Old 02-18-2007, 05:48 PM   #1
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
Default Brake fluid- does it really matter what kind you use?
That's my question: I'm about to upgrade my rotors and pads to DBA 4000 slotted, and Axxis Ultimate pads. Brake fluid is basically just a hydraulic fluid, right? So, unless I'm going to be tracking my car and boiling the fluid, it's not really necessary to have anything fancy, am I correct? Please, correct me if I'm wrong...
If it DOES matter, and there are bad, good, better, and best kinds of brake fluid, what would you all recommend?
2003 WRX w/ VF39 and supporting mods, pro-tuned, Perrin springs/sways.
Thanks!
~ Josh
Balantz is offline   Reply With Quote
Old 02-18-2007, 05:51 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Depends on how fast you want to stop. Higher boiling point on the fuid is better. As well there was another factor but I am sure someone else will remind me what that is. But with a larger turbo and stock brakes you can use every bit of brakes you can use. Suggest braded lines.
Last edited by hybrid gti 2; 02-18-2007 at 05:52 PM. Reason: missed your brake upgrades
Old 02-18-2007, 06:00 PM   #3
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
Isn't the boiling point only something you reach after repeated hard braking?
What exactly do braided lines do?
Thank you for the feedback.
Old 02-18-2007, 06:09 PM   #4
AlmostFast
Member#: 139312
2005 Sti
Grey
Not to be rude but use the search button next time
http://forums.nasioc.com/forums/showthread.php?t=995498 for all of your maintance needs
and to be more exact here is the link for brake fluids
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Hope this helps.
AlmostFast is offline   Reply With Quote
Old 02-18-2007, 06:25 PM   #5
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
Wow...the power or NASIOC. Thank you, AlmostFast. Close the thread, moderators! Questions answered!
~ Josh
Old 02-18-2007, 10:52 PM   #6
strohausii
Member#: 26770
'02 WRX
midnight black
ATE blue for every other flush, so you visually know you have purged all old fluid.... Would make it easier doing fast flushes before/after track sessions.
strohausii is offline   Reply With Quote
Old 02-19-2007, 12:43 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...I would SERIOUSLY re-think the Ultimates.....they dust like MAD...and they eat rotors....
but they ARE cheap and work rather well FOR THE STREET
Old 02-19-2007, 12:57 AM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
not sure about the eat rotors part. But they dust like mad. come stock with stoptech brakes.
Old 02-19-2007, 09:23 AM   #9
fresh2def
Member#: 140916
2005 STI
Upgraded my STI with Braided Lines, Hawk HPS Front & Rear Pads, and Super Blue Racing Brake fluid. All I can say is WOW...cheap and excellent upgrade.
fresh2def is offline   Reply With Quote
Old 02-19-2007, 11:52 AM   #10
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
ATE Super Blue is perfect for 95% of subaru enthusiasts (including me), Motul 600 for the rest.
- Andrew
GTWORX.com is offline   Reply With Quote
Old 02-19-2007, 11:58 AM   #11
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
what do you mean by the "rest" i have motul 600 just because that's what they had, i also have stoptech lines, dba 4000 slotted front and rea, Hawk hps pads, and cusco master cylinder brace. is super blue better? i don't race, auto-x, track my car it's a daily driver
ray101381 is offline   Reply With Quote
Old 02-19-2007, 12:11 PM   #12
Todd TCE
Member#: 90575
"Better" brake fluid or that of a higher boiling point won't make your car stop any better, faster or whatever.
All it will do is extend the operational level of the fluid at sustained upper temp levels.
If you're not boiling what you have now, you don't need higher bp fluid.
Todd TCE is offline   Reply With Quote
Old 02-19-2007, 12:43 PM   #13
oldmansan
Member#: 17877
Midnight Pearl
Depends on how fast you're going to go. I've cooked Motul RBF600 at the track. If you're tracking the car please look into brake ducts AND good fluid. I'm personally using Castrol SRF, but it is pricey.
San
oldmansan is offline   Reply With Quote
Old 02-19-2007, 12:47 PM   #14
GTWORX.com
Member#: 97303
Gray and Black
Motul 600 is just a tiny tiny bit more for the track guys. Like Todd said, it won't give you any more braking power then the Super Blue, but good if you see higher temps. So for you, ATE superblue will do the job, and as far as I know, lasts a little longer.
- Andrew
Old 02-19-2007, 12:50 PM   #15
complexx
Member#: 46948
2004 Impreza WRX STI
World Rally Blue
I don't know why stoptech supplies motul 600 with their high performance street rigs because rarely do you reach boiling temps while driving on the street. Aside from boiling temperature, the main difference between something like motul 600 and super blue is that over time, the the motul 600 will absorb more water and actually drop your boiling temperature sooner than the super blue would. So for street driving, your better off with the super blue. motul really is only beneficial for tracking purposes. It works fine for the street, but you would probably have to change it more often than the super blue.
complexx is offline   Reply With Quote
Old 02-19-2007, 04:03 PM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The hps pads are what I have now. I rarely get them hot enough to make them work.
Old 02-19-2007, 04:33 PM   #17
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Really? I have HPS pads on my Forester and they're great all the time, even in the way below freezing temps we've had lately.
Not a squeek out of them, decent feel, and enough braking power for me.
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 02-19-2007, 05:17 PM   #18
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Huh?
ATE Superblue dry=536, wet=396 deg F
Motul 600 dry=593, wet=420 deg F
Motul has better wet characteristics, no?
wobbletop is offline   Reply With Quote
Old 02-19-2007, 05:29 PM   #19
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
- Andrew
They will allow general good stoping until you stomp on them then they take longer distance when cold. Atlest from my findings.
Old 02-19-2007, 11:16 PM   #20
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Old 02-20-2007, 10:51 AM   #21
strohausii
Member#: 26770
'02 WRX
midnight black
No track, no auto-x = no reason to get expensive fluid right?
Valvoline brake fluid from store shelves?
Old 02-20-2007, 11:08 AM   #22
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
A great brake fluid to use for street driven/enthusiastically driven cars is Valvoline Syntech. For those that don't wanna spend $10-20 a pint on high-end DOT 5.1 stuff, the Valvoline is a DOT 4 that exceeds the DOT 5.1 dry minimums and comes within about 20degrees of the wet minimums. Also runs like $6 a quart, so its more than enough to bleed out a whole 4-corner brake job with plenty leftover. Its widely avail everywhere, and is definately 100x better than the cheapo DOT3 stuff you can get for $1/pint everywhere.
Even just out bedding-in oem/cheapo pads on a street car, i can boil my fluid using DOT3 stuff in about 2-3 hard stops (after its warmed up with some slow stops). After 2-3 more i have no brakes hardly. Couldn't even auto-x with that stuff.
Using the Syntech, I can put in an easy half dozen hard stops with no appreciable loss in braking.
So yes, if you never, ever drive your car in anything but grandma-style, then a cheapo dollar store fluid would work (or having your brakes bled by a Jiffy-lube type place). If you expect your car to handle the occassional bout of spirited driving down windy roads or what not, i would not stake my life on cheapo fluid.
BTW: glad to hear so many people say they love the HPS/SS lines combo. Thats all the brake work i'm planning for my STi for now, hope it improves a bit over whats in it now.
neko is offline   Reply With Quote
Old 02-20-2007, 12:12 PM   #23
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Both ATE Superblue and Motul are pretty cheap anyway (less then $20). ATE comes in larger cans.
- Andrew
Old 02-20-2007, 12:40 PM   #24
complexx
Member#: 46948
World Rally Blue
Originally Posted by wobbletop View Post
Huh?
I said sooner, not lower. The main emphasis I was trying to make was the the tradeoff you get with high BP product, it will probably deteriorate at a faster rate than the lower BP product. I say probably because I'm not in the industry, just using logical thinking. I could be wrong, but I think it's a reasonable inference. I don't know the standard for deriving wet boiling point numbers.
Does it really matter come on? Starscream Off-Topic 2 10-12-2007 08:50 AM
Spark plug resistance. Does it really matter? t3hWIT Normally Aspirated Powertrain 10 11-29-2006 08:36 AM
Does it really matter where I went to school? merilee Off-Topic 36 07-06-2006 09:15 PM
Sway bar brands... does it really matter? 2000wrx Brakes, Steering & Suspension 17 05-25-2006 12:24 AM
Does it REALLY matter if I tow in neutral? P03w Off-Topic 12 12-02-2005 02:13 PM
