floor. Any luck finding it? |
#8 |
Member#: 3310
South East
Those covers are going to go with the seats more than likely. They are pending right now. I should know in about a week whether or not they are sold for sure.
![]() ![]() Shortblock SOLD Cam Last edited by Aspen_2.5RS; 12-08-2007 at 11:48 PM. Reason: added a pic of the engine with sold parts removed |
#12 |
Member#: 3310
South East
Ugh, why won't the first link use the img tags correctly?
![]() ![]() Mirror needs to be cleaned off, but nothing wrong with it. SOLD! SOLD!Last edited by Aspen_2.5RS; 02-22-2007 at 03:33 PM. Reason: mirror sold |
#18 |
Member Sales Rating: (61)
Member#: 104206
South East
Vehicle:2004 WRX Tunnel Ram Gray |
hey Cam, you still got the plastic Boost control solenoid cover and the two clips? or just the two clips? if so, i can paypal you and include that with my coolant hose you're sending. pm me back. thanks
#25 |
Member#: 3310
South East
Nope, sorry, I sold it off the other car a long time ago.
Like I said, I'll know whether or not I can sell engine related stuff on the 25th (the night of the 25th). Cam |
| Thread Tools | |
| Display Modes | |
| TW: is there any interest for a part out of my 02 WRX | 04 Slo Sti | MWSOC Private Classifieds | 27 | 03-21-2010 04:41 PM |
| FS: Complete Part out of 02 wrx Salvage, OEM-a-Plenty | Aspen_2.5RS | South East Region Private Classifieds | 325 | 10-20-2009 09:30 PM |
| some parts out of my 02 wrx | Johnnypoofies | Private 'For Sale' Classifieds | 3 | 07-22-2006 01:17 PM |
| gauging the interest in a part out of my 02 WRX! | wrk king | New England Impreza Club Forum -- NESIC | 13 | 04-06-2004 09:32 AM |
| Begining the parting out of my 02 WRX! | wrk king | Private 'For Sale' Classifieds | 11 | 01-08-2004 09:12 PM |
