Closed Thread
Old 02-18-2007, 06:45 PM   #1
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Default EJ20 Oil Pan gasket or liquid gasket maker?
I've been searching and haven't found a paper/multilayer gasket for the oil pan on a EJ20 WRX 02 engine, I have found a lot of liquid type gasket materials, like RVT . Does anyone make aftermarket gaskets or just use liquid gasket?
jayfressh is offline
Old 02-18-2007, 06:47 PM   #2
ten94tuner
Member#: 141111
i would use whatever the factory one is. you cant go wrong with that.
ten94tuner is offline
Old 02-18-2007, 06:47 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
subaru doesnt use a gasket on their oil pans
and as such, it is highly unlikely you will find a "gasket" for the 2.0 oil pan
oem or otherwise
simply put, You should use a 3-bond sealant
Jamie
Subie Gal is offline
Old 02-18-2007, 06:49 PM   #4
wirolla
Member#: 109725
2001 GM6
SRP
What he said, use an oem equivalent "liquid gasket"
wirolla is offline
Old 02-18-2007, 06:54 PM   #5
ten94tuner
Member#: 141111
oem or otherwise
Jamie
yea im a vw tech and we dont have any gaskets for oil pans, just some sealant goob we use. what kinda of sealants are out there? i only know of the oem one that i use. What is the oem sealant used on subys?
Old 02-18-2007, 07:53 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
OEM sealant on the subie's is a simple 3-bond
i can get you the subaru part number if you like
Old 02-18-2007, 08:30 PM   #7
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Thanks I figured it was a liquid gasket needed, after I couldn't find any part #'s or gaskets, thanks.
Old 05-07-2016, 01:49 AM   #8
DeezyGC8
Member#: 382370
What is the part# if you don't mind me asking? TIA
DeezyGC8 is offline
Old 05-07-2016, 06:21 AM   #9
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
You must be new here... nope, you're not.
You just bumped a 7 year old thread.
parts.subaru.com
www.subarugenuineparts.com
www.subaruwrxparts.com
Loyale93 is offline
Closed Thread
FS: VA:MD: EJ255 Heads w/cams, 3" S/S V-Band Clamps, EJ20 Oil Pan, Oil Cooler, etc. matt84 Engine/Power/Exhaust 49 03-09-2009 10:45 PM
FS: VA:MD: EJ255 Heads w/cams, 3" S/S V-Band Clamps, EJ20 Oil Pan, Oil Cooler, etc. matt84 MAIC Private Classifieds 42 03-07-2009 02:07 PM
FS: (GC8) Cusco F Strut Bar, EJ20 Oil Pan ai42 Private 'For Sale' Classifieds 10 04-20-2005 01:05 AM
urgent: need help from an EJ20 oil pan expert idealrides Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-14-2004 01:56 PM
('93-'01) oil pick-up tube precaution (in case of oil pan dent or unexplained low oil pressure) Rick G Impreza Forum 0 01-22-2003 08:58 PM
